/* My structure of SMTP U32 storage variable. This variable is private and */
/* is not altered by SMTP Client. It is only set to zero when smtp_cbfunc() */
/* is called for the first time. */
typedef struct {
U8 id;
U16 idx;
} MY_BUF;
#define MYBUF(p) ((MY_BUF *)p)
U16 smtp_cbfunc (U8 code, U8 *buf, U16 buflen, U32 *pvar) {
/* This function is called by the SMTP client to get email parameters and */
/* data. It returns the number of bytes written to the output buffer. */
/* Hi-bit of return value (len is or-ed with 0x8000) is a repeat flag the */
/* SMTP client. If this bit is set to 1, the system will call this func */
/* again with parameter 'pvar' pointing to a 4-byte buffer. This buffer */
/* can be used for storing different status variables for this function. */
/* It is set to 0 by SMTP client on first call and is not altered by SMTP */
/* client for repeated calls. This function should NEVER write more than */
/* 'buflen' bytes to the buffer. */
/* Parameters: */
/* code - function code with following values: */
/* 0 - Username: - for SMTP authentication if requested */
/* 1 - Password: - for SMTP authentication if requested */
/* 2 - 'From : ' - get email address of the sender */
/* 3 - 'To : ' - get email address of recipient */
/* 4 - 'Subject: ' - get subject of email */
/* 5 - 'Data : ' - get email data in plain ascii format */
/* buf - SMTP transmit buffer */
/* buflen - length of this buffer (500-1400 bytes - depends on MSS) */
/* pvar - pointer to local storage buffer used for repeated loops */
/* This is a U32 variable - size is 4 bytes. Value is: */
/* - on 1st call = 0 */
/* - 2nd call = as set by this function on first call */
U32 len = 0;
switch (code) {
case 0:
/* Enter Username for SMTP Server authentication. */
len = str_copy (buf, SMTP_USER);
break;
case 1:
/* Enter Password for SMTP Server authentication. */
len = str_copy (buf, SMTP_PASSWORD);
break;
case 2:
/* Enter email address of the sender. */
len = str_copy (buf, MAIL_FROM);
break;
case 3:
/* Enter email address of the recipient. */
len = str_copy (buf, RCPT_TO);
break;
case 4:
/* Enter email subject. */
len = str_copy (buf, MAIL_SUBJECT);
break;
case 5:
/* Enter email data. */
switch (MYBUF(pvar)->id) {
case 0:
/* First call, enter an email header text. */
len = sprintf ((char *)buf, MSG_HEADER);
MYBUF(pvar)->id = 1;
MYBUF(pvar)->idx = 1;
goto rep;
case 1:
/* Add email message body. */
/* Let's use as much of the buffer as possible. */
/* This will produce less packets and speedup the transfer. */
len = sprintf ((char *)(buf), "%d. ",MYBUF(pvar)->idx);
len += str_copy (buf+len, "用户可以在这里添加数据n");
if (++MYBUF(pvar)->idx > 5)
MYBUF(pvar)->id = 2;
/* Request a repeated call, bit 15 is a repeat flag. */
rep: len |= 0x8000;
break;
case 2:
/* Last one, add a footer text to this email. */
len = str_copy (buf, MSG_FOOTER);
break;
return ((U16)len);
BOOL smtp_accept_auth (U8 *srv_ip) {
/* SMTP server with address 'srv_ip' is asking for user authentication. */
/* Return value: __TRUE = use the authentication */
/* __FALSE = do not use the authentication */
/* Accept the authentication. */
return (__TRUE);
* end of file
