`求教:使用DS2781读取序列码,电压电流等信息均为ff(示波器波形如图),如果有前辈使用过,还请帮忙指点一下
/******************************************************************** module function :electric power manage Author:罗黛心言 Creation date:2019.08.27 Modification content and date: ********************************************************************/ //#include "sysconfig.h" #include "PowerDS2781.h" #include "delay.h" #include "sys.h" /******************************************************************** pin41 PA8 ********************************************************************/ uint8_t DS_IO_READ() {return(HAL_GPIO_ReadPin(GPIOA,GPIO_PIN_5));} /******************************************************************** function name: void DS_Rset() function performance: reset pulse suction parameter: outlet parameters: remark: 标准 ********************************************************************/ void DS_Init() { DS_OUT_High(); DS_IO_OUT(); GPIO_InitTypeDef GPIO_InitStruct = {0}; GPIO_InitStruct.Pin = GPIO_PIN_5; GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_MEDIUM; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); __HAL_RCC_GPIOA_CLK_ENABLE(); } void DS_Rset() { DS_IO_OUT(); DS_OUT_Low(); delay_us(T_RSTL);// DS_OUT_High(); delay_us(T_PDH);// //delay_us(T_RSTL-T_PDH-T_PDL/2); } /******************************************************************** function name: uint8_t DS_Check(void) function performance: Power Meter chip detection suction parameter: outlet parameters: return 1:no sensor; return 0:a sensor; remark: ********************************************************************/ uint8_t DS_Check(void) { uint8_t retry = 0; DS_IO_IN(); // while(DS_IO_READ()&&retry<200) // { // retry++; // delay_us(1); // } // if(retry>=200) // return(1); // retry = 0; while(!DS_IO_READ()&&retry<24) //脉冲响应 低电平8~24us { retry++; delay_us(1); } if(retry>=24) return(1); if (retry<15) delay_us(T_SLOT -retry); return(0); // delay_us(T_PDL/2); // retry = DS_IO_READ(); // //delay_us(T_RSTL-T_PDH-T_PDL/2); // return (retry); } /******************************************************************** function name: uint8_t DS_Readbit(void) function performance: read data of bit suction parameter: outlet parameters: return data remark: ********************************************************************/ uint8_t DS_ReadBit(void) { uint8_t data = 0; DS_IO_OUT(); DS_OUT_Low(); delay_us(2); //DS_OUT_High(); DS_IO_IN(); delay_us(T_RDV); data = DS_IO_READ(); delay_us(T_SLOT-T_RDV-2); return (data); } /******************************************************************** function name: uint8_t DS_ReadByte(void) function performance: read data of byte suction parameter: outlet parameters: return data remark: ********************************************************************/ uint8_t DS_ReadByte(void) { uint8_t i = 0,j = 0,data = 0; for(i=0;i<8;i++) { data>>=1; if( DS_ReadBit()) data |= 0x80; } return (data); } /******************************************************************** function name: void DS_Write_Byte(uint8_t data) function performance: suction parameter: data: waiting to be written outlet parameters: remark: ********************************************************************/ void DS_Write_Byte(uint8_t data) { uint8_t i = 0,test = 0; DS_IO_OUT(); for(i=0;i<8;i++) { if(data&0x01) { DS_OUT_Low(); delay_us(T_LOW1); DS_OUT_High(); delay_us(T_SLOT-T_LOW1); } else { DS_OUT_Low(); delay_us(T_LOW0); DS_OUT_High(); delay_us(T_SLOT-T_LOW0); } data =data >> 1; } } uint16_t Read_byte_data(uint8_t start_address) { uint8_t one_byte_data1 = 0; uint8_t one_byte_data2 = 0; uint16_t one_word_data = 0; Write_DS_cmd(Read_Data,start_address); DS_OUT_Low(); one_byte_data1 = DS_ReadByte(); //LSB one_byte_data2 = DS_ReadByte(); //MSB one_word_data = (one_byte_data1<<8)|one_byte_data2; return(one_word_data); } uint8_t Write_data(uint8_t write_address,uint8_t dat) { uint8_t i; uint8_t one_byte_data; uint8_t pres; Write_DS_cmd(Write_Data,write_address); DS_Write_Byte(dat);//写入数据 //osDelay(10); } void Write_DS_cmd(uint8_t cmd,uint8_t address) { uint8_t pres; restart: DS_Rset(); pres = DS_Check(); if(pres) //return fause; // 如果没有器件,返回0 { delay_us(100); goto restart; } DS_Write_Byte(DS_Just_one); //主机发出Skip Net Address命令 DS_Write_Byte(cmd); // 主机发出xx命令 DS_Write_Byte(address); // 主机发出地址命令 //return ture; } void copy_data_ds2780(void) { } uint16_t Get_Voltage(void) { uint8_t H = 0,L = 0; uint8_t state = 0; uint16_t volat = 0; DS_Rset(); state = DS_Check(); volat= Read_byte_data(VOLT_RMSB); return (volat); } uint16_t Get_Temp(void) { uint8_t H = 0,L = 0; uint8_t state = 0; uint16_t tmp = 0; DS_Rset(); state = DS_Check(); tmp= Read_byte_data(TEMP_RMSB); return (tmp); } uint16_t Get_Current(void) { uint8_t H = 0,L = 0; uint8_t state = 0; uint16_t volat = 0; DS_Rset(); state = DS_Check(); volat= Read_byte_data(IREA_RMSB); return (volat); } uint16_t Get_NET(void) { uint8_t H = 0,L = 0; uint8_t state = 0; uint16_t volat = 0; DS_Rset(); state = DS_Check(); volat= Read_byte_data(WRAR_AGEO); volat =volat+1; volat =volat-1; return (volat); } void write_age() { Write_data(WRAR_AGEO,0x13); } uint16_t Get_SIGNAL(void) { uint8_t H = 0,L = 0,i=0; uint8_t si[8] = {0}; uint8_t state = 0; uint16_t volat = 0; uint8_t pres; DS_Rset(); state = DS_Check(); restart: DS_Rset(); pres = DS_Check(); if(pres) //return fause; // 如果没有器件,返回0 { delay_us(100); goto restart; } DS_Write_Byte(DS_Just_one); //主机发出Skip Net Address命令 DS_Write_Byte(Read_Data); // 主机发出xx命令 DS_Write_Byte(ACRL_SIGN); // 主机发出地址命令 //Write_DS_cmd(Read_Data,ACRL_SIGN); for(i=0;i<8;i++) si = DS_ReadByte(); //LSB volat = si[0]; return (volat); } void Set_register_ds2780() { } #ifndef _POWERDS2781_H #define _POWERDS2781_H #include "STM32f4xx_hal.h" #define DS_IO_OUT() {GPIOA->MODER&=~(3<<(5*2));GPIOA->MODER|=1<<5*2;} #define DS_IO_IN() {GPIOA->MODER&=~(3<<(5*2));GPIOA->MODER|=0<<5*2;} #define DS_OUT_High() HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_SET) #define DS_OUT_Low() HAL_GPIO_WritePin(GPIOA,GPIO_PIN_5,GPIO_PIN_RESET) /*******************************电量计芯片EEPROM寄存器定义*************************************/ #define CPRT_RMSB 0X00 // #define IAVG_RMSB 0X08 //平均电流 #define TEMP_RMSB 0X0A //温度 #define VOLT_RMSB 0X0C //电压 #define IREA_RMSB 0X0E //当前电流 #define ACRN_RMSB 0X10 //累计电流 #define ACRL_RMSB 0X12 //低电流累计 #define WRAR_AGEO 0X14 //年龄 #define ACRL_SIGN 0X3D //低电流累计 #define ACRL_ADDN 0X60 //低电流累计 /*******************************电量计芯片功能寄存器定义*************************************/ #define Read_Data 0X69 #define Write_Data 0X6C #define Copy_Data 0X48 #define Recall_Data 0XB8 #define Lock_EEPR 0X6A #define DS_Just_one 0XCC //只有一个电量计芯片时,可不用指定从机地址命令 /*******************************部分常数定义*************************************/ #define Type_Current 0x01 #define Type_Volatage 0x02 #define Type_Temperature 0x03 #define T_RSTL 75 #define T_PDH 5 #define T_PDL 24 #define T_RDV 2 #define T_SLOT 15 #define T_LOW1 1 #define T_LOW0 13 #define Current_Constant 0.00488 /*******************************电池特性参数*************************************/ #define Set_VCHG 0XCF //存储充电电压门限值用来判断检测是否充满电;范围0~9.956V,步长39.04mV 当前设置为8.1V (255/9.956)*8.1 =207 #define Set_VAE 0X00 //有效空电压用于检测空电池电量点,同上 #define Set_TMIN 0XF0 //存储最小充电电流用来检测完全充满状态;范围 0~12.75mV,步长50uV,若RSNS = 20mΩ,则范围0mA~637.5mA (255/637.5)*600=240 #define Set_IAE 0X0E //有效空电流用于检测有效工作时的空电池电量点,同上 uint16_t Get_Data_From_DS_Word(uint8_t slave,uint8_t commend,uint8_t address,uint8_t type); void MX_GPIO_Init(void); void DS_Init(); void DS_Rset(); uint8_t DS_Check(void); void Write_DS_cmd(uint8_t cmd,uint8_t address); uint16_t Get_Voltage(void); uint16_t Get_Current(void); uint16_t Get_SIGNAL(void); uint16_t Get_NET(void); uint16_t Get_Temp(void); void write_age(); #endif ` |
2个回答
不至于呀,电压是对的,电流是对的,SOC错误,是不是电池没有给到美信实验室建模呀,库仑计的一般都要见模型的,和开路电压OCV测试不相同
144个成员聚集在这个小组
加入小组一颗maxim的芯片,只有丝印,有哪位大佬知道是什么型号吗?
1790浏览 1评论
请问MAX9291MAX9288上电后,i2c通信不通的原因?
404浏览 1评论
3908浏览 1评论
459浏览 0评论
938浏览 0评论
GMT+8, 2024-10-2 08:28 , Processed in 0.843676 second(s), Total 113, Slave 94 queries .
