扫一扫,分享给好友
附件1是SDRAM读写的VHDL的语言代码,是根据附件2verilog HDL例程改写的,环境是Quartus II9.1,附件2里有芯片的手册。代码还望各位指正下,还有就是波形怎么仿真,因为自己已经研究了一段时间,也问了些人,并没有解决仿真出现的问题。 我的qq505403998, 讲真,谢谢那些能帮忙的。
9个回答
楼主吧,程序贴出来。大家才会帮你
module sram_test(
clk,rst_n,led, sram_addr,sram_wr_n,sram_data ); input clk; // 50MHz input rst_n; //低电平复位 output led; // LED1 // FPGA与SRAM外部接口 output[14:0] sram_addr; // SRAM地址总线 output sram_wr_n; // SRAM写选通 inout[7:0] sram_data; // SRAM数据总线 //------------------------------------------------------- reg[25:0] delay; //延时计数器 always @ (posedge clk or negedge rst_n) if(!rst_n) delay <= 26'd0; else delay <= delay+1; //不断计数,周期约为1.28s //------------------------------------------------------- reg[7:0] wr_data; // SRAM写入数据总线 reg[7:0] rd_data; // SRAM读出数据 reg[14:0] addr_r; // SRAM地址总线 wire sram_wr_req; // SRAM写请求信号 wire sram_rd_req; // SRAM读请求信号 reg led_r; // LED寄存器 assign sram_wr_req = (delay == 26'd9999); //产生写请求信号 assign sram_rd_req = (delay == 26'd19999); //产生读请求信号 always @ (posedge clk or negedge rst_n) if(!rst_n) wr_data <= 8'd0; else if(delay == 26'd29999) wr_data <= wr_data+1'b1; //写入数据每1.28s自增1 always @ (posedge clk or negedge rst_n) if(!rst_n) addr_r <= 15'd0; else if(delay == 26'd29999) addr_r <= addr_r+1'b1; //写入地址每1.28s自增1 always @ (posedge clk or negedge rst_n) if(!rst_n) led_r <= 1'b0; else if(delay == 26'd20099) begin //每1.28s比较一次同一地址写入和读出的数据 if(wr_data == rd_data) led_r <= 1'b1; //写入和读出数据一致,LED点亮 else led_r <= 1'b0; //写入和读出数据不同,LED熄灭 end assign led = led_r; //------------------------------------------------------- `define DELAY_80NS (cnt==3'd7) reg[2:0] cnt; //延时计数器 always @ (posedge clk or negedge rst_n) if(!rst_n) cnt <= 3'd0; else if(cstate == IDLE) cnt <= 3'd0; else cnt <= cnt+1'b1; //------------------------------------ parameter IDLE = 4'd0, WRT0 = 4'd1, WRT1 = 4'd2, REA0 = 4'd3, REA1 = 4'd4; reg[3:0] cstate,nstate; always @ (posedge clk or negedge rst_n) if(!rst_n) cstate <= IDLE; else cstate <= nstate; always @ (cstate or sram_wr_req or sram_rd_req or cnt) case (cstate) IDLE: if(sram_wr_req) nstate <= WRT0; //进入写状态 else if(sram_rd_req) nstate <= REA0; //进入读状态 else nstate <= IDLE; WRT0: if(`DELAY_80NS) nstate <= WRT1; else nstate <= WRT0; //延时等待160ns WRT1: nstate <= IDLE; //写结束,返回 REA0: if(`DELAY_80NS) nstate <= REA1; else nstate <= REA0; //延时等待160ns REA1: nstate <= IDLE; //读结束,返回 default: nstate <= IDLE; endcase //------------------------------------- assign sram_addr = addr_r; // SRAM地址总线连接 //------------------------------------- reg sdlink; // SRAM数据总线控制信号 always @ (posedge clk or negedge rst_n) if(!rst_n) rd_data <= 8'd0; else if(cstate == REA1) rd_data <= sram_data; //读出数据 always @ (posedge clk or negedge rst_n) if(!rst_n) sdlink <=1'b0; else case (cstate) IDLE: if(sram_wr_req) sdlink <= 1'b1; //进入连续写状态 else if(sram_rd_req) sdlink <= 1'b0; //进入单字节读状态 else sdlink <= 1'b0; WRT0: sdlink <= 1'b1; default: sdlink <= 1'b0; endcase assign sram_data = sdlink ? wr_data : 8'hzz; // SRAM地址总线连接 assign sram_wr_n = ~sdlink; endmodule |
LIBRARY ieee;
USE ieee.std_logic_1164.all; USE ieee.std_logic_unsigned.all; ENTITY write IS PORT ( clk : IN STD_LOGIC;--50MHZ rst_n : IN STD_LOGIC; led : OUT STD_LOGIC; sram_addr : OUT STD_LOGIC_VECTOR(17 DOWNTO 0); sram_wr_n : OUT STD_LOGIC; sram_data : INOUT STD_LOGIC_VECTOR(15 DOWNTO 0) ); END write; ARCHITECTURE trans OF write IS SIGNAL delay : STD_LOGIC_VECTOR(25 DOWNTO 0); SIGNAL wr_data : STD_LOGIC_VECTOR(15 DOWNTO 0); SIGNAL rd_data : STD_LOGIC_VECTOR(15 DOWNTO 0); SIGNAL addr_r : STD_LOGIC_VECTOR(17 DOWNTO 0); SIGNAL sram_wr_req : STD_LOGIC; SIGNAL sram_rd_req : STD_LOGIC; SIGNAL led_r : STD_LOGIC; SIGNAL cnt : STD_LOGIC_VECTOR(2 DOWNTO 0); CONSTANT IDLE : INTEGER := 0; CONSTANT WRT0 : INTEGER := 1; CONSTANT WRT1 : INTEGER := 2; CONSTANT REA0 : INTEGER := 3; CONSTANT REA1 : INTEGER := 4; SIGNAL cstate : STD_LOGIC_VECTOR(3 DOWNTO 0); SIGNAL nstate : STD_LOGIC_VECTOR(3 DOWNTO 0); SIGNAL sdlink : STD_LOGIC; BEGIN PROCESS (clk, rst_n) BEGIN IF (rst_n = '0') THEN delay <= "00000000000000000000000000"; ELSIF (clk'EVENT AND clk = '1') THEN delay <= delay + "00000000000000000000000001"; END IF; END PROCESS; sram_wr_req<='1' when(delay="00000000000010011100001111"); sram_rd_req<='1' when(delay="00000000000100111000011111"); PROCESS (clk, rst_n) BEGIN IF (rst_n = '0') THEN wr_data <= "0000000000000000"; ELSIF (clk'EVENT AND clk = '1') THEN IF (delay = "0000000000111010100101111") THEN wr_data <= wr_data + "0000000000000001"; END IF; END IF; END PROCESS; PROCESS (clk, rst_n) BEGIN IF (rst_n = '0') THEN addr_r <= "000000000000000000"; ELSIF (clk'EVENT AND clk = '1') THEN IF (delay = "00000000000111010100101111") THEN addr_r <= addr_r + "000000000000000001"; END IF; END IF; END PROCESS; PROCESS (clk, rst_n) BEGIN IF (rst_n = '0') THEN led_r <= '0'; ELSIF (clk'EVENT AND clk = '1') THEN IF (delay = "00000000000100111010000011") THEN IF (wr_data = rd_data) THEN led_r <= '1'; ELSE led_r <= '0'; END IF; END IF; END IF; END PROCESS; led <= led_r; PROCESS (clk, rst_n) BEGIN IF (rst_n = '0') THEN cnt <= "000"; ELSIF (clk'EVENT AND clk = '1') THEN IF (cstate =IDLE) THEN cnt<="000"; ELSE cnt <= cnt + "001";--延时计数器 END IF; END IF; END PROCESS; PROCESS (clk, rst_n) BEGIN IF (rst_n = '0') THEN cstate <="0000"; ELSIF (clk'EVENT AND clk = '1') THEN cstate <= nstate; END IF; END PROCESS; PROCESS (cstate, sram_wr_req, sram_rd_req, cnt) BEGIN CASE cstate IS WHEN "0000" =>IF (sram_wr_req = '1') THEN nstate <= "0001"; ELSIF (sram_rd_req = '1') THEN nstate <= "0011"; ELSE nstate <= "0000" ; END IF; WHEN "0001" => IF (cnt = "111") THEN nstate <= "0010"; ELSE nstate <="0001"; END IF; WHEN "0010" => nstate <= "0000"; WHEN "0011" => IF (cnt = "111") THEN nstate <="0100"; ELSE nstate <= "0011"; END IF; WHEN "0100"=> nstate <= "0000"; WHEN OTHERS => nstate <= "0000"; END CASE; END PROCESS; sram_addr <= addr_r; PROCESS (clk, rst_n) BEGIN IF (rst_n = '0') THEN rd_data <= "0000000000000000"; ELSIF (clk'EVENT AND clk = '1') THEN IF (cstate = "0100") THEN rd_data <= sram_data; END IF; END IF; END PROCESS; PROCESS (clk, rst_n) BEGIN IF (rst_n = '0') THEN sdlink <= '0'; ELSIF (clk'EVENT AND clk = '1') THEN CASE cstate IS WHEN "0000" => IF (sram_wr_req = '1') THEN sdlink <= '1'; ELSIF (sram_rd_req = '1') THEN sdlink <= '0'; ELSE sdlink <= '0'; END IF; WHEN "0001" => sdlink <= '1'; WHEN OTHERS => sdlink <= '0'; END CASE; END IF; END PROCESS; --sdlink sram_data <= wr_data WHEN (sdlink = '1') ELSE --sdlink 1 "00000000ZZZZZZZZ"; sram_wr_n <= NOT(sdlink); END trans; VHDL语言改写的,波形仿真不对,delay总是加到50,在清零了。 |
在搭建sdram核时,新建qsys工程,按照引脚分配表分配的,然后隐藏的引脚我也释放了,但在qsys工程上依旧没有显示出来,Assignment planner 显示引脚已经分配了,然后编译没有报错,继续进行下一步创建nios时,出现No Nios II target connection paths were located. Check connections and that a Nios II .sof is downloaded,我是按照教程步骤走的,只不过板子型号不同,按照这个
自己顶顶,希望路过的进来看看帮帮忙。
路过,不会,不过也没看懂楼主到底是什么问题
就是首先在quartus上搭建qsys时,我用tcl脚本文件来分配管脚,但有部分没有在图上显示出来,比如说,1.PNG上sdram_cs_n没有显示分配的引脚,但手动分配的Assignment Planner 在写入TCL文本并且运行后,引脚分配在Planner上都显示了(3.PNG图上显示),然后我编译没有报错,接着就是建立nios II 工程,按照相应教程文档走,出现我在贴子上说的nios上碰到的问题。 |
半飞过 发表于 2016-12-2 10:20 http://www.alteraforum.com/forum/showthread.php?t=27441 看一下,希望对你的问题有帮助 |
你问题解决吗?我也出现同样的问题?求帮助
你正在撰写答案
如果你是对答案或其他答案精选点评或询问,请使用“评论”功能。
NVMe高速传输之摆脱XDMA设计50:主要功能测试结果与分析2 nvmePCIe高速存储
252 浏览 0 评论
NVMe高速传输之摆脱XDMA设计49:主要功能测试结果与分析1
1501 浏览 0 评论
907 浏览 0 评论
855 浏览 0 评论
658 浏览 0 评论
4427 浏览 63 评论
/9
GMT+8, 2025-12-2 10:55 , Processed in 1.036517 second(s), Total 93, Slave 73 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2256
