本帖最后由 L‰Ζ权℃ミ/jd 于 2012-2-29 17:42 编辑 下面的程序哪里出现错误啊,帮忙改下。不要引入clk做监控,直接用inc,dec在敏感列表。 module opt_square(inc,dec,high); input inc,dec; output reg[6:0] high; always@( posedge inc or posedge dec ) begin if(inc) high<=high+7'b1; else high<=high-7'b1; end endmodule 主要想实现2个按键的加一和减一。 编译通得过,在产生功能仿真网表是,提示成功,但是进度在99%
进行波形仿真后出现很多错误。 怎样修改,出现什么问题?求助啊 Error: Zero-time oscillation in node "|opt_square|high[0]~reg0" at time 180.0 ns. Check the design or vector source file for combinational loop. Error: Zero-time oscillation in node "|opt_square|high[0]" at time 180.0 ns. Check the design or vector source file for combinational loop. Error: Zero-time oscillation in node "|opt_square|lpm_add_sub:Add1|addcore:adder|unreg_res_node[1]~7" at time 180.0 ns. Check the design or vector source file for combinational loop. Error: Zero-time oscillation in node "|opt_square|lpm_add_sub:Add1|addcore:adder|_~17" at time 180.0 ns. Check the design or vector source file for combinational loop. Error: Zero-time oscillation in node "|opt_square|lpm_add_sub:Add0|addcore:adder|unreg_res_node[0]~0" at time 180.0 ns. Check the design or vector source file for combinational loop. Error: Zero-time oscillation in node "|opt_square|lpm_add_sub:Add0|addcore:adder|_~0" at time 180.0 ns. Check the design or vector source file for combinational loop. Error: Zero-time oscillation in node "|opt_square|lpm_add_sub:Add1|addcore:adder|unreg_res_node[1]" at time 180.0 ns. Check the design or vector source file for combinational loop. Error: Zero-time oscillation in node "|opt_square|lpm_add_sub:Add1|addcore:adder|_~24" at time 180.0 ns. Check the design or vector source file for combinational loop. Error: Zero-time oscillation in node "|opt_square|lpm_add_sub:Add0|addcore:adder|unreg_res_node[0]" at time 180.0 ns. Check the design or vector source file for combinational loop. 而且进行时序仿真的时候能出现波形,但是波形是错误的 |
2个回答
没有使用一个真正的时钟信号吧
module opt_square(inc,dec,high); input inc,dec; output reg[6:0] high; always@( posedge inc or posedge dec ) begin if(inc) high<=high+7'b1; else high<=high-7'b1; end endmodule---------http://tieba.baidu.com/f?kz=1047173341 |
1、inc,dec两个按键信号不能作为时钟信号吗? 2、假如引入时钟信号如CLK,那么在时钟信号上升沿的时候将扫描过程语句的语句块 假如inc,dec信号持续时间长的话,如果时钟信号频率非常快的话, inc,dec按键按一次就不止增加1了。加一,和减一,将跟着时钟信号上升沿而改变 难达到按键一次增加一次的效果啊。这就是我理解不了的 |
464 浏览 0 评论
430 浏览 0 评论
1533 浏览 0 评论
972 浏览 0 评论
911 浏览 0 评论
4446 浏览 63 评论
GMT+8, 2025-12-4 10:34 , Processed in 0.655396 second(s), Total 73, Slave 54 queries .
4759
