您好,简而言之,我需要知道VEE Pro 7.5是否能够与MODBUS(RS485,我不确定)协议进行通信和获取数据。
我搜索谷歌寻找MODBUS协议的驱动程序,专门为VEE中的通信编写(因为我的编程能力很弱)但没有找到任何东西(我认识到)。 我建议最终做的是设置一个功率计来测量功耗,然后将这些结果通过网络远程读取到我所做的基本VEE程序中。 我工作的公司尚未购买上述功率计,因为我们担心使用MODBUS协议兼容VEE。 感谢您的帮助,如果有什么不清楚,我会很乐意再解释一下。 来自Niraj Patel ---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至“owner-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至 “leave-vrf@it.lists.it.agilent.com”。要向此邮件列表发送邮件,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 Hello, In short, I need to know if VEE Pro 7.5 is capable of communicating and aquiring data from the MODBUS (RS485?? im not sure) protocol. I have searched google to look for drivers for a MODBUS protocol that is specifically written for easy communication in VEE (as my programming abilities are weak) but have not found anything (that I recognise). What I am proposing to eventually do is setup a power meter to measure power consumption and then have these results read remotely over a network into a basic VEE program I have made. The company I work for has yet to purchase the aforementioned power meter as we are worried about compatibility into VEE with the MODBUS protocol. Thank you for trying to help, I will be happy to explain anything again if something is unclear. From Niraj Patel --- You are currently subscribed to vrf as: r***@soco.agilent.com To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
5个回答
>如何将Vee生成的excel文件发布到网站?SaveAs xlHtml = 44.请参阅附件(适用于IIS)。
如果您需要对aweb站点进行身份验证(例如,它不在同一台计算机上),那么这是一个不同的故事。 这取决于网站的设置方式。-SHAWN ----您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至“owner-vrf@it.lists.it.agilent”。 com。“要取消订阅,请发送空白电子邮件至”leave-vrf@it.lists.it.agilent.com“。要向此邮件列表发送邮件,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 > How can I post a Vee generated excel file to a website? SaveAs xlHtml = 44. See attached (for IIS). If you need to authenticate to a web site (like, it's not on the same computer) then that's a different story. It depends on how the web site is setup. -SHAWN- --- You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email] To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
MessageAnyone,我如何将Vee generatedexcel文件发布到网站?---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至“owner-vrf@it.lists.it.agilent”
。取消订阅发送空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。要发送邮件到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 MessageAnyone,How can I post a Vee generated excel file to a website?---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
有一段时间我看到了一个自动将光标放在XY图上的示例。
任何帮助,将不胜感激。 谢谢---您目前订阅了vrf:r***@soco.agilent.com要订阅,请发送电子邮件至“owner-vrf@it.lists.it.agilent.com”。要取消订阅,请发送空白电子邮件至“离开” -vrf@it.lists.it.agilent.com“。要向此邮件列表发送邮件,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 At one time I saw an example that would auto place the cursor on a XY plot at the maximum. Any help would be appreciated. Thanks---You are currently subscribed to vrf as: [email=r***@soco.agilent.com]r***@soco.agilent.com[/email]To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com".To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com".To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com".Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
任何人,我如何将Vee生成的Âexcel文件发布到网站?---订阅发送电子邮件请求到“owner-vrf@it.lists.it.agilent.com”。
要取消订阅,请发送一封空白电子邮件至“leave-vrf@it.lists.it.agilent.com”。 要将邮件发送到此邮件列表,请发送电子邮件至“vrf@agilent.com”。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。 在“www.oswegosw.com/vrf_archive/”上搜索“unofficial vrf archive”。 以上来自于谷歌翻译 以下为原文 Anyone, How can I post a Vee generated excel file to a website? --- To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
如果您需要对网站进行身份验证(例如,它不在同一台计算机上),那么这是一个不同的故事。 这取决于网站的设置方式。-SHAWN ----订阅时向“owner-vrf@it.lists.it.agilent.com”发送电子邮件请求。要取消订阅,请发送空白电子邮件至“leave-vrf” @ it.lists.it.agilent.com“。要发送邮件到这个邮件列表,请发送电子邮件至”vrf@agilent.com“。 如果您需要有关邮件列表的帮助,请发送邮件至“owner-vrf@it.lists.it.agilent.com”。在“www.oswegosw.com/vrf_archive/”上搜索“非官方vrf档案”。 以上来自于谷歌翻译 以下为原文 > How can I post a Vee generated excel file to a website? SaveAs xlHtml = 44. See attached (for IIS). If you need to authenticate to a web site (like, it's not on the same computer) then that's a different story. It depends on how the web site is setup. -SHAWN- --- To subscribe send an email request to "owner-vrf@it.lists.it.agilent.com". To unsubscribe send a blank email to "leave-vrf@it.lists.it.agilent.com". To send messages to this mailing list, email "vrf@agilent.com". If you need help with the mailing list send a message to "owner-vrf@it.lists.it.agilent.com". Search the "unofficial vrf archive" at "www.oswegosw.com/vrf_archive/". |
只有小组成员才能发言,加入小组>>
2108 浏览 1 评论
1870 浏览 1 评论
1725 浏览 5 评论
2592 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1568 浏览 4 评论
511浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
368浏览 0评论
1426浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
282浏览 0评论
2264浏览 0评论
GMT+8, 2024-5-7 21:29 , Processed in 1.226560 second(s), Total 85, Slave 69 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
