U-Boot 2016.09.01 (Jul 19 2018 - 20:34:36 -0700) CPUID: 32440001 FCLK: 400 MHz HCLK: 100 MHz PCLK: 50 MHz DRAM: 64 MiB WARNING: Caches not enabled Flash: 0 Bytes NAND: 256 MiB *** Warning - bad CRC, using default environment In: serial Out: serial Err: serial Net: dm9000 Hit any key to stop autoboot: 0 JZ2440 # save Saving Environment to NAND... env_valid = 1 saveenv函数原型在common/env_nand.c文件 第一行是我加的打印没有执行 int saveenv(void) { printf("saveenv()n"); int ret = 0; ALLOC_CACHE_ALIGN_BUFFER(env_t, env_new, 1); int env_idx = 0; static const struct env_location location[] = { { .name = "NAND", .erase_opts = { .length = CONFIG_ENV_RANGE, .offset = CONFIG_ENV_OFFSET, }, }, #ifdef CONFIG_ENV_OFFSET_REDUND { .name = "redundant NAND", .erase_opts = { .length = CONFIG_ENV_RANGE, .offset = CONFIG_ENV_OFFSET_REDUND, }, }, #endif }; if (CONFIG_ENV_RANGE < CONFIG_ENV_SIZE) return 1; ret = env_export(env_new); if (ret) return ret; #ifdef CONFIG_ENV_OFFSET_REDUND env_new->flags = ++env_flags; /* increase the serial */ env_idx = (gd->env_valid == 1); #endif ret = erase_and_write_env(&location[env_idx], (u_char *)env_new); #ifdef CONFIG_ENV_OFFSET_REDUND if (!ret) { /* preset other copy for next write */ gd->env_valid = gd->env_valid == 2 ? 1 : 2; return ret; } env_idx = (env_idx + 1) & 1; ret = erase_and_write_env(&location[env_idx], (u_char *)env_new); if (!ret) printf("Warning: primary env write failed," " redundancy is lost!n"); #endif return ret; } |
5个回答
没有打印说明没有执行这个函数
还有,你可以试试命令saveenv,而不是save命令
saveenv 和save命令一样,
试试保存改为saveenv,或者直接调用看看
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
基于米尔MYC-LR3576开发板的实时视频识别系统设计与实现
432 浏览 0 评论
飞凌嵌入式ElfBoard-文件I/O的深入学习之阻塞I/O与非阻塞I/O
523 浏览 0 评论
大神们,想知道你们都用什么ide编程调试器? Arduino IDE?还是 e2studio ?还有其他吗?哪个好用呢
680 浏览 0 评论
925 浏览 0 评论
888 浏览 0 评论
/9
GMT+8, 2025-12-4 09:57 , Processed in 0.593479 second(s), Total 49, Slave 42 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
3134
