现阶段使用STM32,基本处于模仿阶段,用野火的教程以及程序,修改一些IO口,然后烧到自己的开发板上,实现一些功能。 第二个实验室了解pwm波这个东西,脉宽调制,调节占空比可以改变电机转速,原理可以看刘洋老师的基础视频,讲的很详细。 修改野火的pwm程序,野火用了四个通道,我只用了tiM4的第一通道,程序如下:
[cpp] view plain copy
- #include "pwm_output.h"
- void pwm_value(void)
- TIM4->CCR1=1300;
- * 函数名:TIM3_GPIO_Config
- * 描述 :配置TIM3复用输出PWM时用到的I/O
- * 输入 :无
- * 输出 :无
- * 调用 :内部调用
- static void TIM4_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- /* TIM4 clock enable */
- //PCLK1经过2倍频后作为TIM3的时钟源等于72MHz
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
- /*GPIOB clock enable */
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; // 复用推挽输出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- // 复位定时器。
- TIM_DeInit(TIM4);
- * 函数名:TIM4_Mode_Config
- * 描述 :配置TIM3输出的PWM信号的模式,如周期、极性、占空比
- * 输入 :无
- * 输出 :无
- * 调用 :内部调用
- static void TIM4_Mode_Config(void)
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- /* PWM信号电平跳变值 */
- u16 CCR1_Val =990;
- // u16 CCR2_Val = 375;
- // u16 CCR3_Val = 250;
- // u16 CCR4_Val = 125;
- TIM3 Configuration: generate 4 PWM signals with 4 different duty cycles:
- TIM3CLK = 72 MHz, Prescaler = 0x0, TIM3 counter clock = 72 MHz
- TIM3 ARR Register = 999 => TIM3 Frequency = TIM3 counter clock/(ARR + 1)
- TIM3 Frequency = 72 KHz.
- TIM3 Channel1 duty cycle = (TIM3_CCR1/ TIM3_ARR)* 100 = 50%
- TIM3 Channel2 duty cycle = (TIM3_CCR2/ TIM3_ARR)* 100 = 37.5%
- TIM3 Channel3 duty cycle = (TIM3_CCR3/ TIM3_ARR)* 100 = 25%
- TIM3 Channel4 duty cycle = (TIM3_CCR4/ TIM3_ARR)* 100 = 12.5%
- /* Time base configuration */
- TIM_TimeBaseStructure.TIM_Period = 3999; //当定时器从0计数到999,即为1000次,为一个定时周期
- TIM_TimeBaseStructure.TIM_Prescaler = 71; //设置预分频:不预分频,即为72MHz
- TIM_TimeBaseStructure.TIM_ClockDivision = 0 ; //设置时钟分频系数:不分频
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //向上计数模式
- TIM_ARRPreloadConfig(TIM4, ENABLE); // 使能TIM4重载寄存器ARR
- TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
- TIM_OCStructInit(&TIM_OCInitStructure);
- /* PWM1 Mode configuration: Channel1 */
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //配置为PWM模式1
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_Pulse = CCR1_Val; //设置跳变值,当计数器计数到这个值时,电平发生跳变
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //当定时器计数值小于CCR1_Val时为高电平
- TIM_OC1Init(TIM4, &TIM_OCInitStructure); //使能通道1
- TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
- /* TIM3 enable counter */
- TIM_Cmd(TIM4, ENABLE); //使能定时器3
- * 函数名:TIM3_PWM_Init
- * 描述 :TIM3 输出PWM信号初始化,只要调用这个函数
- * TIM3的四个通道就会有PWM信号输出
- * 输入 :无
- * 输出 :无
- * 调用 :外部调用
- void TIM4_PWM_Init(void)
- TIM4_GPIO_Config();
- TIM4_Mode_Config();
- /******************* (C) COPYRIGHT 2012 WildFire Team *****END OF FILE************/
当然,野火用的是TIM3,我用的是TIM4
主函数:
[html] view plain copy
- #include "stm32f10x.h"
- * 函数名:main
- * 描述 :主函数
- * 输入 :无
- * 输出 :无
- int main(void)
- while (1)
这个程序编译的时候没出现问题,软件仿真的时候也能出现pwm波,下载到开发板上也成功了,但是电机就是不转,百思不得其解。
找学长看了一下,加了个延时函数,就成功了,说是电调初始化需要点时间,然后主函数改成了:
- * 函数名:main
- * 描述 :主函数
- * 输入 :无
- * 输出 :无
- int main(void)
- int i, j;
- /* TIM3 PWM波输出初始化,并使能TIM3 PWM输出 */
- TIM4_PWM_Init();
- for( i=0;i<20000;i++)
- for ( j=0;j<1000;j++)
- pwm_value();
- while (1)
还是挺简单的嘛。
