电子发烧友论坛扫一扫,分享给好友
我在ccs3.3 上编译自己的库的时候调用了ti提供的fasRTC库 但是在server端编译的时候却报如下的错 不知道是什么问题
undefined first referenced symbol in file --------- ---------------- mpydp(double, double) image.lib divdp(double, double) image.lib >> error: relocation overflow occurred at address 0x000013e0 in section '.text' of input file 'cvhaar.obj (image.lib)'. The 29-bit PC-relative displacement 505150320 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. You may need to add a mask to the assembly instruction or use other target specific assembly features if you really only need the lowest 21 bits of this symbol. Please see the section on Relocation in the Assembly User's Guide. >> error: relocation overflow occurred at address 0x00001414 in section '.text' of input file 'cvhaar.obj (image.lib)'. The 29-bit PC-relative displacement 505150312 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. You may need to add a mask to the assembly instruction or use other target specific assembly features if you really only need the lowest 21 bits of this symbol. Please see the section on Relocation in the Assembly User's Guide. >> error: relocation overflow occurred at address 0x0000149c in section '.text' of input file 'cvhaar.obj (image.lib)'. The 29-bit PC-relative displacement 505150280 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. You may need to add a mask to the assembly instruction or use other target specific assembly features if you really only need the lowest 21 bits of this symbol. Please see the section on Relocation in the Assembly User's Guide. >> error: relocation overflow occurred at address 0x000014dc in section '.text' of input file 'cvhaar.obj (image.lib)'. The 29-bit PC-relative displacement 505150264 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. You may need to add a mask to the assembly instruction or use other target specific assembly features if you really only need the lowest 21 bits of this symbol. Please see the section on Relocation in the Assembly User's Guide. >> error: relocation overflow occurred at address 0x00001c38 in section '.text' of input file 'cvhaar.obj (image.lib)'. The 29-bit PC-relative displacement 505149792 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. You may need to add a mask to the assembly instruction or use other target specific assembly features if you really only need the lowest 21 bits of this symbol. Please see the section on Relocation in the Assembly User's Guide. >> error: relocation overflow occurred at address 0x00001c78 in section '.text' of input file 'cvhaar.obj (image.lib)'. The 29-bit PC-relative displacement 505149776 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. You may need to add a mask to the assembly instruction or use other target specific assembly features if you really only need the lowest 21 bits of this symbol. Please see the section on Relocation in the Assembly User's Guide. >> error: relocation overflow occurred at address 0x00001cc8 in section '.text' of input file 'cvhaar.obj (image.lib)'. The 29-bit PC-relative displacement 505149752 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. You may need to add a mask to the assembly instruction or use other target specific assembly features if you really only need the lowest 21 bits of this symbol. Please see the section on Relocation in the Assembly User's Guide. >> error: relocation overflow occurred at address 0x00001d08 in section '.text' of input file 'cvhaar.obj (image.lib)'. The 29-bit PC-relative displacement 505149736 at this location is too large to fit into the 21-bit PC-Relative field; the destination address is too far away from the instruction. You may need to add a mask to the assembly instruction or use other target specific assembly features if you really only need the lowest 21 bits of this symbol. Please see the section on Relocation in the Assembly User's Guide. |
1个回答
可能是环境没有配置好,提示有未定义的符号链接~
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1756浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1723浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 00:44 , Processed in 0.603637 second(s), Total 73, Slave 56 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2005
