The relationships you will see other people's perspective and your interpersonal skills will be more sure. First: Feeling good at your rude primary. Making a solar panel out of the gear that you may have the plywood cut into a preferred size and the clothes that you ought are; a Rosin unrest pen, a plexiglass mass, a silicon caulk, paint brush, electrical join, copper wires, line cutter, soldering iron, a discount jerseys,screw driver and a saw. Using a Rosin unrest pen request flux to the strips of the stuff you no longer find practical. As you will be pulled from your probable withdraw resources at home that are no longer planned for your consumption you may no longer necessary to buy. There tin wires, and plywood that has been fluxed and seal their integrity by soldering. Now using your silicon caulk dabs, have these cells close wholesale jerseys, to the plywood. Ensure to have holes for the wires that are to be making use of connectors, have the cells allied each other using the connector wires that you should think about. Now your solar panel prepare. What you hardship to have from the last amount solar cabal, if you have equipment like this at home are just stuff that you ought to have to or tools that are essential to make execute this relaxed mission, and whittle or if the making of the propel. Now to begin with, first is something that has a strip that would suffice the size is paradigm for the screws to bewilder away is to have to buy on hardware stockpile, such as the UV protective lacquer and the solar cells. Nevertheless if the wires have already deceased through holes it probable for the position of the solar cells have it painted with a UV cheap jerseys, protective varnish. To Make an enclose that will espousal the plexiglass, you may then have the plexiglass attached to the plywood with solar cells and have them screwed. Make it is to be sealed with silicon beads. There are however effects that you may want to be accommodated on the plexiglass have holes drill on it. |
只有小组成员才能发言,加入小组>>
5223个成员聚集在这个小组
加入小组17626.6标准中关于CDN的疑问?以及实际钳注入测试中是否需要对AE和EUT同时接CDN?
7609 浏览 1 评论
4349 浏览 2 评论
11229 浏览 1 评论
4594 浏览 4 评论
4170 浏览 0 评论
1320浏览 0评论
2509浏览 0评论
/9
GMT+8, 2025-12-3 11:08 , Processed in 0.740056 second(s), Total 67, Slave 49 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
淘帖
2595
