扫一扫,分享给好友
大神们,帮忙啊,菜鸟一只,刚接触汇编。我这边想在C语言中添加汇编模块,汇编模块的作用是对GPIO口进行拉高拉低,即输出一个方波。但在编译的时候汇编部分出现如下错误:
ERRORS: [E0001] Illegal symbol [E0003] Unexpected trailing operand(s) [E0200] Bad term in expression 经过检查发现,出问题是下面两条汇编语句 LDR r0,=0x01E2606c STR r1,[r0] 我就是想对控制GPIO的相应寄存器进行赋值。请问一下 1 上述汇编有没有问题,因为我发现像mov等关键字都会变颜色,但LDR和STR没有变。感觉好像不支持一样(我用的是CCS v4,芯片是AM1808) 2 ccsv4支持的汇编语句及其相应的例子可以在哪里看 3 C语言和汇编混合编程有什么资料推荐吗 |
1个回答
写法不对,参考文档spru187t的7.5.4节:
7.5.4 Using Inline Assembly Language Within a C/C++ program, you can use the asm statement to insert a single line of assembly language into the assembly language file created by the compiler. A series of asm statements places sequential lines of assembly language into the compiler output with no intervening code. For more information, see Section 6.8. The asm statement is useful for inserting comments in the compiler output. Simply start the assembly code string with a semicolon (;) as shown below: asm(";*** this is an assembly language comment"); NOTE: Using the asm Statement Keep the following in mind when using the asm statement: • Be extremely careful not to disrupt the C/C++ environment. The compiler does not check or analyze the inserted instructions. • Avoid inserting jumps or labels into C/C++ code because they can produce unpredictable results by confusing the register-tracking algorithms that the code generator uses. • Do not change the value of a C/C++ variable when using an asm statement. This is because the compiler does not verify such statements. They are inserted as is into the assembly code, and potentially can cause problems if you are not sure of their effect. • Do not use the asm statement to insert assembler directives that change the assembly environment. • Avoid creating assembly macros in C code and compiling with the --symdebug:dwarf (or -g) option. The C environment’s debug information and the assembly macro expansion are not compatible. http://processors.wiki.ti.com/index.php/Main_Page Think Over Before Asking. http://www.catb.org/~esr/faqs/smart-questions.html#goal |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 04:17 , Processed in 0.528795 second(s), Total 41, Slave 34 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2039
