扫一扫,分享给好友
各位大大好,楼主最近做一个点阵的试验,利用STM32驱动MAX7219控制的LED点阵,程序如下,不过点阵全红,不知道问题出在哪了?
#include #include #define uchar unsigned char #define uint unsigned int //定义Max7219端口 ***it Max7219_pinCLK = P2^2; ***it Max7219_pinCS = P2^1; ***it Max7219_pinDIN = P2^0; uchar code disp1[38][8]={ {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//0 {0x10,0x18,0x14,0x10,0x10,0x10,0x10,0x10},//1 {0x7E,0x2,0x2,0x7E,0x40,0x40,0x40,0x7E},//2 {0x3E,0x2,0x2,0x3E,0x2,0x2,0x3E,0x0},//3 {0x8,0x18,0x28,0x48,0xFE,0x8,0x8,0x8},//4 {0x3C,0x20,0x20,0x3C,0x4,0x4,0x3C,0x0},//5 {0x3C,0x20,0x20,0x3C,0x24,0x24,0x3C,0x0},//6 {0x3E,0x22,0x4,0x8,0x8,0x8,0x8,0x8},//7 {0x0,0x3E,0x22,0x22,0x3E,0x22,0x22,0x3E},//8 {0x3E,0x22,0x22,0x3E,0x2,0x2,0x2,0x3E},//9 {0x8,0x14,0x22,0x3E,0x22,0x22,0x22,0x22},//A {0x3C,0x22,0x22,0x3E,0x22,0x22,0x3C,0x0},//B {0x3C,0x40,0x40,0x40,0x40,0x40,0x3C,0x0},//C {0x7C,0x42,0x42,0x42,0x42,0x42,0x7C,0x0},//D {0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x7C},//E {0x7C,0x40,0x40,0x7C,0x40,0x40,0x40,0x40},//F {0x3C,0x40,0x40,0x40,0x40,0x44,0x44,0x3C},//G {0x44,0x44,0x44,0x7C,0x44,0x44,0x44,0x44},//H {0x7C,0x10,0x10,0x10,0x10,0x10,0x10,0x7C},//I {0x3C,0x8,0x8,0x8,0x8,0x8,0x48,0x30},//J {0x0,0x24,0x28,0x30,0x20,0x30,0x28,0x24},//K {0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7C},//L {0x81,0xC3,0xA5,0x99,0x81,0x81,0x81,0x81},//M {0x0,0x42,0x62,0x52,0x4A,0x46,0x42,0x0},//N {0x3C,0x42,0x42,0x42,0x42,0x42,0x42,0x3C},//O {0x3C,0x22,0x22,0x22,0x3C,0x20,0x20,0x20},//P {0x1C,0x22,0x22,0x22,0x22,0x26,0x22,0x1D},//Q {0x3C,0x22,0x22,0x22,0x3C,0x24,0x22,0x21},//R {0x0,0x1E,0x20,0x20,0x3E,0x2,0x2,0x3C},//S {0x0,0x3E,0x8,0x8,0x8,0x8,0x8,0x8},//T {0x42,0x42,0x42,0x42,0x42,0x42,0x22,0x1C},//U {0x42,0x42,0x42,0x42,0x42,0x42,0x24,0x18},//V {0x0,0x49,0x49,0x49,0x49,0x2A,0x1C,0x0},//W {0x0,0x41,0x22,0x14,0x8,0x14,0x22,0x41},//X {0x41,0x22,0x14,0x8,0x8,0x8,0x8,0x8},//Y {0x0,0x7F,0x2,0x4,0x8,0x10,0x20,0x7F},//Z {0x8,0x7F,0x49,0x49,0x7F,0x8,0x8,0x8},//中 {0xFE,0xBA,0x92,0xBA,0x92,0x9A,0xBA,0xFE},//国 }; void Delay_xms(uint x) { uint i,j; for(i=0;i } //-------------------------------------------- //功能:向MAX7219(U3)写入字节 //入口参数:DATA //出口参数:无 //说明: void Write_Max7219_byte(uchar DATA) { uchar i; Max7219_pinCS=0; for(i=8;i>=1;i--) { Max7219_pinCLK=0; Max7219_pinDIN=DATA&0x80; DATA=DATA<<1; Max7219_pinCLK=1; } } //------------------------------------------- //功能:向MAX7219写入数据 //入口参数:address、dat //出口参数:无 //说明: void Write_Max7219(uchar address,uchar dat) { Max7219_pinCS=0; Write_Max7219_byte(address); //写入地址,即数码管编号 Write_Max7219_byte(dat); //写入数据,即数码管显示数字 Max7219_pinCS=1; } void Init_MAX7219(void) { Write_Max7219(0x09, 0x00); //译码方式:BCD码 Write_Max7219(0x0a, 0x03); //亮度 Write_Max7219(0x0b, 0x07); //扫描界限;8个数码管显示 Write_Max7219(0x0c, 0x01); //掉电模式:0,普通模式:1 Write_Max7219(0x0f, 0x00); //显示测试:1;测试结束,正常显示:0 } void main(void) { uchar i,j; Delay_xms(50); Init_MAX7219(); while(1) { for(j=0;j<38;j++) { for(i=1;i<9;i++) Write_Max7219(i,disp1[j][i-1]); Delay_xms(1000); } } } |
1个回答
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
1246 浏览 1 评论
AD7686芯片不传输数据给STM32,但是手按住就会有数据。
1179 浏览 3 评论
2259 浏览 0 评论
如何解决MPU-9250与STM32通讯时,出现HAL_ERROR = 0x01U
1345 浏览 1 评论
hal库中i2c卡死在HAL_I2C_Master_Transmit
1767 浏览 1 评论
GMT+8, 2024-11-28 05:14 , Processed in 0.557441 second(s), Total 74, Slave 57 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
