电子发烧友论坛|
Starting kernel ... [ 0.000000] Booting Linux on physical CPU 0x0 [ 0.000000] Linux version 3.14.43-g875c69b (jinda@ubuntu) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #1 Wed Oct 7 22:15:39 PDT 2015 [ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d [ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache [ 0.000000] Machine model: TI AM335x EVM-SK [ 0.000000] cma: CMA: reserved 24 MiB at 8c800000 [ 0.000000] Memory policy: Data cache writeback [ 0.000000] CPU: All CPU(s) started in SVC mode. [ 0.000000] AM335X ES1.0 (sgx neon ) [ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 64768 [ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait [ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes) [ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes) [ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes) [ 0.000000] Memory: 225284K/261120K available (5843K kernel code, 303K rwdata, 2144K rodata, 260K init, 232K bss, 35836K reserved, 0K highmem) [ 0.000000] Virtual kernel memory layout: [ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB) [ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB) [ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB) [ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB) [ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB) [ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB) [ 0.000000] .text : 0xc0008000 - 0xc07d50c4 (7989 kB) [ 0.000000] .init : 0xc07d6000 - 0xc0817144 ( 261 kB) [ 0.000000] .data : 0xc0818000 - 0xc0863da0 ( 304 kB) [ 0.000000] .bss : 0xc0863da0 - 0xc089ddb8 ( 233 kB) [ 0.000000] NR_IRQS:16 nr_irqs:16 16 [ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts [ 0.000000] Total of 128 interrupts on 1 active controller [ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz [ 0.000016] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956969942ns [ 0.000038] OMAP clocksource: timer1 at 24000000 Hz [ 0.000332] Console: colour dummy device 80x30 [ 0.000359] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0' [ 0.000366] This ensures that you still see kernel messages. Please [ 0.000371] update your kernel commandline. [ 0.000395] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144) [ 0.119362] pid_max: default: 32768 minimum: 301 [ 0.119466] Security Framework initialized [ 0.119525] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.119538] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes) [ 0.127611] CPU: Testing write buffer coherency: ok [ 0.128024] Setting up static identity map for 0x805baa20 - 0x805baa78 [ 0.129054] devtmpfs: initialized [ 0.131085] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3 [ 0.138977] omap_hwmod: tptc0 using broken dt data from edma [ 0.139066] omap_hwmod: tptc1 using broken dt data from edma [ 0.139146] omap_hwmod: tptc2 using broken dt data from edma [ 0.143532] omap_hwmod: debugss: _wait_target_disable failed [ 0.199500] pinctrl core: initialized pinctrl subsystem [ 0.200604] regulator-dummy: no parameters [ 0.203076] NET: Registered protocol family 16 [ 0.205231] DMA: preallocated 256 KiB pool for atomic coherent allocations [ 0.207985] cpuidle: using governor ladder [ 0.208003] cpuidle: using governor menu [ 0.215026] syscon 44e10000.control_module: regmap [mem 0x44e10000-0x44e107fb] registered [ 0.216601] platform 49000000.edma: alias fck already exists [ 0.216626] platform 49000000.edma: alias fck already exists [ 0.216642] platform 49000000.edma: alias fck already exists [ 0.217862] OMAP GPIO hardware version 0.1 [ 0.233370] No ATAGs? [ 0.233397] hw-breakpoint: debug architecture 0x4 unsupported. [ 0.262263] bio: create slab [ 0.279779] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver [ 0.280877] vbat: 5000 mV [ 0.281304] lis3_reg: no parameters [ 0.281416] reg-fixed-voltage fixedregulator@2: could not find pctldev for node /pinmux@44e10800/pinmux_wl12xx_gpio, deferring probe [ 0.281442] platform fixedregulator@2: Driver reg-fixed-voltage requests probe deferral [ 0.281919] vtt: 1500 mV [ 0.285321] vgaarb: loaded [ 0.285892] i2c-core: driver [palmas] using legacy suspend method [ 0.285902] i2c-core: driver [palmas] using legacy resume method [ 0.286686] SCSI subsystem initialized [ 0.288284] u***core: registered new interface driver u***fs [ 0.288482] u***core: registered new interface driver hub [ 0.288704] u***core: registered new device driver u*** [ 0.289816] omap_i2c 44e0b000.i2c: could not find pctldev for node /pinmux@44e10800/pinmux_i2c0_pins, deferring probe [ 0.289849] platform 44e0b000.i2c: Driver omap_i2c requests probe deferral [ 0.290290] pps_core: LinuxPPS API ver. 1 registered [ 0.290301] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti [ 0.290438] PTP clock support registered [ 0.292553] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400 [ 0.293520] Advanced Linux Sound Architecture Driver Initialized. [ 0.295265] Switched to clocksource timer1 [ 0.316584] NET: Registered protocol family 2 [ 0.317501] TCP established hash table entries: 2048 (order: 1, 8192 bytes) [ 0.317539] TCP bind hash table entries: 2048 (order: 1, 8192 bytes) [ 0.317570] TCP: Hash tables configured (established 2048 bind 2048) [ 0.317639] TCP: reno registered [ 0.317653] UDP hash table entries: 256 (order: 0, 4096 bytes) [ 0.317673] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes) [ 0.317857] NET: Registered protocol family 1 [ 0.318281] RPC: Registered named UNIX socket transport module. [ 0.318294] RPC: Registered udp transport module. [ 0.318301] RPC: Registered tcp transport module. [ 0.318308] RPC: Registered tcp NFSv4.1 backchannel transport module. [ 0.319458] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available [ 0.322391] futex hash table entries: 256 (order: -1, 3072 bytes) [ 0.508776] VFS: Disk quotas dquot_6.5.2 [ 0.508849] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes) [ 0.509409] NFS: Registering the id_resolver key type [ 0.509489] Key type id_resolver registered [ 0.509498] Key type id_legacy registered [ 0.509540] jffs2: version 2.2. (NAND) (SUMMARY) 漏 2001-2006 Red Hat, Inc. [ 0.509733] msgmni has been set to 488 [ 0.511298] NET: Registered protocol family 38 [ 0.511343] io scheduler noop registered [ 0.511351] io scheduler deadline registered [ 0.511374] io scheduler cfq registered (default) [ 0.513296] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568 [ 0.517558] backlight supply power not found, using dummy regulator [ 0.521556] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled [ 0.527394] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 88, base_baud = 3000000) is a 8250 [ 1.181231] console [ttyS0] enabled [ 1.186787] omap_rng 48310000.rng: OMAP Random Number Generator ver. 20 [ 1.193844] [drm] Initialized drm 1.1.0 20060810 [ 1.210251] brd: module loaded [ 1.219455] loop: module loaded [ 1.223036] (hci_tty): inside hci_tty_init [ 1.227736] (hci_tty): allocated 250, 0 [ 1.236209] mtdoops: mtd device (mtddev=name/number) must be supplied [ 1.246909] u***core: registered new interface driver asix [ 1.252572] u***core: registered new interface driver ax88179_178a [ 1.258898] u***core: registered new interface driver cdc_ether [ 1.264986] u***core: registered new interface driver smsc95xx [ 1.270934] u***core: registered new interface driver net1080 [ 1.276818] u***core: registered new interface driver cdc_subset [ 1.282952] u***core: registered new interface driver zaurus [ 1.288785] u***core: registered new interface driver cdc_ncm [ 1.295054] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver [ 1.301649] ehci-pci: EHCI PCI platform driver [ 1.306342] ehci-omap: OMAP-EHCI Host Controller driver [ 1.312100] u***core: registered new interface driver cdc_wdm [ 1.318039] u***core: registered new interface driver u***-storage [ 1.325207] mousedev: PS/2 mouse device common for all mice [ 1.332703] input: ti-tsc as /devices/ocp/44e0d000.tscadc/TI-am335x-tsc/input/input0 [ 1.342052] i2c-core: driver [rtc-ds1307] using legacy suspend method [ 1.348570] i2c-core: driver [rtc-ds1307] using legacy resume method [ 1.355841] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0 [ 1.362959] 44e3e000.rtc: already running [ 1.367913] i2c /dev entries driver [ 1.371608] Driver for 1-wire Dallas network protocol. [ 1.379482] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec [ 1.388579] omap_hsmmc 48060000.mmc: unable to get vmmc regulator -517 [ 1.395441] platform 48060000.mmc: Driver omap_hsmmc requests probe deferral [ 1.402873] omap_hsmmc 481d8000.mmc: unable to get vmmc regulator -517 [ 1.409544] platform 481d8000.mmc: Driver omap_hsmmc requests probe deferral [ 1.418988] ledtrig-cpu: registered to indicate activity on CPUs [ 1.425453] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2 [ 1.432601] omap-sham 53100000.sham: hw accel on OMAP rev 4.3 [ 1.440079] u***core: registered new interface driver u***hid [ 1.445716] u***hid: USB HID core driver [ 1.449874] platform 44d00000.wkup_m3: Driver wkup_m3 requests probe deferral [ 1.460500] oprofile: using arm/armv7 [ 1.464512] TCP: cubic registered [ 1.467907] Initializing XFRM netlink socket [ 1.472291] NET: Registered protocol family 17 [ 1.476847] NET: Registered protocol family 15 [ 1.481428] Key type dns_resolver registered [ 1.486504] cpu cpu0: of_pm_voltdm_notifier_register: Failed to get cpu0 regulator/voltdm: -517 [ 1.495252] cpu cpu0: cpu0 clock notifier not ready, retry [ 1.500909] platform cpufreq-cpu0.0: Driver cpufreq-cpu0 requests probe deferral [ 1.509064] PM: bootloader does not support rtc-only! [ 1.514152] ThumbEE CPU extension supported. [ 1.518590] Registering SWP/SWPB emulation handler [ 1.525101] lis3_reg: disabling [ 1.528389] vbat: disabling [ 1.531197] regulator-dummy: disabling [ 1.535744] Error: Driver 'tfp410' is already registered, aborting... [ 1.544791] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013). [ 1.551505] [drm] No driver support for vblank timestamp query. [ 1.607805] Console: switching to colour frame buffer device 60x34 [ 1.616405] tilcdc 4830e000.lcdc: fb0: frame buffer device [ 1.622004] tilcdc 4830e000.lcdc: registered panic notifier [ 1.627635] [drm] Initialized tilcdc 1.0.0 20121205 on minor 0 [ 1.634758] vwl1271: 1800 mV [ 1.639912] tps65910 0-002d: No interrupt support, no core IRQ [ 1.650406] vrtc: 1800 mV [ 1.653424] vrtc: supplied by vbat [ 1.658663] vio: at 1500 mV [ 1.661645] vio: supplied by vbat [ 1.666874] vdd_mpu: 912 <--> 1375 mV at 1137 mV [ 1.671677] vdd_mpu: supplied by vbat [ 1.677240] vdd_core: 912 <--> 1150 mV at 1137 mV [ 1.682144] vdd_core: supplied by vbat [ 1.687339] vdd3: 5000 mV [ 1.691471] vdig1: at 1800 mV [ 1.694626] vdig1: supplied by vbat [ 1.699589] vdig2: at 1800 mV [ 1.702729] vdig2: supplied by vbat [ 1.707682] vpll: at 1800 mV [ 1.710742] vpll: supplied by vbat [ 1.715631] vdac: at 1800 mV [ 1.718694] vdac: supplied by vbat [ 1.723503] vaux1: at 1800 mV [ 1.726683] vaux1: supplied by vbat [ 1.731631] vaux2: at 3300 mV [ 1.734786] vaux2: supplied by vbat [ 1.739740] vaux33: at 3300 mV [ 1.742970] vaux33: supplied by vbat [ 1.747969] vmmc: 1800 <--> 3300 mV at 3300 mV [ 1.752593] vmmc: supplied by vbat [ 1.757973] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz [ 1.882584] mmc0: host does not support reading read-only switch. assuming write-enable. [ 1.892897] mmc0: new high speed SDHC card at address aaaa [ 1.899087] mmcblk0: mmc0:aaaa SU04G 3.69 GiB [ 1.905217] mmcblk0: p1 p2 p3 [ 1.926058] remoteproc0: wkup_m3 is available [ 1.930537] remoteproc0: Note: remoteproc is still under development and considered experimental. [ 1.939588] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed. [ 1.950212] remoteproc0: Direct firmware load failed with error -2 [ 1.956588] remoteproc0: Falling back to user helper [ 1.962184] cpu cpu0: of_pm_voltdm_notifier_register: Fail calculating voltage latency[1100000<->1260000]:-22 [ 1.977619] omap_hsmmc 481d8000.mmc: card claims to support voltages below defined range [ 2.009895] mmc1: queuing unknown CIS tuple 0x91 (3 bytes) [ 2.016212] mmc1: new SDIO card at address 0001 [ 2.045428] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6 [ 2.051570] davinci_mdio 4a101000.mdio: detected phy mask fffffffc [ 2.059280] libphy: 4a101000.mdio: probed [ 2.063324] davinci_mdio 4a101000.mdio: phy[0]: device 4a101000.mdio:00, driver Atheros 8031 ethernet [ 2.072637] davinci_mdio 4a101000.mdio: phy[1]: device 4a101000.mdio:01, driver Atheros 8031 ethernet [ 2.082862] cpsw 4a100000.ethernet: Detected MACID = 00:18:31:e7:9f:ed [ 2.090832] cpsw 4a100000.ethernet: cpsw: Detected MACID = 00:18:31:e7:9f:ee [ 2.100444] input: gpio_buttons@0 as /devices/gpio_buttons@0/input/input1 [ 2.108158] omap_rtc 44e3e000.rtc: setting system clock to 2012-07-27 12:05:11 UTC (1343390711) [ 2.120246] ALSA device list: [ 2.123252] No soundcards found. [ 2.130080] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem [ 2.137511] EXT4-fs (mmcblk0p2): write access will be enabled during recovery [ 2.356736] EXT4-fs (mmcblk0p2): recovery complete [ 2.364058] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null) [ 2.372370] VFS: Mounted root (ext4 filesystem) readonly on device 179:2. [ 2.383054] devtmpfs: mounted [ 2.386896] Freeing unused kernel memory: 260K (c07d6000 - c0817000) INIT: version 2.86 booting Please wait: booting... Starting udev [ 3.554933] 47401300.u***-phy supply vcc not found, using dummy regulator [ 3.727479] 47401b00.u***-phy supply vcc not found, using dummy regulator [ 3.856633] lis3lv02d: 16 bits lis331dlh sensor found [ 4.025792] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input2 [ 4.237272] davinci_evm sound: tlv320aic3x-hifi <-> 4803c000.mcasp mapping ok [ 4.769880] mu***-hdrc mu***-hdrc.0.auto: MUSB HDRC host driver [ 4.841426] mu***-hdrc mu***-hdrc.0.auto: new USB bus registered, assigned bus number 1 [ 4.854693] u*** u***1: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.861625] u*** u***1: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.868906] u*** u***1: Product: MUSB HDRC host driver [ 4.873907] u*** u***1: Manufacturer: Linux 3.14.43-g875c69b mu***-hcd [ 4.880216] u*** u***1: SerialNumber: mu***-hdrc.0.auto [ 4.887323] hub 1-0:1.0: USB hub found [ 4.891174] hub 1-0:1.0: 1 port detected [ 4.900763] mu***-hdrc mu***-hdrc.1.auto: MUSB HDRC host driver [ 4.907277] mu***-hdrc mu***-hdrc.1.auto: new USB bus registered, assigned bus number 2 [ 4.915424] u*** u***2: New USB device found, idVendor=1d6b, idProduct=0002 [ 4.922248] u*** u***2: New USB device strings: Mfr=3, Product=2, SerialNumber=1 [ 4.929531] u*** u***2: Product: MUSB HDRC host driver [ 4.934519] u*** u***2: Manufacturer: Linux 3.14.43-g875c69b mu***-hcd [ 4.940834] u*** u***2: SerialNumber: mu***-hdrc.1.auto [ 4.947815] hub 2-0:1.0: USB hub found [ 4.951635] hub 2-0:1.0: 1 port detected [ 5.066593] alignment: ignoring faults is unsafe on this CPU. Defaulting to fixup mode. Remounting root file system... [ 5.130899] EXT4-fs (mmcblk0p2): warning: mounting fs with errors, running e2fsck is recommended [ 5.141551] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null) Caching udev devnodes logger: mount: mount point /proc/bus/u*** does not exist ALSA: Restoring mixer settings... No state is present for card AM335xEVMSK Configuring network interfaces... Found hardware: "AM335x-EVMSK" "" "" "" "" Hardware is initialized using a generic method No state is present for card AM335xEVMSK [ 6.880702] net eth0: initializing cpsw version 1.12 (0) [ 6.966079] net eth0: phy found : id is : 0x4dd074 eth0 no wireless extensions. udhcpc (v1.13.2) started Sending discover... [ 8.749293] random: nonblocking pool is initialized [ 9.966097] libphy: 4a101000.mdio:00 - Link is Up - 100/Full Sending discover... Sending discover... No lease, forking to background done. Setting up IP spoofing protection: rp_filter. INIT: Entering runlevel: 5 Starting system message bus: dbus. Starting Hardware abstraction layer hald Starting Dropbear SSH server: dropbear. Starting telnet daemon. Starting network benchmark server: netserver. Starting syslogd/klogd: done Starting thttpd. [ 18.424131] Unhandled fault: external abort on non-linefetch (0x1018) at 0xb6ff344c Bus error No SGX hardware, not starting PVR Starting Lighttpd Web Server: lighttpd. 2012-07-27 12:05:27: (log.c.166) server started [ 18.679202] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 18.953668] kjournald starting. Commit interval 5 seconds [ 18.961893] EXT3-fs (mmcblk0p3): using internal journal [ 18.967477] EXT3-fs (mmcblk0p3): recovery complete [ 18.972313] EXT3-fs (mmcblk0p3): mounted filesystem with ordered data mode / Starting Matrix GUI application. [ 19.528866] Number of LUNs=8 [ 19.531908] Mass Storage Function, version: 2009/09/11 [ 19.539103] LUN: removable file: (no medium) [ 19.543898] Number of LUNs=2 [ 19.547869] LUN: file: /dev/mmcblk0p1 [ 19.552454] LUN: file: /dev/mmcblk0p3 [ 19.556277] Number of LUNs=2 [ 19.561392] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11 [ 19.568527] g_mass_storage gadget: userspace failed to provide iSerialNumber [ 19.575684] g_mass_storage gadget: g_mass_storage ready [ 19.584675] mu***-hdrc mu***-hdrc.0.auto: otg: u***_otg_register_gadget: device not registered to otg core [ 19.916399] g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage *************************************************************** *************************************************************** NOTICE: This file system contains the followin GPLv3 packages: binutils-symlinks binutils gdbserver If you do not wish to distribute GPLv3 components please remove the above packages prior to distribution. This can be done using the opkg remove command. i.e.: opkg remove Where NOTE: If the package is a dependency of another package you will be notified of the dependent packages. You should use the --force-removal-of-dependent-packages option to also remove the dependent packages as well *************************************************************** *************************************************************** [ 62.085784] remoteproc0: failed to load am335x-pm-firmware.elf [ 62.091837] remoteproc0: powering up wkup_m3 [ 62.102178] remoteproc0: Direct firmware load failed with error -2 [ 62.108649] remoteproc0: Falling back to user helper [ 62.139045] remoteproc0: request_firmware failed: -2 [ 62.144230] wkup_m3 44d00000.wkup_m3: rproc_boot failed INIT: Id "S" respawning too fast: disabled for 5 minutes 1.请大家帮忙看看 是哪的问题 就是 进不了输入界面,是 EXT3 EXT4 不兼容的问题吗,还是什么问题 ,刚开始学习,很多不知道,希望大家帮助帮助。 2.ti-processor-sdk-linux-335x-evm-01.00.00.03/filesystem/tisdk-rootfs-image-am335x-evm.tar.gz 这个文件系统怎么用啊 我在官网资料上也没找到制作过程,望大家给点帮助 谢谢了!! |
2个回答
你用的是原版的文件系统吗?怎么提示信息说,有一些固件都没有了.
那个文件爱你系统,你使用tar zxvf tisdk-rootfs-image-am335x-evm.tar.gz 解压出来,再把这个文件系统里面的所有东西都拷到SD卡的第二个分区就行了. |
hwjj940056201 发表于 2018-6-4 04:21 首先,感谢您的解答,通过您的方法没什么问题了,我现在要做声卡的部分,我用的是 tisdk_am335x-evm_defconfig 默认的配置, 因为刚接触内核,很多都不懂,我想问下如果是默认的配置,声卡驱动放在哪里啊,是哪个文件,还有就是有关声卡硬件的配置,在哪个文件里做的,可能我问的不够专业,麻烦您再帮帮忙,先谢谢了! |
只有小组成员才能发言,加入小组>>
549 浏览 0 评论
1613 浏览 0 评论
2047 浏览 0 评论
为啥BQ7693003DBTR芯片在和BQ769X0盒子通讯时收不到信号?
1513 浏览 0 评论
DSP 28027F 开发板 XDS100v2调试探针诊断日志显示了 Error -150 (SC_ERR_FTDI_FAIL)如何解决
1337 浏览 0 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
1757浏览 29评论
2781浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
1724浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
1634浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
1645浏览 13评论
/9
GMT+8, 2025-12-2 08:23 , Processed in 0.502192 second(s), Total 45, Slave 38 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2738
