7 个讨论
lkjljljlj 发表于 2018-8-6 08:52 hi,您好 我在用6678 evm测试的时候,所有的程序段分配在DDR,传入以下DDR参数表 00 00 00 70 00 87 35 00 02 42 80 F5 00 00 00 00 00 00 00 1C 00 00 00 02 63 06 2A 32 00 00 00 00 00 00 14 50 11 13 78 3C 30 71 7F E3 55 9F 86 AF 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 70 07 32 14 00 00 00 00 00 10 01 0F 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 03 05 是可以正常boot 的,我的理解是这些参数对DDR做了初始化才使得boot 能够成功,不知对不对? 谢谢! |
您好, 我用的是SPI加载,根据tiboot.h下的DDR配置参数结构体: typedef struct bootEmif4Tbl_s [ UINT32 configSelect; /* Bit map defining which registers to set */ UINT32 pllPrediv; /* Values of all 0s will disable the pll */ UINT32 pllMult; UINT32 pllPostDiv; UINT32 sdRamConfig; UINT32 sdRamConfig2; UINT32 sdRamRefreshCtl; UINT32 sdRamTiming1; UINT32 sdRamTiming2; UINT32 sdRamTiming3; UINT32 lpDdrNvmTiming; UINT32 powerManageCtl; UINT32 iODFTTestLogic; UINT32 performCountCfg; UINT32 performCountMstRegSel; UINT32 readIdleCtl; UINT32 sysVbusmIntEnSet; UINT32 sdRamOutImpdedCalCfg; UINT32 tempAlterCfg; UINT32 ddrPhyCtl1; UINT32 ddrPhyCtl2; UINT32 priClassSvceMap; UINT32 mstId2ClsSvce1Map; UINT32 mstId2ClsSvce2Map; UINT32 eccCtl; UINT32 eccRange1; UINT32 eccRange2; UINT32 rdWrtExcThresh; ] BOOT_EMIF4_TBL_T; 然后传入对应DDR初始化需要的值,但是没发现与leveling的操作相关的配置 谢谢! |
Leveling寄存器没有配置时会用缺省值,这对某些板子可能可以,但绝对不是一个可靠的配置。 如果你用SPI加载的话,可以试以下bootloader user's guide中介绍的方法: 3.2.3 Boot Configuration Table A boot configuration table is used if certain peripherals must be programmed with values that differ from their reset values before loading an application. For example, if the application needs to be loaded into DDR memory, the boot configuration table can be used to program the DDR registers and enable the DDR peripheral before loading the application code into DDR. Each table entry in the boot configuration table has three elements: • The address to be modified • The set mask • The clear mask The RBL reads the specified address, then sets any bits that are set in the set mask element and clears any bits that are set in the clear mask element. If both the set and clear mask elements are 0, the value in the address field is branched via a standard call with the return address stored in register B3. The boot configuration table is terminated when all three elements are 0. |
dualxu 发表于 2018-8-6 09:50 你说的几个参数是用来配置DDR PLL的,PLLOUT=input_CLK*(PLLM+1)/PLLD,在C6678 data manual中有 其他的DDR参数使用如下链接的spreadsheet生成: http://www.deyisupport.com/question_answer/dsp_arm/c6000_multicore/f/53/t/53384.aspx |
只有小组成员才能发言,加入小组>>
607 浏览 0 评论
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1921 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3677 浏览 4 评论
5043 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1746 浏览 1 评论
CC3100BOOST使用CC3200lunchXL进行烧录
704浏览 2评论
750浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
727浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1216浏览 1评论
1803浏览 1评论
GMT+8, 2024-5-21 11:47 , Processed in 1.015767 second(s), Total 57, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
