上面是仿真结果,下面是代码 module fifo_data( input wrclk, input rdclk, input rst_n, input din_en, input [17:0] din_re, input [17:0] din_im, output [17:0] dout_re, output [17:0] dout_im, output rdempty_re, output wrfull_re, output rdempty_im, output wrfull_im ); reg rdreq_re,wrreq_re; reg rdreq_im,wrreq_im; reg [17:0] fifo_din_re; reg [17:0] fifo_din_im; always @(posedge wrclk)begin if(!rst_n)begin fifo_din_re <= 0; fifo_din_im <= 0; // wrreq <= 1'b0; end else begin if (din_en) begin fifo_din_re <= din_re; fifo_din_im <= din_im; // wrreq <= 1'b1; end else begin fifo_din_re <= 0; fifo_din_im <= 0; // wrreq <= 1'b0; end end end always @(posedge wrclk or negedge rst_n)begin if(!rst_n) wrreq_re <= 1'b0; else begin if(!wrfull_re )begin wrreq_re <= 1'b1; end else wrreq_re <= 1'b0; end end always @(posedge wrclk or negedge rst_n)begin if(!rst_n) wrreq_im <= 1'b0; else begin if(!wrfull_im )begin wrreq_im <= 1'b1; end else wrreq_im <= 1'b0; end end always @(posedge rdclk or negedge rst_n)begin if(!rst_n)begin rdreq_re <= 1'b0; end else if(!rdempty_re)begin rdreq_re <= 1'b1; end else rdreq_re <= 1'b0; end always @(posedge rdclk or negedge rst_n)begin if(!rst_n)begin rdreq_im <= 1'b0; end else if(!rdempty_im)begin rdreq_im <= 1'b1; end else rdreq_im <= 1'b0; end //assign data_out=fifo_Q; fifo fifo_re ( .aclr ( !rst_n ), .data ( fifo_din_re ), .rdclk ( rdclk ), .rdreq ( rdreq_re ), .wrclk ( wrclk ), .wrreq ( wrreq_re ), .q ( dout_re ), .rdempty ( rdempty_re ), .wrfull ( wrfull_re ) ); fifo fifo_im ( .aclr ( !rst_n ), .data ( fifo_din_im ), .rdclk ( rdclk ), .rdreq ( rdreq_im ), .wrclk ( wrclk ), .wrreq ( wrreq_im ), .q ( dout_im ), .rdempty ( rdempty_im ), .wrfull ( wrfull_im ) ); endmodule |
2个回答
表示没看懂,截的图也没截信号的名字,也不知道你fifo设的深度是多少,不过你写的时钟慢,读的时钟快,出来这种波形也不奇怪
227 浏览 0 评论
421 浏览 0 评论
1413 浏览 1 评论
477 浏览 0 评论
求FPGA 驱动控制ltc2271 或者 ltc2180 或者 ltc2190或者 ltc2202 的代码
2098 浏览 0 评论
4976 浏览 113 评论
GMT+8, 2024-9-13 23:21 , Processed in 0.968855 second(s), Total 73, Slave 56 queries .
