电子发烧友论坛
天终于有时间继续调试,可是在调试过程中添加运行代码时出现问题,希望哪位高人指点一下,谢谢。先上代码。 #! /usr/bin/env python # -*- coding: utf-8 -*- import time import datetime import threading import binascii import platform import logging import SerialDeal import serialMainUI if platform.system() == "Windows": from serial.tools import list_ports elif platform.system() == "Linux": import glob, os, re import wx import wx.xrc logging.basicConfig(level=logging.DEBUG, format='%(asctime)s %(filename)s[line:%(lineno)d] %(levelname)s %(message)s', datefmt='%a, %d %b %Y %H:%M:%S') class MainSerialUI(serialMainUI.serialFrame): def __init__(self, master=None): super(MainSerialUI, self).__init__() self.ser = None self.receive_count = 0 self.receive_data = "" self.list_box_serial = None def __del__(self): if platform.system() == "Linux": try: self.ser.SetStopEvent() except: pass def m_openserOnButtonClick( self, event ): try: self.port = self.m_comset.GetValue() self.baudrate = self.m_comboBox2.GetValue() self.parity = self.m_comboBox3.GetValue() self.databit = self.m_comboBox4.GetValue() self.stopbit = self.m_comboBox5.GetValue() self.ser = SerialDeal.serDeal(Port=self.port, BaudRate=self.baudrate, ByteSize=self.databit, Parity=self.parity, Stopbits=self.stopbit) self.ser.open() if self.ser.alive: self.thread_read = threading.Thread(target=self.SerRead) self.thread_read.setDaemon(True) self.thread_read.start() except Exception as e: logging.error(e) event.Skip() def SerialRead(self): try: n = self.ser.inWaiting() if n: self.receive_data += self.ser.read(n).replace(binascii.unhexlify("00"), "") if self.thresholdValue <= len(self.receive_data): self.receive_count += 1 # 接收显示是否为Hex if self.m_rcvBox.get() == 1: self.receive_data = self.space_b2a_hex(self.receive_data) self.m_rcvtext.insert("end", "[" + str(datetime.datetime.now()) + " - " + str(self.receive_count) + "]:n", "green") self.m_rcvtext.insert("end", self.receive_data + "n") self.m_rcvtext.see("end") self.receive_data = "" except Exception as e: logging.error(e) self.receive_data = "" self.ser.stop() self.ser = None def m_clrRcvTextOnButtonClick( self, event ): self.m_rcvtext.Clear() event.Skip() def space_b2a_hex(self, data): ''' 格式化接收到的数据字符串 示例:123 --> 31 32 33 ''' new_data_list = list() new_data = "" hex_data = binascii.b2a_hex(data) temp_data = "" for index,value in enumerate(hex_data): temp_data += value if len(temp_data) == 2: new_data_list.append(temp_data) temp_data = "" for index,value in enumerate(new_data_list): if index%25 == 0 and index != 0: new_data += "n" new_data += value new_data += " " return new_data def main(): App = wx.PySimpleApp() MainSerialUI().Show(True) App.MainLoop() if __name__ == '__main__': main() 总是提示错误见下图 编译不能通过,所以编写的代码不能时时check,很是郁闷,百度查了,也是无果,求助于各位大神,谢谢! 发稿与2018年1月23日 |
只有小组成员才能发言,加入小组>>
39个成员聚集在这个小组
加入小组3618 浏览 0 评论
6277 浏览 0 评论
2516 浏览 0 评论
5524 浏览 0 评论
2231 浏览 0 评论
/9
GMT+8, 2025-12-2 06:14 , Processed in 1.519588 second(s), Total 61, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
4428
