我正在使用一个图形LCD(8080接口)在我的项目中。在使用GrimeLCCDInf1V16在创建者中发现它难以与PSoC5进行接口之后,我设法通过使用GPIO中的GPIO引脚来连接它。我已经建立了我的四个控制引脚(NCS,NRD,NWR和AO)作为数字输出,并将它们物理连接到LCD。我已经设置了8个数据引脚作为数字输出/数字输入,并连接到LCD。我可以给LCD写完美的文字和绘制一些图形。对于需要阅读的例程,问题开始了。我看不懂液晶显示器!我怀疑我错过了我的PIN设置的东西。当我尝试将数据引脚设置为双向引脚时,我甚至无法写入LCD。当我把引脚设置为数字输入和数字输出时,我可以写入LCD,但不能从中读取。有想法的人请帮助。
以上来自于百度翻译 以下为原文 I am using a graphics lcd (8080 interface) in my project. After finding it difficult to interface it with the psoc5 using the graphiclcdintf_v1_6 in creator I managed to inteface it by connecting it up using gpio pins in creator. I have set up my four control pins (nCS, nRD, nWR and AO) as digital outputs and connected them physically to the lcd. I have set up the 8 data pins as digital output/ digital inputs and connected to the lcd as well. I can write to the LCD perfectly - writing text and drawing some graphics. For routines that require reading, the problems begin. I cannot read the lcd memory! I suspect that I missed something in my pin setup. When i try setting up the data pins as bidirectional pins, I fail to even write to the lcd. When I set the pins as digital input and digital output I can write to the lcd but cannot read from it. Anyone with ideas- please help. |
2个回答
是的,在使用双向引脚时,我使用了电阻上拉和下拉设置。我可以很好地阅读LCD的文本层,但是我无法读取图形层而没有错误。我已经意识到,这是一个常见的问题,这种类型的显示器(SED1335/RA835)。因此,我的问题最终不是PSoC问题。
以上来自于百度翻译 以下为原文 Yes, I used the resistive pull-up and pull down setting while using the bidirectional pins. I can perfectly read the text layer of the LCD but I cant read the graphics layer without errors. I've since realised that this has been a common problem with this type of display (sed1335/ ra8835). So my problem turns out is not a PSoC problem, after all. |
只有小组成员才能发言,加入小组>>
718个成员聚集在这个小组
加入小组1911 浏览 1 评论
1666 浏览 1 评论
3419 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1583 浏览 6 评论
1388 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
210浏览 2评论
195浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
341浏览 2评论
367浏览 1评论
76浏览 1评论
GMT+8, 2024-5-14 00:34 , Processed in 0.807212 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
