扫一扫,分享给好友
在内核里面是否有使能NAND的配置吗?最简单的办法看你的pinmux配了没有?
在device tree里面配了,用的是am335x-evm.dts官方默认已经配了 nandflash_pins_default: nandflash_pins_default [ pinctrl-single,pins = < 0x0 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad0.gpmc_ad0 */ 0x4 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad1.gpmc_ad1 */ 0x8 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad2.gpmc_ad2 */ 0xc (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad3.gpmc_ad3 */ 0x10 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad4.gpmc_ad4 */ 0x14 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad5.gpmc_ad5 */ 0x18 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad6.gpmc_ad6 */ 0x1c (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_ad7.gpmc_ad7 */ 0x70 (PIN_INPUT_PULLUP | MUX_MODE0) /* gpmc_wait0.gpmc_wait0 */ 0x74 (PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_wpn.gpio0_30 */ 0x7c (PIN_OUTPUT | MUX_MODE0) /* gpmc_csn0.gpmc_csn0 */ 0x90 (PIN_OUTPUT | MUX_MODE0) /* gpmc_advn_ale.gpmc_advn_ale */ 0x94 (PIN_OUTPUT | MUX_MODE0) /* gpmc_oen_ren.gpmc_oen_ren */ 0x98 (PIN_OUTPUT | MUX_MODE0) /* gpmc_wen.gpmc_wen */ 0x9c (PIN_OUTPUT | MUX_MODE0) /* gpmc_be0n_cle.gpmc_be0n_cle */ >; ]; nandflash_pins_sleep: nandflash_pins_sleep [ pinctrl-single,pins = < 0x0 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x4 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x8 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0xc (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x10 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x14 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x18 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x1c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x70 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x74 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x7c (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x90 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x94 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x98 (PIN_INPUT_PULLDOWN | MUX_MODE7) 0x9c (PIN_INPUT_PULLDOWN | MUX_MODE7) >; ]; |
60user197 发表于 2018-5-15 00:43 内核没有读到flash ID,nand分区表有没有打印出来呢 |
有没有读到id没去print测试,但没有打印分区信息 |
nand的id读出来是错的mac_id = ff dev_id = ff |
搞定了,不过还是谢谢你的回答。是时序不对,在device tree配一下时序就好了, |
搞定了,不过还是谢谢你的回答。是时序不对,在device tree配一下时序就好了 |
您好,我也遇到这种情况,请问,你是怎么解决的? |
你好,我也遇到相同狀況,最後也是修改了device tree就解決了,以下關於dts內容,參考看看 nand-bus-width = <8>; gpmc,device-width = <2>; 這兩個設定可能滿關鍵的,我沒去深究原因,但試了各種組合(8,1) (16,1) (8,2) (16,2) 另外時序部分,因為u-boot抓得到,所以我在u-boot中把GPMC_CONFIG1~7(register) 的值印出來, 對照datasheet和ti-gpmc.txt,修改dts中gpmc時序的那些數字 嘗試的過程中,訊息會從只有 "No NAND Device found" 慢慢增多, 最後我使用了 nand-bus-width = <8>; gpmc,device-width = <2>; 並且時序全部乘以2,才在Linux中完整抓到NAND,希望不是歪打正著~~ |
只有小组成员才能发言,加入小组>>
341 浏览 1 评论
539 浏览 2 评论
NA555DR VCC最低电压需要在5V供电,为什么用3.3V供电搭了个单稳态触发器也使用正常?
781 浏览 3 评论
MSP430F249TPMR出现高温存储后失效了的情况,怎么解决?
655 浏览 1 评论
对于多级放大电路板,在PCB布局中,电源摆放的位置应该注意什么?
1138 浏览 1 评论
AT32F407在USART2 DMA发送数据时,接包接到了要发送的数据,程序还是处于等待传输完成的标识判断中,为什么?
69浏览 29评论
193浏览 23评论
请问下tpa3220实际测试引脚功能和官方资料不符,哪位大佬可以帮忙解答下
256浏览 20评论
请教下关于TAS5825PEVM评估模块原理图中不太明白的地方,寻求答疑
205浏览 14评论
两个TMP117传感器一个可以正常读取温度值,一个读取的值一直是0,为什么?
63浏览 13评论
GMT+8, 2024-12-24 19:30 , Processed in 1.110040 second(s), Total 95, Slave 79 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
