扫一扫,分享给好友
我要做基于FPGA的模数转换算法设计,采用的是顶层设计,分模块编写,再元件例化。ad部分没问题,就是fpga里把16位二进制数转换成32位单精度浮点数并做除法,编译之后错误都出现在fpga模块里和顶层设计的有关fpga的语句里,还都是语法错误。请教大神指导修改,谢谢!
顶层设计: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; Use ieee.std_logic_unsigned.all; Use ieee.std_logic_arith.all; ENtiTY test IS port( led_out:out std_logic; clk1: IN std_logic; HOLDA,HOLDB,HOLDC:OUT std_logic; S3_rd,S2_rd,S1_rd:OUT std_logic; S3_CS,S2_CS,S1_CS:OUT std_logic; S3_EOC,S2_EOC,S1_EOC:IN std_logic; data_bus: out std_logic_vector (15 downto 0); reset_bar: IN std_logic ); END entity test; Architecture behavioral of test is component ads8365 is port ( a1: IN std_logic; HOLDA1,HOLDB1,HOLDC1:OUT std_logic; S3_rd1,S2_rd1,S1_rd1:OUT std_logic; S3_CS1,S2_CS1,S1_CS1:OUT std_logic; S3_EOC1,S2_EOC1,S1_EOC1:IN std_logic; data_bus1: out std_logic_vector (15 downto 0); reset_bar1: IN std_logic ); end component; component fpga is port (reset_bar2: IN std_logic; clk_f: IN std_logic; aaa1: out std_logic_vector(31 downto 0); aaa2: out std_logic_vector(31 downto 0) ); end component; component led_out is port (led_out1:out std_logic; clkin: IN std_logic ); end component; signal AD_ctr_reg: std_logic_vector(15 downto 0);--ADC control regester signal AD_EOC_reg: std_logic_vector(15 downto 0);-- ADC end convered regesiter signal ab_rege_cs1: std_logic; signal Addr_reg: std_logic_vector(15 downto 0);--address regestor signal clk_test: std_logic; signal a_delayed: std_logic; signal a_pe: std_logic; signal Retifier_sector_reg: std_logic_vector(5 downto 0); signal Retif_deadtimer: std_logic_vector(15 downto 0); signal Inverter_sector_reg: std_logic_vector(5 downto 0); signal Inverter_deadtimer: std_logic_vector(15 downto 0); signal sap: std_logic; signal ***p: std_logic; signal scp: std_logic; begin u1: component ads8365 port map (a1=> clk1,HOLDA1=> HOLDA,HOLDB1=> HOLDB,HOLDC1=> HOLDC, S3_rd1=> S3_rd,S2_rd1=> S2_rd,S1_rd1=> S1_rd,S3_CS1=> S3_CS,S2_CS1=> S2_CS,S1_CS1=> S1_CS, S3_EOC1=> S3_EOC,S2_EOC1=> S2_EOC,S1_EOC1=> S1_EOC,data_bus1=> data_bus,reset_bar1=> reset_bar ); u2: component fpga port map (reset_bar2=> reset_bar,clk_f=> clk1); u3: component led_out port map (led_out1=> led_out,clkin=> clk1); end behavioral; fpga模块: library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; Use ieee.std_logic_unsigned.all; Use ieee.std_logic_arith.all; entity fpga is port ( reset_bar2: IN std_logic; clk_f: IN std_logic; aaa1: out std_logic_vector(31 downto 0 ); aaa2: out std_logic_vector(31 downto 0) ); end entity fpga; Architecture behavioral of fpga is signal Addr_reg: std_logic_vector(15 downto 0); signal AD_ctr_reg: std_logic_vector(15 downto 0); signal s1:std_logic; signal s2:std_logic; signal m1:std_logic_vector(22 downto 0); signal m2:std_logic_vector(22 downto 0); signal e1:std_logic_vector(7 downto 0); signal e2:std_logic_vector(7 downto 0); begin process(a1) variable a1_counter3:integer range 0 to 20; begin if reset_bar2 = '0'then a1_counter3 :=0; elsif rising_edge(a1) then if a1_counter3 =20 then a1_counter3 :=0; temp:= Addr_reg xor "0111111111111111"; temp:= conv_std_logic_vector(conv_integer(temp)+1,16); aaa1(31)<= 0; aaa1(30 DOWNTO 23)<= 10001110; aaa1(22 DOWNTO 0) <= temp (14 downto 0) & "00000000"; s1<=aaa1(31); e1<=aaa1(30 DOWNTO 23); m1<=aaa1(22 DOWNTO 0); aaa2(31)<= 0; aaa2(30 downto 23)<= 10001100; aaa2(22 downto 0) <= "1001100110011" & "0000000000"; s2<=aaa2(31); e2<=aaa2(30 DOWNTO 23); m2<=aaa2(22 DOWNTO 0); else a1_counter3:=a1_counter3+1; end if; end if; END PROCESS; end; |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1280 浏览 0 评论
888 浏览 0 评论
842 浏览 0 评论
619 浏览 0 评论
977 浏览 0 评论
4424 浏览 63 评论
/9
GMT+8, 2025-12-1 19:33 , Processed in 0.564749 second(s), Total 72, Slave 53 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
25311
