我使用mini2440开发板和其自带的Linux内核代码编译出uImage烧写到Nand flash 0x60000开始的地址空间,然后
[u-boot@MINI2440]# nand read.jffs2 0x30007fc0 0x60000 0x200000 NAND read: device 0 offset 0x60000, size 0x200000 2097152 bytes read: OK [u-boot@MINI2440]# bootm 0x30007fc0 ## Booting kernel from Legacy Image at 30007fc0 ... Image Name: Linux-2.6.29.4-FriendlyARM Created: 2009-12-08 6:04:05 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2022344 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK Loading Kernel Image ... OK OK Starting kernel ... Uncompressing Linux.................................................................................................................................. done, booting the kernel.程序停止这里不动了?怎么办 --------------------------------------------------------------------------------------------------------- [u-boot@MINI2440]# nand read.jffs2 0x30008000 0x60000 0x200000 NAND read: device 0 offset 0x60000, size 0x200000 2097152 bytes read: OK [u-boot@MINI2440]# bootm 0x30008000 ## Booting kernel from Legacy Image at 30008000 ... Image Name: Linux-2.6.29.4-FriendlyARM Created: 2009-12-08 6:04:05 UTC Image Type: ARM Linux Kernel Image (uncompressed) Data Size: 2022344 Bytes = 1.9 MB Load Address: 30008000 Entry Point: 30008000 Verifying Checksum ... OK XIP Kernel Image ... OK OK Starting kernel ... data abort pc : [<30008020>] lr : [<33fa31e4>] sp : 33f3fe04 ip : e59ff014 fp : e59ff014 r10: e59ff014 r9 : ea000012 r8 : 33f3ffdc r7 : 33f3ffc0 r6 : 0000016a r5 : 33f412ad r4 : 00000000 r3 : 00000000 r2 : 30000100 r1 : 0000016a r0 : 56190527 Flags: nzCv IRQs off FIQs off Mode SVC_32 Resetting CPU ... resetting ... 以上是两种不同的运行结果 这是为什么呢? |
2个回答
我仅修改了flash分区部分的代码如下:
static struct mtd_partition friendly_arm_default_nand_part[] = { [0] = { .name = "u-boot", .size = 0x00040000, .offset = 0, }, [1] = { .name = "u-boot-env", .size = 0x00020000, .offset = 0x00040000, }, [2] = { .name = "kernel", .offset = 0x00060000, .size = 0x00500000, }, [3] = { .name = "root", .offset = 0x00560000, .size = 0x03aa0000, } }; 有u-boot使用经验的朋友帮帮忙 QQ372017601 |
$gedit arch/arm/mach-s3c2440/mach-mini2440.c
MACHINE_START(PNX4008, "FriendlyARM Mini2440 development board") 改为 MACHINE_START(MINI2440, "FriendlyARM Mini2440 development board") 在include/asm/mach-types.h中有定义 #define MACH_TYPE_PNX4008 782 #define MACH_TYPE_MINI2440 1999 |
只有小组成员才能发言,加入小组>>
197个成员聚集在这个小组
加入小组为什么点亮LED的例子放在NORFlash上跑会出现奇怪的现象?
2014 浏览 6 评论
1828 浏览 5 评论
韦东山老师推出的《玩转ARM裸机实战》课程将帮你以上问题一扫而光!
4380 浏览 1 评论
GMT+8, 2024-4-27 02:14 , Processed in 0.553784 second(s), Total 74, Slave 55 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
