扫一扫,分享给好友
1. mii 模式接入2路phy lan8710,phy地址phy1 为0 ,phy2为1,dual mac模式;
2.2路ip配置分别为192.168.0.8 192.168.1.8; 3.当2路都接入交换机时不停的up down; [ 4082.624549] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready root@ARM:/lib# [ 4084.602947] phy->addr = 1,slave_port = 2phy->addr = 1,slave_port = 2 [ 4085.616926] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Half - flow control off [ 4085.649686] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready [ 4087.183188] phy->addr = 0,slave_port = 1phy->addr = 1,slave_port = 2 [ 4087.665679] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 4089.222960] phy->addr = 0,slave_port = 1 [ 4089.226767] cpsw 4a100000.ethernet eth0: Link is Down [ 4089.713149] phy->addr = 1,slave_port = 2phy->addr = 0,slave_port = 1 [ 4090.225759] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx [ 4091.762943] phy->addr = 1,slave_port = 2 [ 4091.766751] cpsw 4a100000.ethernet eth1: Link is Down [ 4092.293187] phy->addr = 0,slave_port = 1phy->addr = 1,slave_port = 2 [ 4092.785896] cpsw 4a100000.ethernet eth1: Link is Up - 100Mbps/Full - flow control rx/tx [ 4095.332954] phy->addr = 0,slave_port = 1 [ 4095.336761] cpsw 4a100000.ethernet eth0: Link is Down [ 4095.833229] phy->addr = 1,slave_port = 2phy->addr = 0,slave_port = 1 [ 4096.335757] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow con trol rx/tx 4 down掉eth1 开始恢复正常,也能ping通; root@arm:/lib# ping 192.168.0.1 PING 192.168.0.1 (192.168.0.1) 56(84) bytes of data. 64 bytes from 192.168.0.1: icmp_seq=1 ttl=128 time=0.419 ms 64 bytes from 192.168.0.1: icmp_seq=2 ttl=128 time=0.442 ms 64 bytes from 192.168.0.1: icmp_seq=3 ttl=128 time=0.427 ms 64 bytes from 192.168.0.1: icmp_seq=4 ttl=128 time=0.417 ms 64 bytes from 192.168.0.1: icmp_seq=5 ttl=128 time=0.392 ms 64 bytes from 192.168.0.1: icmp_seq=6 ttl=128 time=0.416 ms 5 比较奇怪的是我把这一路网口的ip改到192.168.1.8,竟然能ping竟然还是能ping通 同样的现象在eth1上也一样; 感觉像是交换层面的问题,请ti的专家们指导一下; |
5个回答
344868615qq 发表于 2018-6-1 02:08 Jian Zhou ,这些东西怎么配置编译条件,我看不懂,或者哪个app的源码,谢谢 |
这个是在文件系统的/etc目录下的init脚本里配置的。 |
已解决,将芯片从lan8710->lan8720 ,接口从mii->rmii方式,不再出现不停up down的情况,也不会一个逻辑网口ping通2个物理网口的情况; |
ally4462 发表于 2018-6-1 02:54 您好,我在调lan8720。我遇到的问题是100M下有30%的丢包率,10M下有5%的丢包率。能否交流一下。QQ862049719 |
只有小组成员才能发言,加入小组>>
309 浏览 1 评论
513 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
754 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
641 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1113 浏览 1 评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
226浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
181浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
46浏览 13评论
在使用3254进行录音的时候出现一个奇怪的现象,右声道有吱吱声,请教一下,是否是什么寄存器设置存在问题?
149浏览 13评论
TLV320芯片内部自带数字滤波功能,请问linein进来的模拟信号是否是先经过ADC的超采样?
158浏览 12评论
GMT+8, 2024-12-18 20:46 , Processed in 0.864761 second(s), Total 58, Slave 51 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
