参考链接:http://processors.wiki.ti.com/index.php/Connecting_to_DSP_on_C6A8168,_DM8168,_DM8148
我载的dm814x相关的gel文件具体使用文件为附件中 IOExpansion_test_2.x.gel 操作步骤如下 1.通过串口停止uboot进一步加载 2.按照参考链接配置gel文件,launch Configuration 后connect A8核 在scripts中执行DM814X system Initialization->DM814x_System_Initialisation_GP_driver(); 3.执行结果如下: CortexA8: GEL Output: PLL and Control MMR unlock done ... CortexA8: Output: DM814X ALL ADPLL INIT IS IN PROGRESS,Please wait ..... CortexA8: Output: DM814X MODENA_PLL Init is in Progress, Please wait ..... CortexA8: GEL Output: ADPLLS CLKOUT value is = 600 CortexA8: Output: DM814X MODENA_PLL Init is Done CortexA8: Output: DM814X MODENA_PLL is initialized to 600Mhz CortexA8: Output: DM814X DSS_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X DSS_PLL Init is Done CortexA8: Output: DM814X DSS_PLL is initialized to 200MHz CortexA8: Output: DM814X DSP_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X DSP_PLL Init is Done CortexA8: Output: DM814X DSP_PLL is initialized to 500MHz CortexA8: Output: DM814X SGX_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X SGX_PLL Init is Done CortexA8: Output: DM814X SGX_PLL is initialized to 200MHz CortexA8: Output: DM814X IVA_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X IVA_PLL Init is Done CortexA8: Output: DM814X IVA_PLL is initialized to 266MHz CortexA8: Output: DM814X ISS_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X ISS_PLL Init is Done CortexA8: Output: DM814X ISS_PLL is initialized to 400MHz CortexA8: Output: DM814X USB_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X USB_PLL Init is Done CortexA8: Output: DM814X USB_PLL is initialized to 200MHz CortexA8: Output: DM814X DDR_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X DDR_PLL Init is Done CortexA8: Output: DM814X DDR_PLL is initialized to 666MHz CortexA8: Output: DM814X AUDIO_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X AUDIO_PLL Init is Done CortexA8: Output: DM814X AUDIO_PLL is initialized to 200MHz CortexA8: Output: DM814X HDMI_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X HDMI_PLL Init is Done CortexA8: Output: DM814X VIDEO_0_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X VIDEO_0_PLL Init is Done CortexA8: Output: DM814X VIDEO0_PLL is initialized to 54MHz CortexA8: Output: DM814X VIDEO_1_PLL Init is in Progress, Please wait ..... CortexA8: Output: DM814X VIDEO_1_PLL Init is Done CortexA8: Output: DM814X VIDEO1_PLL is initialized to 148.5MHz CortexA8: Output: --- SATA PLL Locked CortexA8: Output: **** DM814X ALL ADPLL INIT IS COMPLETE ******* CortexA8: Trouble Writing Memory Block at 0x48100100 on Page 0 of Length 0x4: (Error -1065 @ 0x3D5A) Unable to access device memory. Verify that the memory address is in valid memory. If error persists, confirm configuration, power-cycle board, and/or try more reliable JTAG settings (e.g. lower TCLK). (Emulation package 5.1.73.0) DM814X_System_Initialisation_GP_device() cannot be evaluated. target access failed at *((unsigned int *) 0x48100100)=(unsigned int) 0x01031FFF [IOExpansion_test_2.x.gel:708] at PLL_CLOCKS_Config() [IOExpansion_test_2.x.gel:865] at DM814X_System_Initialisation_GP_device() 在0x48100100出寄存器操作失败, 对应的GEL文件中语句是: WR_MEM_32(0x48100100, 0x01031FFF); //WR_MEM_32(0x48100114, 0xC010E); //WR_MEM_32(0x48100118, 0xF); 如果把“WR_MEM_32(0x48100100, 0x01031FFF);”注释掉,GEL脚步不能正常执行完毕。 0x48100100寄存器说明如下: 疑问: 1.0x48100100寄存器为何不能操作。 2.想要利用CCS对A8进行调试是否初始化:PSC、PLL、DDR、即可 3.因为缺乏linux基础和多核调试经验,想在CCS上进行A8和DSP的单核调试,直接添加至liunx体系下,不知该思路是否可行 求解答(ㆀ˘・з・˘) |
4 个讨论
物是人非aaa 发表于 2018-7-25 09:00 Chris, 我使用的是Appro DM8127 IPNC ,如下图所示 现在发现在停止boot后能够load A8程序,但A8程序中有些寄存器不能正常访问,例如“HDVPSS Peripheral Registers” 不知道是否在boot初始阶段对寄存器访问进行了限制? 主要想通过单核调试一些驱动,主要做的应用是对capture图像进行算法处理显示,需求是720P@60在LCD上显示。 ps,在A8程序中的printf 函数没有在console里打印输出,不知是否正常? 感谢回复~ |
只有小组成员才能发言,加入小组>>
TMS320F28377D:新做了以377d为芯片的板子,上电后芯片复位引脚出现方波请问如何解决?
1910 浏览 0 评论
TPS55340通电后输入端保险丝烧断,芯片输入和GND之间短路
3667 浏览 4 评论
5041 浏览 0 评论
请问如何用DM368对RGB格式的图片数据进行编码生成JPEG格式图片?
1740 浏览 1 评论
9426 浏览 8 评论
CC3100BOOST使用CC3200lunchXL进行烧录
683浏览 2评论
730浏览 1评论
TMS320F28034: 利用C2prog通过SCI给TMS320F28034烧录程序,出现错误提示:Bootloading... failed (invalid echo)!
700浏览 1评论
求DLPC350 Programmer’s Guide User's Guide 中文版说明书
1209浏览 1评论
1794浏览 1评论
GMT+8, 2024-5-12 10:13 , Processed in 0.771653 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
