我在做一个基于51单片机的交通灯,在普中HC6800-ES v2.0开发板上做,我把信号灯接在p1口0-5端口,自己焊接了一个信号灯模块,现在程序运行后正常通行四个子状态以及全面禁行模式都没问题,但是切换南北限行或者切换东西限行时,会出现数码管闪烁,还有一点噪音,比如东西方向原本绿灯,切换东西限行,会先有5秒黄灯,然后红灯,这个时候切换后原本应该是黄灯 ,但是这个时候数码管就会闪烁,时间看不清。并且信号灯显示也有问题,大概5秒后就正常了原本只应该亮两个灯,但是会亮四个,其中两个闪烁5秒左右会熄灭,求大神解答
#include #define uchar unsigned char #define uint unsigned int #define zrun_sta1 0xe1 #define zrun_sta2 0xd1 #define zrun_sta3 0xcc #define zrun_sta4 0xca #define nbxx_sta1 0xca #define nbxx_sta2 0xe1 #define dxxx_sta1 0xe1 #define dxxx_sta2 0xcc #define stop_sta 0xc9 ***it nanbei_r=P1^0; ***it dongxi_r=P1^3; ***it wei1=P2^2; ***it wei2=P2^3; ***it wei3=P2^4; ***it key1=P3^0; ***it key2=P3^1; ***it key3=P3^2; ***it key4=P3^3; uchar code seg7[]={ 0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71 }; uchar dxtime,nbtime,count,runmode,sec; void delayms(uint xms) { uint i,j; for(i=xms;i>0;i--) for(j=110;j>0;j--); } void display(uchar nbtime,uchar dxtime) { uchar shi,ge; shi=nbtime/10; ge=nbtime%10; P0=seg7[shi]; wei1=1; wei2=1; wei3=1; delayms(5); P0=0x00; P0=seg7[ge]; wei1=0; wei2=1; wei3=1; delayms(5); P0=0x00; shi=dxtime/10; ge=dxtime%10; P0=seg7[shi]; wei1=1; wei2=0; wei3=1; delayms(5); P0=0x00; P0=seg7[ge]; wei1=0; wei2=0; wei3=1; delayms(5); P0=0x00; } void regu_run() { if(sec<30) P1=zrun_sta1; else if(sec<35) P1=zrun_sta2; else if(sec<65) P1=zrun_sta3; else if(sec<70) P1=zrun_sta4; display(nbtime,dxtime); } void nbxx() { bit btemp; btemp=nanbei_r; if(btemp==1) { if(sec<5) { P1=nbxx_sta1; display(nbtime,88); } else { P1=nbxx_sta2; display(88,88); } } else { P1=nbxx_sta2; display(88,88); } } void dxxx() { bit btemp; btemp=dongxi_r; if(btemp==1) { if(sec<5) { P1=dxxx_sta1; display(88,dxtime); } else { P1=dxxx_sta2; display(88,88); } } else { P1=dxxx_sta2; display(88,88); } } void keyscan() { if(key1==0) { delayms(2); if(key1==0) { while(!key1); //等待k1键松开 runmode=1; dxtime=30; nbtime=35; sec=0; TR0=1; } } if(key2==0) { delayms(10); if(key2==0) { while(!key2); TR0=0; runmode=2; nbtime=5; sec=0; TR0=1; } } if(key3==0) { delayms(10); if(key3==0) { while(!key3); TR0=0; dxtime=5; runmode=3; sec=0; TR0=1; } } if(key4==0) { delayms(2); if(key4==0) { while(!key4); runmode=4; sec=0; TR0=0; } } } void main() { P2=0xFF; //防止出现交叉重影 TMOD=0x01; TH0=(65536-50000)/256; TL0=(65536-50000)%256; EA=1; ET0=1; sec=1; nbtime=35; dxtime=30; TR0=0; while(1) { keyscan(); if(runmode==1) regu_run(); if(runmode==2) nbxx(); if(runmode==3) dxxx(); if(runmode==4) { TR0=0; P1=stop_sta; display(88,88); } } } void timer0_int()interrupt 1 { TH0=(65536-50000)/256; TL0=(65536-50000)%256; count++; if(count==20) { sec++; nbtime--; dxtime--; if(sec==70) { sec=0; nbtime=35; dxtime=30; } if(sec==30) { dxtime=5; } if(sec==35) { dxtime=35; nbtime=30; } if(sec==65) { nbtime=5; } count=0; } TR0=1; } |
3个回答
这个简单,肯定是程序的问题了!明日白天再来仔细看和回复你。
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
265 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
789 浏览 0 评论
1306 浏览 2 评论
787 浏览 0 评论
【RA4M2-SENSOR开发板评测】Analogue+Timers综合测试
1587 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16902 浏览 31 评论
/9
GMT+8, 2025-12-2 09:36 , Processed in 0.808411 second(s), Total 83, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1910
