电子发烧友论坛|
想请教一下,为何我用FPGA控制AD5242写的时候,两个电位器之间阻值变化会相互影响?就是同一个芯片中0号变化以后,去变化1号,反过来看0号,它也变了。我用同一根IIC控制4个此芯片,这4个芯片间也会有相互影响。
以下是我的FPGA程序,请大神指点~ module write( clk,rst_n, sda,scl,data_24,iic_en ); input clk; // 50MHz input rst_n; input [23:0] data_24; inout sda;
input iic_en; //effective on 1 //--------------------------------------------- reg[2:0] cnt; reg[9:0] cnt_delay; reg scl_r; always @ (posedge clk or negedge rst_n)
always @ (posedge clk or negedge rst_n) begin
end always @ (posedge clk or negedge rst_n)
`define SCL_POS (cnt_delay==9'd499) `define SCL_HIG (cnt_delay==9'd124) `define SCL_NEG (cnt_delay==9'd249) `define SCL_LOW (cnt_delay==9'd280) //--------------------------------------------- reg[3:0] num; reg[7:0] db_r; reg sda_link; reg[7:0] sda_r; reg[3:0] cstate; parameter START = 4'd0; parameter ADD1 = 4'd1; parameter ACK1 = 4'd2; parameter ADD2 = 4'd3; parameter ACK2 = 4'd4; parameter DATA = 4'd5; parameter ACK3 = 4'd6; parameter STOP1 = 4'd7; parameter ENABLE = 4'd8; //--------------------------------------------- always @ (posedge clk or negedge rst_n) begin if(!rst_n) begin num <= 3'd0; sda_link <= 1'b1; sda_r <= 1'b1; cstate <= ENABLE; end else begin case (cstate) ENABLE:begin if(iic_en) begin cstate <= START; end else cstate <= ENABLE; end START: begin if(`SCL_HIG) begin sda_link <= 1'b1; db_r <= data_24[23:16]; sda_r <= 1'b0; cstate <= ADD1; num <= 4'd0; end else cstate <= START; end ADD1: begin if(`SCL_LOW) begin if(num == 4'd8) begin num <= 4'd0; sda_r <= 1'b1; sda_link <= 1'b0; cstate <= ACK1; end else begin cstate <= ADD1; num <= num+1'b1; case (num) 4'd0: sda_r <= db_r[7]; 4'd1: sda_r <= db_r[6]; 4'd2: sda_r <= db_r[5]; 4'd3: sda_r <= db_r[4]; 4'd4: sda_r <= db_r[3]; 4'd5: sda_r <= db_r[2]; 4'd6: sda_r <= db_r[1]; 4'd7: sda_r <= db_r[0]; default: ; endcase end end else cstate <= ADD1; end ACK1: begin if(/*!sda*/`SCL_NEG) begin cstate <= ADD2; db_r <= data_24[15:8]; end else cstate <= ACK1; end ADD2: begin if(`SCL_LOW) begin if(num == 4'd8) begin sda_link <= 1'b0; sda_r <= 1'b1; num <= 4'd0; cstate <= ACK2; end else begin sda_link <= 1'b1; cstate <= ADD2; num <= num+1'b1; case (num) 4'd0: sda_r <= db_r[7]; 4'd1: sda_r <= db_r[6]; 4'd2: sda_r <= db_r[5]; 4'd3: sda_r <= db_r[4]; 4'd4: sda_r <= db_r[3]; 4'd5: sda_r <= db_r[2]; 4'd6: sda_r <= db_r[1]; 4'd7: sda_r <= db_r[0]; default: ; endcase end end else cstate <= ADD2; end ACK2: begin if(/*!sda*/`SCL_NEG) begin cstate <= DATA; db_r <= data_24[7:0]; end else cstate <= ACK2; end DATA: begin if(`SCL_LOW) begin if(num == 4'd8) begin sda_link <= 1'b0; sda_r <= 1'b1; num <= 4'd0; cstate <= ACK3; end else begin sda_link <= 1'b1; cstate <= DATA; num <= num+1'b1; case (num) 4'd0: sda_r <= db_r[7]; 4'd1: sda_r <= db_r[6]; 4'd2: sda_r <= db_r[5]; 4'd3: sda_r <= db_r[4]; 4'd4: sda_r <= db_r[3]; 4'd5: sda_r <= db_r[2]; 4'd6: sda_r <= db_r[1]; 4'd7: sda_r <= db_r[0]; default: ; endcase end end else cstate <= DATA; end ACK3: begin if(/*!sda*/`SCL_NEG) begin sda_r <= 1'b0; sda_link <= 1'b1; cstate <= STOP1; end else cstate <= ACK3; end STOP1: begin if(`SCL_HIG) begin sda_link <= 1'b1; sda_r <= 1'b1; cstate <= START; end else cstate <= STOP1; end default: cstate <= START; endcase end end assign sda = sda_link ? sda_r:1'bz; //--------------------------------------------- endmodule |
相关推荐 |
只有小组成员才能发言,加入小组>>
寻求ADF5355类似的微波源,在DC-15GHz内,锁频时间在1ms内
1787 浏览 0 评论
1627 浏览 0 评论
999 浏览 0 评论
1098 浏览 0 评论
ADF5355失锁: 在用ADF5355进行多次扫频时,延时给了500ms还是经常会失锁
1189 浏览 0 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
2845浏览 3评论
2086浏览 2评论
给ADUM4223 增加信号驱动15V电压就不正常, 波动很大会被烧是什么情况?
2119浏览 2评论
1173浏览 2评论
使用ADI官方提供的no-OS來接收GPS L1(1575.42MHz)的資料
1405浏览 1评论
/9
GMT+8, 2025-12-2 05:40 , Processed in 0.447114 second(s), Total 40, Slave 33 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
5106
