电子发烧友论坛|
我一个在CCS3.3下编译好的工程,在CCS5.4下有错误。
error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_usDelay.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2800" specified in a previous file or on the command line error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_SysCtrl.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_Sci.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_PieVect.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_PieCtrl.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line >> Compilation failure error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_GlobalVariableDefs.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_DefaultIsr.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_CodeStartBranch.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line error #16008-D: file "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Debug/DSP2833x_ADC_cal.obj" specifies ISA revision "C28FPU32", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line error #16008-D: file "C:/ti/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_ml.lib error #16008-D: file "C:/ti/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_ml.lib error #16008-D: file "C:/ti/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_ml.lib<_lock.obj>" specifies ISA revision "C2800", which is not compatible with ISA revision "C2700" specified in a previous file or on the command line error #16008-D: file "C:/ti/ccsv5/tools/compiler/c2000_6.1.3/lib/rts2800_ml.lib error #10010: errors encountered during linking; "E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Example_2833xScia_FFDLB/../../../DSP2833x_examples/sci_loopback/Debug/Example_2833xScia_FFDLB.out" not built gmake: *** [E:/dsp/F/ccs3.381/DSP28335/DS1302/DS1302/DSP2833x_examples/sci_loopback/Example_2833xScia_FFDLB/../../../DSP2833x_examples/sci_loopback/Debug/Example_2833xScia_FFDLB.out] Error 1 gmake: Target `all' not remade because of errors. **** Build Finished **** 请高手指教,如何解决?谢谢! |
2 个讨论
只有小组成员才能发言,加入小组>>
550 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1514 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1338 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2783浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 17:57 , Processed in 0.681711 second(s), Total 46, Slave 37 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2821
