时序图如上,读取PART ID 返回0xF0。从时序可以看到依次写入的是0x0B,0x02,后返回了0xF0。这是什么问题,求解答? 配置代码: hspi1.Instance = SPI1; hspi1.Init.Mode = SPI_MODE_MASTER; hspi1.Init.Direction = SPI_DIRECTION_2LINES; hspi1.Init.DataSize = SPI_DATASIZE_8BIT; hspi1.Init.CLKPolarity = SPI_POLARITY_LOW; hspi1.Init.CLKPhase = SPI_PHASE_1EDGE; hspi1.Init.NSS = SPI_NSS_SOFT; hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8; hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB; hspi1.Init.TIMode = SPI_TIMODE_DISABLE; hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE; hspi1.Init.CRCPolynomial = 10; if (HAL_SPI_Init(&hspi1) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } 引脚初始化: hspi1.Instance = SPI1; hspi1.Init.Mode = SPI_MODE_MASTER; hspi1.Init.Direction = SPI_DIRECTION_2LINES; hspi1.Init.DataSize = SPI_DATASIZE_8BIT; hspi1.Init.CLKPolarity = SPI_POLARITY_LOW; hspi1.Init.CLKPhase = SPI_PHASE_1EDGE; hspi1.Init.NSS = SPI_NSS_SOFT; hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_8; hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB; hspi1.Init.TIMode = SPI_TIMODE_DISABLE; hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE; hspi1.Init.CRCPolynomial = 10; if (HAL_SPI_Init(&hspi1) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } 读取: uint8_t rd_addr = 0; uint8_t reg_cmd = 0; rd_addr = registerAddress; ADXL362_ENABLE(); //HAL_Delay(2); reg_cmd = ADXL362_READ_REG; HAL_SPI_Transmit(&hspi1, ®_cmd, 1, 1000); HAL_SPI_Transmit(&hspi1, &rd_addr, 1, 1000); HAL_SPI_Receive(&hspi1, pReadData, bytesNumber, 1000); //HAL_Delay(200); ADXL362_DISABLE(); 附件为逻辑分析仪捕捉的时序图。 |
相关推荐 |
只有小组成员才能发言,加入小组>>
1001 浏览 2 评论
给ADUM4223 增加信号驱动15V电压就不正常, 波动很大会被烧是什么情况?
1393 浏览 2 评论
ADP5092 SYS端口为2.09V,但是REG_OUT为0是什么原因?
1941 浏览 1 评论
ad7193差分输入ain1与ain2差是正值时,读到电压与实际值误差小,但为负值值,误差就变的很大
4274 浏览 2 评论
9067 浏览 1 评论
ADC3442采集,分析数据出现有规则毛刺,请问是哪方面的问题啊?
1542浏览 3评论
AD7190状态寄存器一直是0x80,连续转换模式下RDY不拉低
1700浏览 2评论
1002浏览 2评论
1678浏览 2评论
1393浏览 2评论
GMT+8, 2024-12-26 11:23 , Processed in 0.848292 second(s), Total 76, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
