【OK210试用体验】循环点亮 led 灯 - 在线问答 - 电子技术论坛 - 最好最受欢迎电子论坛!
617595187 ( 楼主 ) 2015-8-22 22:13:06  只看该作者 倒序浏览
个人是小白,手动烧写了linux系统。按照论坛里很牛的大神的帖子,熟悉烧写代码的流程,代码还是参考大神的,代码如下:
main.c文件
#include "stdint.h"
// IO port for controling LEDs
#define     GPM04_BASE    0xE0200340  // GPM04 Base Address
#define     GPD0_BASE    0xE02000A0
#define     GPCON_OFS    0x00        // Control Register Offset
#define     GPDAT_OFS    0x04        // Data Register Offset
#define     MP0_4CON_REG    (*(volatile uint32_t *)(GPM04_BASE+GPCON_OFS))
#define     MP0_4DAT_REG    (*(volatile uint32_t *)(GPM04_BASE+GPDAT_OFS))
#define     GPD0CON_REG    (*(volatile uint32_t *)(GPD0_BASE+GPCON_OFS))
#define     GPD0DAT_REG    (*(volatile uint32_t *)(GPD0_BASE+GPDAT_OFS))
#define     LED1    4    // GPM0_4->LED1
#define     LED2    5    // GPM0_5->LED2
#define     LED3    6    // GPM0_6->LED3
#define     LED4    7    // GPM0_7->LED4
#define        BEEP    0    // GPD0_0->BEEP
void Delay_ms(uint32_t Count)
    //延时1ms,共延时nCountms
    // Arm clock为400M,循环体每次30个Arm clock
    int32_t temp1 = 13333;
    int32_t temp2 = 0;
    asm volatile (
        "Delay_ms_0:n"
        "mov  %0, %2n"
        "Delay_ms_1:n"
        "subs  %0, %0, #1n" // 单发射 cycle 1
        // 跳转清流水线,以下指令均只用作填充流水线
        "mov %1, %1n"    // 双发射 cycle 1
        "mov %1, %1n"    // 单发射 cycle 2
        "mov %1, %1n"    // 单发射 cycle 3
        "mov %1, %1n"    // 单发射 cycle 4
        "mov %1, %1n"    // 单发射 cycle 5
        "mov %1, %1n"    // 单发射 cycle 6
        "mov %1, %1n"    // 单发射 cycle 7
        "mov %1, %1n"    // 单发射 cycle 8
        "mov %1, %1n"    // 单发射 cycle 9
        "mov %1, %1n"    // 单发射 cycle 10
        "mov %1, %1n"    // 单发射 cycle 11
        "mov %1, %1n"    // 单发射 cycle 12
        "mov %1, %1n"    // 单发射 cycle 13
        "mov %1, %1n"    // 单发射 cycle 14
        "mov %1, %1n"    // 单发射 cycle 15
        "mov %1, %1n"    // 单发射 cycle 16
        "mov %0, %0n"    // 单发射 cycle 17
        "bne.w Delay_ms_1n" // 跳转会清流水线,13级流水线,cycle 30
        "subs  %1, %1, #1n"   // 调用者确保nCount不为0
        "bne.w Delay_ms_0n"
        : "+r"(temp2), "+r"(Count): "r"(temp1): "cc"
void Gpio_LED1(uint8_t On)
    if (On) {
        MP0_4DAT_REG &= ~(1<     } else {
        MP0_4DAT_REG |= (1<     }
void Gpio_LED2(uint8_t On)
    if (On) {
void Gpio_LED3(uint8_t On)
    if (On) {
void Gpio_LED4(uint8_t On)
    if (On) {
void Gpio_Beep(uint8_t On)
    if (On) {
        GPD0DAT_REG |= (1<     } else {
        GPD0DAT_REG &= ~(1<     }
void Gpio_Init(void)
     // GPM04_4 output led1, off
    MP0_4CON_REG = (MP0_4CON_REG & (~(0xf<<(LED1<<2)))) | (0x1<<(LED1<<2));
    MP0_4DAT_REG |= (1<      // GPM04_5 output led2, off
    MP0_4CON_REG = (MP0_4CON_REG & (~(0xf<<(LED2<<2)))) | (0x1<<(LED2<<2));
    MP0_4DAT_REG |= (1<      // GPM04_6 output led3, off
    MP0_4CON_REG = (MP0_4CON_REG & (~(0xf<<(LED3<<2)))) | (0x1<<(LED3<<2));
    MP0_4DAT_REG |= (1<      // GPM04_7 output led4, off
    MP0_4CON_REG = (MP0_4CON_REG & (~(0xf<<(LED4<<2)))) | (0x1<<(LED4<<2));
    MP0_4DAT_REG |= (1<     // Beep output, off
    GPD0CON_REG = (GPD0CON_REG & (~(0xf<<(BEEP<<2)))) | (0x1<<(BEEP<<2));
void main(void)
    Gpio_Init();
    while (1) {
        Gpio_LED1(1);
        Delay_ms(1000);
        Gpio_LED1(0);
        Gpio_LED2(1);
        Delay_ms(1000);
        Gpio_LED2(0);
        Gpio_LED3(1);
        Delay_ms(1000);
        Gpio_LED3(0);
        Gpio_LED4(1);
        Gpio_Beep(1);
        Delay_ms(1000);
        Gpio_LED4(0);
        Gpio_Beep(0);
led.s文件
    SECTION .intvec:CODE:NOROOT(2)
    PUBLIC    __iar_program_start
    ARM
__iar_program_start
    EXTERN    main
    BLX    main
    END
下载工具使用的是sdboot.exe这个软件还是很好用的,手动用dnw1.01.EXE,可是没有找到OK210的驱动
实验现象
感谢帖友的分享。努力学习中,。。。
0个回复
站长推荐上一条 /9 下一条
GMT+8, 2025-12-4 00:06 , Processed in 0.664420 second(s), Total 64, Slave 44 queries .
