Cadence生成光绘文件后出现以下类似警告,并且我调整精度、尺寸什么的均不起作用,警告依然存在警告如下: WARNING: Segment with same start and end points at (342.123 1076.217) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (1221.057 1072.204) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (1218.757 1074.502) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (2097.478 2230.525) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (2297.480 2230.525) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (1884.360 2665.827) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (3562.512 1834.255) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (179.519 2143.857) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (179.519 2104.487) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (2427.170 1695.526) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (3214.390 1885.527) will be ignored. Increasing output accuracy may allow segment to be generated. WARNING: Segment with same start and end points at (3744.810 1705.527) will be ignored. Increasing output accuracy may allow segment to be generated.
3个回答
请问你这个问题解决了吗 ?和你一样精准度,单位什么都试了 还是不好使,如果解决了,麻烦指导我一下谢谢您。
这个我咨询了一下LAYout,说这种情况不影响制板,没什么问题 |
这个我咨询了一下layout,说这种情况不影响制板,没什么问题 |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
10 浏览 0 评论
1710 浏览 1 评论
891 浏览 3 评论
1019 浏览 0 评论
pads打印彩色贴片图时,为什么有时有颜色选择,有时没有颜色选择?
1368 浏览 1 评论
GMT+8, 2024-10-4 17:14 , Processed in 0.669864 second(s), Total 76, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
