扫一扫,分享给好友
如题,我用的是CCS5.4和XDS510,驱动已经正常安装了,但是在测试连接的时候,显示了Failure due to the controller command-finish taking too long.具体内容如下,请问各位大神这是怎么什么情况。
[Start] Execute the command: %ccs_base%/common/uscif/dbgjtag.exe -f %boarddatafile% -rv -o -F inform,logfile=yes -S pathlength -S integrity [Result] -----[Print the board config pathname(s)]------------------------------------ C:Userslysh1992AppDataLocal.ti693494126 0 BrdDattestBoard.dat -----[Print the reset-command software log-file]----------------------------- This utility has selected a 100- or 510-class product. This utility will load the adapter 'seedjca8990isa.dll'. The library build date was 'Apr 1 2013'. The library build time was '23:55:08'. The library package version is '5.1.73.0'. The library component version is '35.34.40.0'. The controller does not use a programmable FPGA. The controller has a version number of '1' (0x00000001). The controller has an insertion length of '16' (0x00000010). This utility will attempt to reset the controller. A error occurred while attempting to reset the controller. -----[An error has occurred and this utility has aborted]-------------------- This error is generated by TI's USCIF driver or utilities. The value is '-342' (0xfffffeaa). The title is 'SC_ERR_HUNG_COMMAND'. The explanation is: Failure due to the controller command-finish taking too long. [End] |
6个回答
不支持
没遇到过!
要跟仿真器厂家建议
我的也是
我的是win8,,64位的,楼主如果解决的话麻烦你写一下哟,
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
TMS320C6748 板卡设计中是否一定需要有SDRAM或者DDR
2341 浏览 0 评论
1382 浏览 0 评论
4021 浏览 1 评论
【六岳微LY-F335开发板试用体验】epwm启动ADC并在OLED上显示结果
4882 浏览 0 评论
【六岳微LY-F335开发板试用体验】软件开发环境及调试下载
4908 浏览 0 评论
/9
GMT+8, 2025-12-11 03:06 , Processed in 1.982186 second(s), Total 54, Slave 47 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
9014
