扫一扫,分享给好友
基于ti官方的SDK8.0 ,安装网上教程,把GPU编译到内核里了,直接测试GPU,跑官方的例子,是可以的。
/opt/gfxsdkdemos/ogles2/ ./OGLES2ChameleonMan 是没有问题的,编译的是QT5.5 配置好了GPU路径,也没报错,编译好后,库放到文件系统下 /OPT下 加入qt_env.sh 脚本 export QTDIR=/opt/qt5.5_lib export QT_QPA_FONTDIR=$QTDIR/lib/fonts export QT_QPA_PLATFORM_PLUGIN_PATH=$QTDIR/plugins/platforms export LD_LIBRARY_PATH=$QTDIR/lib:$LD_LIBRARY_PATH export QT_QPA_DEFAULT_PLATFORM=eglgs export QT_QPA_EGLFS_WIDTH=800 export QT_QPA_EGLFS_HEIGHT=480 export QT_QPA_EGLFS_FB=/dev/fb0 脚本放在/etc/profile.d 下 修改 etc/powervr.ini WindowSystem=libpvrQWSWSEGL.so DisableHWTQTextureUpload=1 运行程序: root@am335x-evm:/usr/qt# ./7Sonar QML debugging is enabled. Only use this in a safe environment. This application failed to start because it could not find or load the Qt platform plugin "xcb" in "/opt/qt5.5_lib/plugins/platforms". Available platform plugins are: directfbegl (from /opt/qt5.5_lib/plugins/platforms), directfb (from /opt/qt5.5_lib/plugins/platforms), eglfs (from /opt/qt5.5_lib/plugins/platforms), linuxfb (from /opt/qt5.5_lib/plugins/platforms), minimal (from /opt/qt5.5_lib/plugins/platforms), minimalegl (from /opt/qt5.5_lib/plugins/platforms), offscreen (from /opt/qt5.5_lib/plugins/platforms), eglfs, linuxfb, minimal, minimalegl, offscreen. 加入 -platform eglfs 选项 root@am335x-evm:/usr/qt# ./7Sonar -platform eglfs QML debugging is enabled. Only use this in a safe environment. This application failed to start because it could not find or load the Qt platform plugin "eglfs" in "/opt/qt5.5_lib/plugins/platforms". Available platform plugins are: directfbegl (from /opt/qt5.5_lib/plugins/platforms), directfb (from /opt/qt5.5_lib/plugins/platforms), eglfs (from /opt/qt5.5_lib/plugins/platforms), linuxfb (from /opt/qt5.5_lib/plugins/platforms), minimal (from /opt/qt5.5_lib/plugins/platforms), minimalegl (from /opt/qt5.5_lib/plugins/platforms), offscreen (from /opt/qt5.5_lib/plugins/platforms), eglfs, linuxfb, minimal, minimalegl, offscreen. Reinstalling the application may fix this problem. Aborted 还是错误!!求指点下,,头大了 ?哪里的问题,QT库,还是系统的问题。 |
7个回答
不行呀,,我开始就用的最新版,,然后发现QT 库,少了quick controls 等一堆的控件!完全用不了呀!!!要不没编译,要不就是删掉了,不给用。。白折腾了1一个来月。。。。。 也没有个最新SDK的QT教程,不行我自己编译呀。。。。哎。。。。 |
huzp_123 发表于 2018-5-15 11:36 我的理解控件应该是应用层的东西,如果少了控件,你通过应用层加进去应该更快。 如果我的回答解决了您的问题,请确认答案,谢谢!:) |
是QT的控件库,但要编译这个库,需要GPU的相关的头文件,库等路径等等 ,在新版本的SDK里,不在提供GPU相关的GDK了,,所以没法编译支持opengl es2 的QT了 只能用老版本来。。 |
huzp_123 发表于 2018-5-15 12:09 偏应用的东西,我们接触较少,您可以列下具体的控件库的名字,已经需要的GPU的头文件吗? 我会内部查下。 谢谢! 如果我的回答解决了您的问题,请确认答案,谢谢!:) |
万分感谢,主要是QTQUICK那里的库,你可以看下图片,这个是TI官方的QT5库 这个是正常下编译的QT5的库 像什么Controls Layouts 都没有的 。 GDK以前是和SDK一起打包配套的,我只要把GDK的路径给QT就可以了。具体用了哪些也不太清楚的,据说GDK和SDK是配套的,不能混用。 |
http://blog.sina.com.cn/s/blog_70bb32080101ripy.html 参考这个帖子,总算搞定了,谢谢关注! |
只有小组成员才能发言,加入小组>>
340 浏览 1 评论
533 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
777 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
653 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1132 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
63浏览 29评论
164浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
253浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
203浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
60浏览 13评论
GMT+8, 2024-12-24 02:03 , Processed in 0.977563 second(s), Total 90, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
