| 回复本帖可获得 1 分积分奖励! 每人限 1 次 | |
#include
***it KEY_OUT_1 = P3^7; ***it KEY_OUT_2 = P3^6; ***it KEY_OUT_3 = P3^5; ***it KEY_OUT_4 = P3^4; ***it KEY_IN_1 = P3^0; ***it KEY_IN_2 = P3^1; ***it KEY_IN_3 = P3^2; ***it KEY_IN_4 = P3^3; extern void LcdSingleShow(unsigned char x,unsigned char y,unsigned char dat); unsigned char code KeyCodeMap[4][4] = { {'1','2','3',0x26}, {'4','5','6',0x25}, {'7','8','9',0x28}, ('0',0x1b,0x0d,0x27), }; unsigned char KeySta[4][4] = { {1,1,1,1},{1,1,1,1}, {1,1,1,1},{1,1,1,1}, }; extern void KeyAction(unsigned char keycode); void KeyDriver() { unsigned char i,j; static unsigned char backup[4][4] = { {1,1,1,1},{1,1,1,1}, {1,1,1,1},{1,1,1,1}, }; for(i=0;i<4;i++) { for(j=0;j<4;j++) { if(backup[i][j] != KeySta[i][j]) { if(backup[i][j] == 1) KeyAction(KeyCodeMap[i][j]); backup[i][j] = KeySta[i][j]; } } } } void KeyScan() //扫描按键状态并消抖 { unsigned char i; unsigned char a,b,c,d; static unsigned char keyout = 0; static unsigned char keybuf[4][4] = { {0xff,0xff,0xff,0xff},{0xff,0xff,0xff,0xff}, {0xff,0xff,0xff,0xff},{0xff,0xff,0xff,0xff}, }; keybuf[0][keyout] = (keybuf[keyout][0]<<1)|KEY_IN_1; keybuf[1][keyout] = (keybuf[keyout][1]<<1)|KEY_IN_2; keybuf[2][keyout] = (keybuf[keyout][2]<<1)|KEY_IN_3; keybuf[3][keyout] = (keybuf[keyout][3]<<1)|KEY_IN_4; for(i=0;i<4;i++) { if((keybuf[i][keyout]&0x0f) == 0x0f) KeySta[i][keyout] = 1; else if((keybuf[i][keyout]&0x0f) == 0x00) KeySta[i][keyout] = 0; } keyout++; keyout &= 0x03; switch(keyout) { case 0:KEY_OUT_1 = 0;KEY_OUT_2 = 1;KEY_OUT_3 = 1;KEY_OUT_4 = 1;break; case 1:KEY_OUT_2 = 0;KEY_OUT_1 = 1;KEY_OUT_3 = 1;KEY_OUT_4 = 1;break; case 2:KEY_OUT_3 = 0;KEY_OUT_2 = 1;KEY_OUT_1 = 1;KEY_OUT_4 = 1;break; case 3:KEY_OUT_4 = 0;KEY_OUT_2 = 1;KEY_OUT_3 = 1;KEY_OUT_1 = 1;break; default:break; } } 为什么只有主对角线上的四个按键可以正常使用 按其它按键都没有反应 在程序中插入Lcd显示 应该是KeyScan()这个函数出错了 但没发现错在哪
4个回答
回帖奖励 +1 分积分
硬件是否正确
回帖奖励 +1 分积分
这是CT107D上的矩阵键盘?
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
【瑞萨RA6E2】瑞萨E2S软件安装过程,等待过程玩下97_e2 studio_ZGZZ
331 浏览 0 评论
532 浏览 0 评论
【原创】【RA4M2-SENSOR开发板评测】低功耗+USB综合测试
842 浏览 0 评论
1383 浏览 2 评论
824 浏览 0 评论
【youyeetoo X1 windows 开发板体验】少儿AI智能STEAM积木平台
16914 浏览 31 评论
/9
GMT+8, 2025-12-3 16:20 , Processed in 0.862947 second(s), Total 83, Slave 63 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
1302
