电子发烧友论坛|
3 个讨论
Q1: 如果CC2530一直使用定时器计时,功率大概是多少?
看数据手册,有给外设电流大小。或者接个万用表实测下电流就好了。 PARAMETER TEST CONDITIONS MIN TYP MAX UNIT Digital regulator on. 16-MHz RCOSC running. No radio, crystals, or peripherals active. 3.4 mA Medium CPU activity: normal flash access(1), no RAM access 32-MHz XOSC running. No radio or peripherals active. 6.5 8.9 mA Medium CPU activity: normal flash access(1), no RAM access 32-MHz XOSC running, radio in RX mode, –50-dBm input power, no peripherals active, CPU 20.5 mA idle 32-MHz XOSC running, radio in RX mode at -100-dBm input power (waiting for signal), no 24.3 29.6 mA Core current peripherals active, CPU idle Icore consumption 32-MHz XOSC running, radio in TX mode, 1-dBm output power, no peripherals active, CPU idle 28.7 mA 32-MHz XOSC running, radio in TX mode, 4.5-dBm output power, no peripherals active, CPU 33.5 39.6 mA idle Power mode 1. Digital regulator on; 16-MHz RCOSC and 32-MHz crystal oscillator off; 0.2 0.3 mA 32.768-kHz XOSC, POR, BOD and sleep timer active; RAM and register retention Power mode 2. Digital regulator off; 16-MHz RCOSC and 32-MHz crystal oscillator off; 1 2 μA 32.768-kHz XOSC, POR, and sleep timer active; RAM and register retention Power mode 3. Digital regulator off; no clocks; POR active; RAM and register retention 0.4 1 μA Peripheral Current Consumption (Adds to core current Icore for each peripheral unit activated) Timer 1 Timer running, 32-MHz XOSC used 90 μA Timer 2 Timer running, 32-MHz XOSC used 90 μA Timer 3 Timer running, 32-MHz XOSC used 60 μA Iperi Timer 4 Timer running, 32-MHz XOSC used 70 μA Sleep timer Including 32.753-kHz RCOSC 0.6 μA ADC When converting 1.2 mA Erase 1 mA Flash Burst write peak current 6 mA |
原文地址:http://www.kaleidscope.cn:1020/archives/1056
以下为部分内容: Zigbee协议栈中如果要实现一个定时事件或者延时的话,有很多种方法,定时事件呢其实就是我们熟悉的使用定时器来定时,产生定时事件,当然也可以用来延时。 1、协议栈定时器HalTimerConfig ZigBee协议栈提供了定时器的使用接口,在hal层调用HalTimerConfig即可配置使用,而定时器2被协议栈占用了,所以只有使用1、3、4三个定时器。 在hal_timer.h中我们可以看到几个定时器的定义: /* Timer ID definitions */ #define HAL_TIMER_0 0x00 // 8bit timer #define HAL_TIMER_1 0x01 // 16bit Mac timer #define HAL_TIMER_2 0x02 // 8bit timer #define HAL_TIMER_3 0x03 // 16bit timer #define HAL_TIMER_MAX 4 // Max number of timer 所以和硬件中的定时器是有区别的,经过了映射,这里需要注意一下。 * HAL_TIMER_0 --> HW Timer 3 8bit * HAL_TIMER_2 --> HW Timer 4 8bit * HAL_TIMER_3 --> HW Timer 1 16bit 如果我们要使用协议栈的定时器进行相关操作,只需进行定时器的配置即可: extern uint8 extern uint8 HalTimerConfig ( uint8 timerId,uint8 opMode,uint8 channel,uint8 channelMode,bool intEnable,halTimerCBack_t cback ); opMode - Operation mode操作方式共3种 * channel - Channel where the counter operates on选择通道,对应IO口 * channelMode - Mode of that channel通道的模式 * intEnable -可中断 * cBack - Pointer to the callback function 中断函数 然后在回调函数中进行处理相关事件即可。 void timer_callback(uint8 timerId, uint8 channel, uint8 channelMode); 2、使用寄存器直接操作 直接使用寄存器就更简单了,就把CC2530当做一个单片机用就可以了,这里我拿了我以前写的代码给大家演示,注释有错的地方请忽略,大概就这样吧。 void InitT3(void) [ T3CTL |= 0x08 ; //开溢出中断 T3IE = 1; //开总中断和T3中断 T3CTL|=0X12; //,128/16000000*N=0.5S,N=65200 T3CC0 = 0x01; T3CTL &= ~0X03; //自动重装 00->0xff T3CTL |=0X10; //启动 ] void timer1Init(void) [/*设置定时器T1,128分频,模模式,从0计数到T1CC0*/ |
只有小组成员才能发言,加入小组>>
584 浏览 0 评论
1641 浏览 0 评论
2080 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1533 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1372 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1782浏览 29评论
2810浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1742浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1654浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1672浏览 13评论
/9
GMT+8, 2025-12-10 01:12 , Processed in 0.779560 second(s), Total 52, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
7352
