扫一扫,分享给好友
我用的是ti-SDK-am335x-evm-06.00.00.00 PSP是linux3.2.0-psp04.06.00.11,为了在BBB上用上CAN总线,对mux33xx.c做了如下修改
修改前 _AM33XX_MUXENTRY(UART1_CTSN, 0, "uart1_ctsn", NULL, " NULL", "i2c2_sda", "spi1_cs0", NULL, NULL, "gpio0_12"), _AM33XX_MUXENTRY(UART1_RTSN, 0, "uart1_rtsn", NULL, " NULL", "i2c2_scl", "spi1_cs1", NULL, NULL, "gpio0_13"), _AM33XX_MUXENTRY(UART1_RXD, 0, "uart1_rxd", "mmc1_sdwp", " NULL", "i2c1_sda", NULL, "pr1_uart0_rxd_mux1", NULL, "gpio0_14"), _AM33XX_MUXENTRY(UART1_TXD, 0, "uart1_txd", "mmc2_sdwp", " NULL", "i2c1_scl", NULL, "pr1_uart0_txd_mux1", NULL, "gpio0_15"), 修改后 _AM33XX_MUXENTRY(UART1_CTSN, 0, "uart1_ctsn", NULL, "d_can0_tx", "i2c2_sda", "spi1_cs0", NULL, NULL, "gpio0_12"), _AM33XX_MUXENTRY(UART1_RTSN, 0, "uart1_rtsn", NULL, "d_can0_rx", "i2c2_scl", "spi1_cs1", NULL, NULL, "gpio0_13"), _AM33XX_MUXENTRY(UART1_RXD, 0, "uart1_rxd", "mmc1_sdwp", "d_can1_tx", "i2c1_sda", NULL, "pr1_uart0_rxd_mux1", NULL, "gpio0_14"), _AM33XX_MUXENTRY(UART1_TXD, 0, "uart1_txd", "mmc2_sdwp", "d_can1_rx", "i2c1_scl", NULL, "pr1_uart0_txd_mux1", NULL, "gpio0_15"), 对board-am335xevm.c文件进行如下修改: 加入 static struct pinmux_config d_can_bbb0_pin_mux[] = [ ["uart1_ctsn.d_can0_tx", OMAP_MUX_MODE2 | AM33XX_PULL_ENBL], ["uart1_rtsn.d_can0_rx", OMAP_MUX_MODE2 | AM33XX_PIN_INPUT_PULLUP], [NULL, 0], ]; static struct pinmux_config d_can_bbb1_pin_mux[] = [ ["uart1_rxd.d_can1_tx", OMAP_MUX_MODE2 | AM33XX_PULL_ENBL], ["uart1_txd.d_can1_rx", OMAP_MUX_MODE2 | AM33XX_PIN_INPUT_PULLUP], [NULL, 0], ]; 在函数static void d_can_init(int evm_id, int profile)中加入 case BEAGLE_BONE_BLACK: /* Instance Zero */ setup_pin_mux(d_can_bbb0_pin_mux); am33xx_d_can_init(0); /* Instance one */ setup_pin_mux(d_can_bbb1_pin_mux); am33xx_d_can_init(1); break; 最后/* Beaglebone Black */ static struct evm_dev_cfg beagleboneblack_dev_cfg[] = [ [am335x_rtc_init, DEV_ON_BASEBOARD, PROFILE_NONE], [clkout2_enable, DEV_ON_BASEBOARD, PROFILE_NONE], [tps65217_init, DEV_ON_BASEBOARD, PROFILE_NONE], [mii1_init, DEV_ON_BASEBOARD, PROFILE_NONE], [u***0_init, DEV_ON_BASEBOARD, PROFILE_NONE], [u***1_init, DEV_ON_BASEBOARD, PROFILE_NONE], [mmc1_emmc_init, DEV_ON_BASEBOARD, PROFILE_NONE], [mmc0_init, DEV_ON_BASEBOARD, PROFILE_NONE], [d_can_init, DEV_ON_BASEBOARD, PROFILE_NONE],// 加入d_can_init函数 /* [i2c2_init, DEV_ON_BASEBOARD, PROFILE_NONE],*/ //删除i2c2的初始化函数 [sgx_init, DEV_ON_BASEBOARD, PROFILE_NONE], [NULL, 0, 0], ]; 按照AM335X DCAN driver guide.pdf 对linux driver的CAN进行了配置,然后编译内核,将内核拷到SD卡中(我用的是SD启动),uboot和filesystem没有变,能正常启动, 问题:但是在/dev目录下找不到can0,can1的驱动,运行canconfig can0 start 提示Cannot find device "can0".查看串口显示记录,在启动过程中出现了boardname:A335BNLT board version : 000B,The board is a AM335x Beaglebone Black..........等等,关于CAN的显示CAN device driver interface, CAN bus driver for Bosch D_CAN controller 1.0,can:controller area network core (rev 20090105 abi 8),can:raw protocol(rev 20090105),can:broadcast manager prorocol (20090105 t)。 PS:目前我只用了BBB,没有CAN扩展板,没有接CAN收发器,如果只看/dev目录下有没有驱动的话 CAN收发器应该可以不接,请教TI的大神帮我 |
7个回答
谢谢你的及时回复,配置过了 按照TI DCAN driver文档上配置过了,是不是D15,16,17,18这几个管脚不能同时用作CAN0,CAN1,你看看我对那两个文件的修改对不对? |
cmh30 发表于 2018-6-21 11:13 从你修改的文件,看不到什么问题。给你个建议,你先配置一个CAN,看看能不能通 |
_AM33XX_MUXENTRY(UART1_CTSN, 0, "uart1_ctsn", NULL, "d_can0_tx", NULL, "spi1_cs0", NULL, NULL, "gpio0_12"), _AM33XX_MUXENTRY(UART1_RTSN, 0, "uart1_rtsn", NULL, "d_can0_rx", NULL, "spi1_cs1", NULL, NULL, "gpio0_13"), _AM33XX_MUXENTRY(UART1_RXD, 0, "uart1_rxd", "mmc1_sdwp", "d_can1_tx", NULL, NULL, "pr1_uart0_rxd_mux1", NULL, "gpio0_14"), _AM33XX_MUXENTRY(UART1_TXD, 0, "uart1_txd", "mmc2_sdwp", "d_can1_rx", NULL, NULL, "pr1_uart0_txd_mux1", NULL, "gpio0_15"), 即将i2c2_scl,i2c1_scl等改为NULL就可以了,貌似和I2C有冲突,再问下有没有关于UART的文档,我在外扩展了串口收发器,但是不知道怎么配置内核?? |
cmh30 发表于 2018-6-21 12:11 6个UART内核已经配置好了,主要是要配置好pinmux。 UART被认为是比较通用的外设,因此在wiki上没有特别的文档。 |
只有小组成员才能发言,加入小组>>
351 浏览 1 评论
545 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
790 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
660 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1140 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
83浏览 29评论
296浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
261浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
210浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
68浏览 13评论
GMT+8, 2024-12-28 04:38 , Processed in 1.071033 second(s), Total 89, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
