你好
我正在研究一个项目,我必须测量相对于万有引力的加速度。当任何方向的相对加速度大于x mg时,我想得到警报。我已经尝试使用高通滤波器和点击功能构建,但我没有得到预期的结果。有人知道我如何使用传感器功能的构建来实现这个功能吗? 我还有第二个与传感器有关的问题: 当我使用内置传感器测量温度时,我得到的值是8位二进制补码,左对齐,但我还没有发现如何将它们转换为实际温度。在正常的加热房间里,我大多得到大约-3或-4的值(从二进制补码转换成小数)。温度范围为-40至85℃。 #relative-acceleration#lis2dh 以上来自于谷歌翻译 以下为原文 Hi I�m working on a projekt where I have to measure the acceleration relative to the gravitation. I want to get an alert when there is an relative acceleration in any direction greater than x mg. I have tried with the build in high-pass filter and the click function, but I didn�t get results as expected. Does someone have an idea how i can use the build in functions of the sensor to get this working? And I have a second question related to the sensor: When i measure the temperature with the build in sensor, I get the values as 8bit two�s complement, left justified, but I haven�t found out how to convert them to the real temperature. I mostly get values of about -3 or -4 (converted from two�s complement into decimal) in a normal heated room. The temperature range is -40 to 85. #relative-acceleration #lis2dh |
3个回答
请分享您的传感器配置以及究竟是什么问题。你期望得到什么结果?
温度传感器可用于测量温度变化。 以上来自于谷歌翻译 以下为原文 Please share you sensor configuration and what was exactly the problem. What results do you expect? The temperature sensor can be used to measure temperature variations. |
谢谢您的回答。我解决了上面的问题,但是我对6D位置检测有另一个问题。
首先我的配置: 所有三个轴都启用,低功耗模式10Hz(寄存器0x20 = 0x2F)BDU激活,+ -2g FS(寄存器0x23 = 0x80)AOI1 on INT1 PIN(寄存器0x22 = 0x40)INT1 Treshhold 500mg(寄存器0x32 = 0x20)INT1时间0s(寄存器0x33 = 0x00)INT1 6D位置检测,z高&低电平激活(寄存器0x30 = 0xF0)使用此配置时,如果z轴的值高于约900mg或低于-900 mg,则PIN INT1为高电平,但阈值应为500mg。 我在配置中犯了错误吗? 是否有计算,以获得与配置的阈值的角度? 以上来自于谷歌翻译 以下为原文 Thank you for your answer. I solved the questions above, but I have another problem with the 6D position detection. First of all my configuration:
Have I made a mistake in the configuration? Is there a calulation, to get the angle with the configured treshhold? |
角度和阈值具有以下关系=×sin()其中A是以g为单位的加速度,g是地球的重力(1g)和?是以度为单位的角度。
因此,对于您的值0x20(500mg),中断会产生与横向向上或横向向下方向最多30°的偏差( 寄存器0x30 = 0xF0) 。 为了检测这两个方向,将X和Y轴上的值与阈值进行比较。只有当X轴和Y轴的值低于500mg时,才能检查INT1引脚是否为高电平,Z轴值不重要。 以上来自于谷歌翻译 以下为原文 The angle and the threshold have following relation = × sin ( ) where A is acceleration in g, g is Earth?s gravity (1g) and ? is angle in degrees. So for your value 0x20 (500mg) the interrupt is generated up to 30° deviation from landscape up or landscape down orientations ( Register 0x30=0xF0) . To detect these two orientations the values in X and Y axis is compared with the threshold. You can check the INT1 pin is high only if the value in X and Y axis are bellow 500mg, Z axis value is not important. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1582 浏览 1 评论
2265 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1518 浏览 1 评论
2889 浏览 6 评论
5393 浏览 21 评论
393浏览 4评论
653浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
295浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
742浏览 3评论
613浏览 3评论
GMT+8, 2024-5-11 07:46 , Processed in 0.846318 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
