- //宏定义
- #define uchar unsigned char
- #define uint unsigned int
- //包含头文件
- #include
- #include <18b20.h>
- #include
- #include
- #include
- #include
- #define Imax 14000 //此处为晶振为11.0592时的取值,
- #define Imin 8000 //如用其它频率的晶振时,
- #define Inum1 1450 //要改变相应的取值。
- #define Inum2 700
- #define Inum3 3000
- ***it K1=P1^0;
- ***it K2=P1^1;
- ***it K3=P1^2; //按键定义
- ***it BUZZ=P1^4;
- ***it PWM=P2^0; //PWM输出
- unsigned char Im[4]={0x00,0x00,0x00,0x00};//红外编码
- //uchar displaydata[4]; //显示暂存数组
- //全局变量
- char f,dang,count,count1,a_a; //档位
- unsigned long m,Tc;
- unsigned char IrOK; //定义红外工作变量
- void jisuan(); //声明计算函数
- uchar mode;
- char sec_b=0;
- bit flag_b=0;
- uint TH,TL; //上下限变量
- uchar baif,suiji;
- uchar code zhuanhuan[4]={0,3,5,10};//转换数组
- /*ascii码*/
- unsigned char mun_char_table[]={"0123456789abcdef- "};
- unsigned char temp_table[] ={"L:00.0C H:00.0C"};
- unsigned char temp_set_table[]={"D:0 T:00.0C"};
- void write_eeprom() //内部eeprom写函数
- SectorErase(0x2000); //清空
- SectorErase(0x2c00);
- SectorErase(0x2e00);
- byte_write(0x2c00,TH/256);
- byte_write(0x2c01,TH%256);
- byte_write(0x2c02,TL/256);
- byte_write(0x2c03,TL%256); //将上下限数据保存到eeprom
- byte_write(0x2c04,dang);
- byte_write(0x2c05,mode);
- byte_write(0x2060,0x01);
- /******************把数据从单片机内部eeprom中读出来*****************/
- void read_eeprom()
- mode = byte_read(0x2c05);
- dang = byte_read(0x2c04);
- TH = byte_read(0x2c00)*256+byte_read(0x2c01);
- TL = byte_read(0x2c02)*256+byte_read(0x2c03);
- a_a = byte_read(0x2060);
- /**************开机自检eeprom初始化*****************/
- void init_eeprom()
- if(a_a != 1) //新的单片机初始单片机内问eeprom
- a_a = 1;
- write_eeprom(); //保存数据
- //毫秒级的延时函数,time是要延时的毫秒数
- void delay(uint time)
- uint i,j;
- for(i=0;i
- for(j=0;j<110;j++);
- void display() //显示函数
- lcd_char_write(7,1,mun_char_table[disdata[1]]);
- lcd_char_write(8,1,mun_char_table[disdata[2]]);
- lcd_char_write(10,1,mun_char_table[disdata[3]]);
- lcd_char_write(2,1,mun_char_table[dang]);
- lcd_char_write(2,0,mun_char_table[TL%1000/100]);
- lcd_char_write(3,0,mun_char_table[TL%100/10]);
- lcd_char_write(5,0,mun_char_table[TL%10]);
- lcd_char_write(11,0,mun_char_table[TH%1000/100]);
- lcd_char_write(12,0,mun_char_table[TH%100/10]);
- lcd_char_write(14,0,mun_char_table[TH%10]);
- void key() //按键函数
- if(K1==0) //按键1按下或者遥控器上的按键按下
- delay(5); //延时去抖
- if(K1==0) //再次判断按键按下
- BUZZ=0;
- delay(20);
- BUZZ=1; //按键音
- mode++; //模式加
- if(mode>4) //模式加到大于4
- mode=0; //模式清零
- // Im[2]=0;
- IrOK=0; //变量清零
- write_eeprom(); //写入eeprom数据
- while(!K1); //按键释放
- if(K2==0)
- delay(5);
- if(K2==0)
- BUZZ=0;
- delay(20);
- BUZZ=1;
- if(mode==0) //模式等于1时
- TH++; //上限加
- if(TH>999) //上限加到大于99.9度
- TH=TL+1; //上限等于下限加一
- else if(mode==1) //模式等于2时
- TL++; //下限加
- if(TL>=TH) //下限加到大于等于上限
- TL=TH-1; //下限等于上限减一
- else if(mode==3) //模式等于3时
- dang++; //档位加一
- if(dang>3) //档位大于3时
- dang=0; //档位清零
- //Im[2]=0;
- //IrOK=0; //红外变量清零
- while(!K2); //按键释放
- if(K3==0)
- delay(5);
- if(K3==0)
- BUZZ=0;
- delay(20);
- BUZZ=1;
- if(mode==0)
- TH--;
- if(TH<=TL)
- TH=TL+1;
- else if(mode==1)
- TL--;
- if(TL>=TH)
- TL=TH-1;
- else if(mode==3)
- dang++;
- if(dang>3)
- dang=0;
- //Im[2]=0;
- //IrOK=0;
- write_eeprom();
- while(!K3);
- void jisuan() //计算函数
- if(mode==0||mode==1||mode==2) //模式0、1、2
- if(tvalue<=TL) //温度小于下限时
- PWM=1; //关闭输出,占空比0%
- else if(tvalue>=TH) //温度大于等于上限
- PWM=0; //打开输出,占空比100%
- else //其他状态时
- if(tvalue<(TL+(TH-TL)/2))
- baif=15; //占空比控制变量
- if(count1>baif) //根据变量判断占空比大小pwm=0.3
- PWM=1; //关闭风扇
- else
- PWM=0; //打开风扇*/
- else
- baif=25; //占空比控制变量
- PWM=1; //关闭风扇
- else
- PWM=0; //打开风扇*/
- else if(mode==3) //模式3时
- if(count1>(zhuanhuan[dang]*5)) //根据档位计算出占空比
- PWM=1;
- else
- PWM=0;
- void main() //主函数
- /*uint count; //定义变量
- unsigned int i=0,j=0;
- EA=1; //打开中断总开关
- EX1=1; //打开外部中断1
- IT1=1; //下降沿有效
- TMOD=0x11; //定时器工作方式
- TR0=0; //关闭T0
- TH0=0;
- TL0=0; //初值0
- ET1=1; //T1允许中断
- TR1=1; //T1打开中断
- TH1=0xfc;
- TL1=0x18; //T1初值1ms
- mode=0; //初始模式0
- TH=300;
- TL=200; //上下限初始值
- init_eeprom(); //初始化eeprom
- read_eeprom(); //读取eeprom数据
- lcd_system_reset(); //LCD1602 初始化
- for (i=0;i<16;i++) lcd_char_write(i,0,temp_table[i]);
- for (j=0;j<12;j++) lcd_char_write(j,1,temp_set_table[j]);
- while(1) //进入循环
- jisuan(); //计算函数
- count++; //变量加
- if(count>200) //加到大于200
- count=0; //清零
- TR1=0; //关闭定时器T1
- read_wendu(); //读取温度
- TR1=1; //打开定时器T1
- jisuan(); //计算函数
- display(); //显示函数 */
- while(1) key(); //按键函数
- //jisuan(); //计算函数
- void timer1() interrupt 3 //定时器T1工作函数
- TH1=0xfc;
- TL1=0x18; //重新赋初值
- count1++; //加
- if(count1>50)
- count1=0;
- void intersvr1(void) interrupt 2 //红外工作函数
- TR0=1;
- Tc=TH0*256+TL0;//提取中断时间间隔时长
- TH0=0;
- TL0=0; //定时中断重新置零
- if((Tc>Imin)&&(Tc
- m=0;
- f=1;
- return;
- } //找到启始码
- if(f==1)
- if(Tc>Inum1&&Tc
- Im[m/8]=Im[m/8]>>1|0x80; m++;
- if(Tc>Inum2&&Tc
- Im[m/8]=Im[m/8]>>1; m++; //取码
- if(m==32)
- m=0;
- f=0;
- if(Im[2]==~Im[3])
- IrOK=1;
- TR0=0;
- else
- IrOK=0; //取码完成后判断读码是否正确
- //准备读下一码
复制代码
3个回答
