电子发烧友论坛|
关于AD9910低温下加电异常技术咨询
(Help needed regarding the fault of AD9910 at power-on in low temperature condition) 现象描述:低温下(-40℃~0℃)AD9910反复加电30次左右出现一次故障,无输出信号。AD9910仅使用分频功能,参考为480M单音信号,输出为26~30M单音信号。 (Fault description: AD9910 is used for frequency-dividing, with reference input of 480MHz, and output of 26~30MHz single tone signal. There is one fault ( with no output signal) out of 30 times at time of power-on in low temperature(-40℃~0℃) ) 使用通用SPI控制发数,SCLK,SDIO和I/O_UPDAT时序如下: Data was sent by general SPI interface, and the timing sequence of SCLK,SDIO Vs. I/O_UPDAT is as follows: 红色是SCLK,黄色是SDIO,绿色是I/O_UPDAT。 red-SCLK, yellow-SDIO, green- I/O_UPDAT 上图展开 观测SCLK与I/O_UPDAT交汇点。 watching the intersection of SCLK and I/O_UPDAT 咨询1:请问SCLK,SDIO与I/O_UPDAT如上图配置是否存在问题? question 1: Is the parameter setting-up of SCLK,SDIO Vs. I/O_UPDAT is correct as being shown above 将SCLK和I/O_UPDAT时序改为如下后低温未出现故障现象。 when the timing sequence was changed as being shown followed, there was no fault at time of power-on in low temperature. 黄色为SCLK,绿色为I/O_UPDAT。 yellow--SCLK, green--I/O_UPDAT 将I/O_UPDAT在时钟完成2个周期后在置高 Once the I/O_UPDAT was set to high after 2 periods of SCLK, there was no fault at time of power-on in low temperature. our second question was: is there a delay required for I/O_UPDAT regarding SCLK signal? if yes, how to set up the time delay? 咨询2:更改时序后未出现故障,是否因为I/O_UPDAT与SCLK之间要求有延时,请问延时如何控制?
1个回答
只有小组成员才能发言,加入小组>>
寻求ADF5355类似的微波源,在DC-15GHz内,锁频时间在1ms内
1787 浏览 0 评论
1627 浏览 0 评论
999 浏览 0 评论
1098 浏览 0 评论
ADF5355失锁: 在用ADF5355进行多次扫频时,延时给了500ms还是经常会失锁
1189 浏览 0 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
2843浏览 3评论
2086浏览 2评论
给ADUM4223 增加信号驱动15V电压就不正常, 波动很大会被烧是什么情况?
2119浏览 2评论
1173浏览 2评论
使用ADI官方提供的no-OS來接收GPS L1(1575.42MHz)的資料
1405浏览 1评论
/9
GMT+8, 2025-12-2 00:38 , Processed in 0.650620 second(s), Total 72, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1686
