扫一扫,分享给好友
情况是这样
利用quartusII 13.1生成了一个nco 核,进行模块例化和tb文件编写 编译通过,没有问题,点击run rtl simulation,modelsim中仿真报错如图 显示在执行nco_run_msim_rtl_verilog.do文件在第41行停止了,文件中的第41行如图 以前在仿真FIR核时出现过类似问题,我的解决方法是改掉模块例化名,原来的模块例化名如图 原来编译好的IP核如图 改正:将模块例化名中的 "_st" 删掉,改正后的模块例化名如图 编译后的IP核显示如图 再次编译点击仿真,这回却报出了另外一个错误 错误中提到的文件内容粘贴如下 Info: Start Nativelink Simulation process Error: You did not generate the simulation model files or you generated the IP file using an older version of MegaCore which is not supported by RTL NativeLink Simulation Error: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly Error: NativeLink simulation flow was NOT successful ================The following additional information is provided to help identify the cause of error while running nativelink scripts================= Nativelink TCL script failed with errorCode: NONE Nativelink TCL script failed with errorInfo: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly (procedure "get_ip_info" line 1) invoked from within "get_ip_info $full_file_name" (procedure "run_eda_simulation_tool" line 195) invoked from within "run_eda_simulation_tool eda_opts_hash" 编写的例化代码核tb代码如下 module nco ( phi_inc_i, clk, reset_n, clken, fsin_o, fcos_o, out_valid); input [31:0] phi_inc_i; input clk; input reset_n; input clken; output [17:0] fsin_o; output [17:0] fcos_o; output out_valid; nco1 nco1_inst( .phi_inc_i(phi_inc_i), .clk(clk), .reset_n(reset_n), .clken(clken), .fsin_o(fsin_o), .fcos_o(fcos_o), .out_valid(out_valid)); endmodule `timescale 1ps / 1ps module nco_vlg_tst(); wire out_valid; wire [17:0] sin_val; wire [17:0] cos_val; reg [31:0] phi; reg reset_n; reg clken; reg clk; parameter CYCLE = 20000; parameter HALF_CYCLE = 10000; initial begin $dumpvars; #0 clk = 1'b0; #0 reset_n = 1'b0; #0 clken = 1'b1; #0 phi = 32'b00000101000111101011100001010010; #(14*HALF_CYCLE) reset_n = 1'b1; end always begin #HALF_CYCLE clk = 1; #HALF_CYCLE clk = 0; end integer sin_ch, sin_print; integer cos_ch, cos_print; initial begin sin_ch = $fopen ("fsin_o_ver_nco1.txt"); cos_ch = $fopen ("fcos_o_ver_nco1.txt"); end always @(posedge clk) begin if(reset_n==1'b1 & out_valid==1'b1) begin if (sin_val[17:0] < (1<<17)) sin_print = sin_val[17:0]; else sin_print = sin_val[17:0] - (1<<18); if (cos_val[17:0] < (1<<17)) cos_print = cos_val[17:0]; else cos_print = cos_val[17:0] - (1<<18); $fdisplay (sin_ch, "%0d", sin_print); $fdisplay (cos_ch, "%0d", cos_print); end end nco i_nco1 ( .out_valid(out_valid), .fsin_o(sin_val[17:0]), .fcos_o(cos_val[17:0]), .phi_inc_i(phi[31:0]), .reset_n(reset_n), .clken(clken), .clk(clk) ); endmodule 不知道是哪里出了问题,所以求各位吧友指教,非常感谢! |
1 条评论
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1280 浏览 0 评论
888 浏览 0 评论
842 浏览 0 评论
619 浏览 0 评论
977 浏览 0 评论
4424 浏览 63 评论
/9
GMT+8, 2025-12-1 21:48 , Processed in 0.876388 second(s), Total 81, Slave 60 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
6295
