*** Using Compiler 'V5.06 update 4 (build 422)', folder: 'C:Keil_v5ARMARMCCBin'
Build target 'Target 1' compiling main.c... main.c(16): error: #18: expected a ")" IPOH_MODER&=~(3<<(2*10)); main.c(17): error: #18: expected a ")" IPOH_MODER|=(1<<(2*10)); main.c(19): error: #18: expected a ")" PIOH_ODR&=~(1<<10); main.c(29): warning: #1-D: last line of file ends without a newline } main.c: 1 warning, 3 errors ".outLED-REG.axf" - 3 Error(s), 1 Warning(s). 这是错误 |
10 个讨论
/* 新建工程寄存器模板 */
#include "stm32f4xx.h" #define PERIPH_BASE ((unsigned int)0X40000000) #define AHB1PERIPH_BASE (PERIPH_BASE+0X00020000) #define GPIOH_BASE (AHB1PERIPH_BASE+0X0000IC00) //peripheral外设缩写 #define GPIOH_ODR *(unsigned int *)(GPIOH_BASE+0X14) #define GIPOH_MODER *(unsigned int *)(GPIOH_BASE+0X00) int main(void) { GIPOH_MODER&=~(3<<(2*10)); GIPOH_MODER|=(1<<(2*10)); GPIOH_ODR&=~(1<<10); while(1); } /* 骗过系统不报错 */ void SystemInit(void) { } 这是程序 |
/* 新建工程寄存器模板 */
#include "stm32f4xx.h" #define PERIPH_BASE ((unsigned int)0X40000000) #define AHB1PERIPH_BASE (PERIPH_BASE+0X00020000) #define GPIOH_BASE (AHB1PERIPH_BASE+0X0000IC00) //peripheral外设缩写 #define GPIOH_ODR *(unsigned int *)(GPIOH_BASE+0X14) #define GIPOH_MODER *(unsigned int *)(GPIOH_BASE+0X00) int main(void) { GIPOH_MODER&=~(3<<(2*10)); GIPOH_MODER|=(1<<(2*10)); GPIOH_ODR&=~(1<<10); while(1); } /* 骗过系统不报错 */ void SystemInit(void) { } |
/* 新建工程寄存器模板 */ #include "stm32f4xx.h" #define PERIPH_BASE ((unsigned int)0X40000000) #define AHB1PERIPH (PERIPH_BASE+0X00020000) #define GPIOH_BASE (AHB1PERIPH_BASE+0X0000IC00) //peripheral外设缩写 #define GPIOH_ODR *(unsigned int *)(GPIOH_BASE+0X14) #define GIPOH_MODER *(unsigned int *)(GPIOH_BASE+0X00) int main(void) { AHB1PERIPH |=(1<<7); GIPOH_MODER &=~(1<<2*10); GIPOH_MODER|=(1<<2*10); GPIOH_ODR &=~(1<<10); while(1); } /* 骗过系统不报错 */ void SystemInit(void) { } |
你正在撰写讨论
如果你是对讨论或其他讨论精选点评或询问,请使用“评论”功能。
STM32F405驱动DS1302时钟模块,输出时间错乱该怎么排查?
2776 浏览 2 评论
stm32f405rgt6驱动DS1302ZN出现时间错乱问题
2379 浏览 1 评论
stm32用fsmc读取ad7606采集数据,数据不变,只有开发版复位才更新数据
2255 浏览 0 评论
2367 浏览 1 评论
1625 浏览 1 评论
/9
GMT+8, 2025-12-1 19:05 , Processed in 0.892447 second(s), Total 81, Slave 66 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
21912
