根据数据表,斯巴达6家族有
广泛的第三方SPI(高达x4)和NOR闪存支持功能丰富的Xilinx平台闪存和JTAG 但是,如果它支持NAND闪存,我不太清楚吗? 我想构建和FPGA + ARM平台,我当时认为每个组件都有自己的闪存。 您如何看待,我应该只使用一个NAND闪存进行FPGA和处理器访问,这意味着FPGA配置文件(.mcs)也存储在非易失性闪存中,在加电时,ARM处理器会自动配置FPGA吗? NAND闪存与Xilinx Spartan 6兼容吗? 有人可以帮助我,谢谢。 格拉迪斯 以上来自于谷歌翻译 以下为原文 According to the datasheet, The Spartan 6 family has Broad third-party SPI (up to x4) and NOR flash support Feature rich Xilinx Platform Flash with JTAG However, I don't quite understans if it supports NAND flash? I want to build and FPGA + ARM platform, I was thinking that each component has their own flash. How do you think, should I use just one NAND flash for both FPGA and processor access, which means FPGA configuration file (.mcs) is also stored in the non volatile Flash memory, at power up, ARM processor automatically configures FPGA? Is NAND flash compatible with Xilinx Spartan 6? Anyone could help me please, Thank you. Gladys |
2个回答
NAND闪存不能用于配置FPGA,但您可以在设计中使用NAND闪存。
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 在原帖中查看解决方案 以上来自于谷歌翻译 以下为原文 NAND flash cannot be used for configuring the FPGA, but you can use NAND flash in your design. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.comView solution in original post |
------您是否尝试在Google中输入问题? 如果没有,你应该在发布之前。太多结果? 尝试添加网站:www.xilinx.com 以上来自于谷歌翻译 以下为原文 NAND flash cannot be used for configuring the FPGA, but you can use NAND flash in your design. ------Have you tried typing your question into Google? If not you should before posting. Too many results? Try adding site:www.xilinx.com |
只有小组成员才能发言,加入小组>>
2179 浏览 7 评论
2617 浏览 4 评论
Spartan 3-AN时钟和VHDL让ISE合成时出现错误该怎么办?
2090 浏览 9 评论
3156 浏览 0 评论
如何在RTL或xilinx spartan fpga的约束文件中插入1.56ns延迟缓冲区?
2212 浏览 15 评论
有输入,但是LVDS_25的FPGA内部接收不到数据,为什么?
452浏览 1评论
1541浏览 1评论
在使用xc5vsx95T时JTAG扫片不成功,测量TDO无信号输出
2184浏览 0评论
516浏览 0评论
1658浏览 0评论
GMT+8, 2024-5-14 16:58 , Processed in 1.107936 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
