亲爱的朋友们
我在客户的支持中遇到了一个问题:在客户的硬件系统中,模拟芯片和微控制器的电源和接地是分开的,除了模拟芯片(如ADC)和MCU之间的数字接口用光电耦合器隔开。附图。但是如果我们把PSOC5嵌入到电路中,取代现有的模拟芯片和MCU,客户的主要担心是如何将模拟和数字完全分开。我知道模拟块和数字块的电源和接地是分开的。但我不知道模拟块和数字总线是如何实现的,就像光耦合器的功能一样。这就是我所有的问题,非常感谢! JPG 59.4 K 以上来自于百度翻译 以下为原文 Dear Friends I met an issue when supporting a customer.That is: In the customer's hardware system now,the power supply and ground of the analog chips and microcontroller are separate.Except that the digital interface between evevry analog chip(like ADC) and MCU are isolated by Photo-Coupler.These are just like picture attached. But if we embed our PSOC5 in the circuit and replace the present analog chips and MCU,the main worry of customer is that how can the analog and digital be entirely separated. I know that the power supply and ground of the analog block and digital block are separated. But I don't know how do the analog block and digital BUS ,just like the function of Photo-Coupler. That's all of my question.Thanks a lot!
3个回答
嗨,Rickzhou,
PSoC 3/5内部结构分别为模拟、数字和I/O的独立电源,分别通过引脚VDDA、VDDD和VDDIO。芯片的4个象限可以与4个不同的VDDIO电平一起使用。 也有2个内部1.8V调节器,为内部核心逻辑提供数字(VCCD)和模拟(VCCA)电源。 有关电源系统的更多信息可在以下链接的技术参考手册中找到: HTTP://www. CyPress?COM/?DOCID=26848 此外,为了最佳使用模拟块,必须遵循一些最佳实践,这在这些应用笔记中被突出显示: HTTP://www. CyPress?COM/?DOCID=25562 HTTP://www. CyPress?COM/?DOCID=26389 当做, DASG 以上来自于百度翻译 以下为原文 Hi Rickzhou, PSoC 3/5 internal architecture has separate supply for Analog, Digital and I/O which are through the pins Vdda, Vddd and Vddio respectively. The 4 Quadrants of the Chip can be used with 4 different Vddio levels. There are also 2 internal 1.8V regulators which provide the digital (Vccd) and analog (Vcca) supplies for the internal core logic. More information on the power supply system can be found in the Technical Reference Manual at the following link: http://www.cypress.com/?docID=26848 Also for optimum use of the Analog block, some Best Practises has to be followed, which are highlighted in these Application Notes: http://www.cypress.com/?docID=25562 http://www.cypress.com/?docID=26389 Regards, dasg |
亲爱的DASG
非常感谢你的帮助,你给我的文章很有帮助!但是我应该问更多关于模拟接口的事情,就像附上的图片吗? 因为一些模拟组件,如ADC,DA和COMP将通过模拟接口将一些数据传输到UDB或CPU。模拟接口能像模拟偶那样完全隔离模拟和数字吗?如果不能分开,电源和GND在一些严格的条件下可能会减少。 非常感谢! 里克 AbIF.BMP 621.5 K 以上来自于百度翻译 以下为原文 Dear Dasg Thanks a lot for your great help and the articles you show to me are very helpful! But should I ask something more about the analog interface,just like the picture attached? Because some analog components like ADC,DA and Comp will transfer some data to UDB or CPU through analog interface. And can the analog interface isolate analog and digital entirely,just like photo-couple? If it can't the separation of power supply and GND may be meaningless in some strict conditions. Thank you very much! Rick
DASG,你能提供你提到的两个应用笔记的更新链接吗?谢谢。西蒙
以上来自于百度翻译 以下为原文 dasg, can you provide updated links for that two application notes you mentioned? Thanks. Simon |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1909 浏览 1 评论
1660 浏览 1 评论
3418 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1579 浏览 6 评论
1387 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
205浏览 2评论
193浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
334浏览 2评论
360浏览 1评论
71浏览 1评论
GMT+8, 2024-5-6 13:59 , Processed in 0.647260 second(s), Total 76, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
