if(flag==1)
{ flag=0; if(receive_table[3]!=receive_table[0]+receive_table[1]+receive_table[2]) { send_UART(0xff); } else { send_UART(0x00); 这段是求和校验,为什么只是返回ff,即使校验成功。还有模拟电压输出也有问题,有大神了解的求指点, QQ1533477443(有偿) |
4个回答
有没有人呀,有没有人呀,有没有人呀......
没有前后程序,没法做出判断~~~~
#include #include "delay.h" #define RELOAD_COUNT 248 //11.0592Mhz, 256-reload_count=8, baud=115200 #include #include "delay.h" #define RELOAD_COUNT 248 //11.0592Mhz, 256-reload_count=8, baud=115200 #define uchar unsigned char //单字节 #define uint unsigned int //双字节 #define N 4 //接收字节数 #define M 1 //发送字节数 #define S_max 20 //最高速度档位 ***it LED = P1^3; ***it CTRL1=P0^4; ***it CTRL2=P0^5; ***it CTRL3=P0^6; ***it CTRL4=P0^7; ***it CTRL5=P4^6; ***it CTRL6=P4^1; uchar transmit_table[M]; //发送数组 uchar receive_table[N]; //接收数组 uint i=0; //发送数组变量 uint j=0; //接收数组变量 uint flag=0; //接收标志位 // ***it SPI_status=SPSTAT.7; //spi波特率为四分之一晶振源,数据先准备好然后随着上升沿更新。 uchar L_WORD=0xaa; uchar H_WORD=0x0f; // 0000 //void delay(uint k); void send_UART(uchar l); void UART_Interrupt_Receive(void); void serial_port_initial(); void send_TLV5608(); void main() { send_TLV5608(); P0=0; serial_port_initial(); while(1) { LED=1; CTRL6=0; //delay(50000); LED=0; CTRL6=1; //单片机测试LED //delay(50000); if(flag==1) { flag=0; if(receive_table[3]!=receive_table[0]+receive_table[1]+receive_table[2]) { send_UART(0xff); } else { send_UART(0x00); /* L_WORD=(int)(((float)receive_table[1]/5)*(0x3FF))&(0xff); //DA转换器低字节 H_WORD=(((int)(((float)receive_table[1]/5)*(0x3FF))>>8)|receive_table[0])&(0xff); // DA转换器高字节 switch(receive_table[0]) { case 0x00:if(receive_table[2]==0x01) {CTRL1=1;send_TLV5608(); break;} else if(receive_table[2]==0x10){CTRL1=0;break;} else { send_UART(0xff);break;} case 0x01:if(receive_table[2]==0x01) {CTRL2=1;send_TLV5608(); break;} else if(receive_table[2]==0x10){CTRL2=0;break;} else { send_UART(0xff);break;} case 0x02:if(receive_table[2]==0x01) {CTRL3=1;send_TLV5608(); break;} else if(receive_table[2]==0x10){CTRL2=0;break;} else { send_UART(0xff);break;} case 0x03:if(receive_table[2]==0x01) {CTRL4=1;send_TLV5608(); break;} else if(receive_table[2]==0x10){CTRL2=0;break;} else { send_UART(0xff);break;} case 0x04:if(receive_table[2]==0x01) {CTRL5=1;send_TLV5608(); break;} else if(receive_table[2]==0x10){CTRL2=0;break;} else { send_UART(0xff);break;} case 0x05:if(receive_table[2]==0x01) {CTRL6=1;send_TLV5608(); break;} else if(receive_table[2]==0x10){CTRL2=0;break;} else { send_UART(0xff);break;} default: send_UART(0xff);break; } ES=1; */ //开启串口中断 } } } // if(flag==1) // { // // ES=0; // for(i=0;i // SBUF=transmit_table; // while(!TI); // TI=0; // } // ES=1; // flag=0; // // } } void send_TLV5608() { SPCTL=0xF8; SPSTAT=0xC0;//clear SPIF,WCOL SPDAT=L_WORD; while((SPSTAT^7)==0) { continue; } SPDAT=H_WORD; } void serial_port_initial() //115200bps@11.0592MHz { PCON |= 0x80; //使能波特率倍速位SMOD SCON = 0x50; //8位数据,可变波特率 AUXR |= 0x04; //独立波特率发生器时钟为Fosc,即1T BRT = 0xFA; //设定独立波特率发生器重装值 AUXR |= 0x01; //串口1选择独立波特率发生器为波特率发生器 AUXR |= 0x10; //启动独立波特率发生器 EA=1; ES=1; } //void serial_port_initial() // { // SCON = 0X50; //方式1,串口1,可变波特率,8位数据,无校验位 // BRT = RELOAD_COUNT; //串口1使用独立波特率发生器 // AUXR = 0X11; //串口1波特率发生器选择为独立波特率发生器,开启独立波特率发生器,12时钟计数1次,Fosc/12/(256-BRT) // EA = 1; // ES = 1; // } void send_UART(uchar l) { ES = 0; TI = 0; SBUF = l; while(!TI); TI = 0; ES = 1; } void UART_Interrupt_Receive(void) interrupt 4 { if(RI==1) { RI=0; receive_table[j++]=SBUF; if(j>=N) { flag=1; //接收数组满标志位 j=0; } } else { TI=0; } } |
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
STM32进行DMA数据转运,为什么只有A组最后一位数据被转运到B组去?
501 浏览 1 评论
1377 浏览 3 评论
1022 浏览 0 评论
嵌入式开发 Win11安装ST-Link 提示 设备描述符请求失败 怎么处理?
1157 浏览 0 评论
1443 浏览 1 评论
GMT+8, 2024-8-12 11:21 , Processed in 0.563572 second(s), Total 50, Slave 43 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
