本人目前有拿到两种开发套件:1套是CC2538 smartrf06开发套件 ;1套是CC2530 smartrf05开发套件。
CC2530套件跑的是协议栈ZStack-CC2530-2.5.1a, 两个设备1个coordinator,1个enddevice两者通信正常; CC2538套件跑的是协议栈Z-Stack Mesh 1.0.0,两个设备1个coordinator,1个enddevice两者也通信正常; 然后做了一个交叉的实验,就是跑协议栈Z-Stack Mesh 1.0.0的CC2538做为coordinator,跑ZStack-CC2530-2.5.1a的CC2530做为end device,他们之间可以组网成功,但是通信不正常,互相收不到发送的字符串 “hello world”,求解啊! |
4 个讨论
小Qhhui 发表于 2018-8-17 06:48 另外我刚用Z-stack Home1.2.0里面CC2530的例程编译了下,总出现如下编译错误: Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 482 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 507 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 511 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 512 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 557 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 569 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 599 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 680 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 680 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 729 Error[Pe095]: array is too large C:Texas InstrumentsZ-Stack Home 1.2.1ComponentshaltargetCC2530EB_hal_uart_dma.c 735 Error while running C/C++ Compiler mac_autopend.c Error[Pe167]: argument of type "unsigned char *" is incompatible with parameter of type "unsigned char volatile __xdata *" C:Texas InstrumentsZ-Stack Home 1.2.1Componentsmaclow_levelsrf04mac_autopend.c 464 Error[Pe167]: argument of type "unsigned char *" is incompatible with parameter of type "unsigned char volatile __xdata *" C:Texas InstrumentsZ-Stack Home 1.2.1Componentsmaclow_levelsrf04mac_autopend.c 472 Error[Pe167]: argument of type "unsigned char *" is incompatible with parameter of type "unsigned char volatile __xdata *" C:Texas InstrumentsZ-Stack Home 1.2.1Componentsmaclow_levelsrf04mac_autopend.c 561 Error[Pe167]: argument of type "unsigned char *" is incompatible with parameter of type "unsigned char volatile __xdata *" C:Texas InstrumentsZ-Stack Home 1.2.1Componentsmaclow_levelsrf04mac_autopend.c 580 Error[Pe167]: argument of type "unsigned char *" is incompatible with parameter of type "unsigned char volatile __xdata *" C:Texas InstrumentsZ-Stack Home 1.2.1Componentsmaclow_levelsrf04mac_autopend.c 598 Error[Pe167]: argument of type "unsigned char *" is incompatible with parameter of type "unsigned char volatile __xdata *" C:Texas InstrumentsZ-Stack Home 1.2.1Componentsmaclow_levelsrf04mac_autopend.c 616 |
电路学友 发表于 2018-8-17 07:00 更正一个比较低级的错误,TI提供的最新协议栈中的CC2530部分是可以编译通过的,之所以出现如上的各种编译错误是因为我的PC上安装了EW430,EWARM,EW8051多个版本的IAR,导致打开CC2530工程时,IAR中的工程配置部分乱了,导致各种编译问题。 |
只有小组成员才能发言,加入小组>>
340 浏览 1 评论
533 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
777 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
653 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1132 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
63浏览 29评论
169浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
255浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
205浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
60浏览 13评论
GMT+8, 2024-12-24 03:11 , Processed in 0.957993 second(s), Total 64, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
