你好,
我用PSPAC1的PSOC1和CY3266A的示意图来测量PIR传感器。我一直工作很好,直到我选择了VC2数据时钟源而不是VC1。我选择VC1来管理CyFi的时钟,并且我固定了2的值,即VC1= SysCLK/4=24MHz/4=6MHz。 另一方面,我已经将ADCIMC的时钟源改变为VC2,并且i已经固定了3的值,即VC2=VC1/N=6MHZ/3=2MHz。对于我来说,当我将ADCICC模块的时钟源从VC1改变为VC2时,该项目的工作正常。从ADC得到的值超出范围。 我不能使用VC3来配置CyFi,因为我需要这个模块带有CNT8。 有谁知道这是什么事?我能用另一种方式来管理这个项目的CYFI吗? 提前感谢和问候, 魔光子 以上来自于百度翻译 以下为原文 Hi, I'm working with the example for PSoC1 of PIRMOtiON kit and CY3236A schematic to measure PIR sensor. IHas been working fine until I have choosen VC2 data clock source instead VC1. I choose VC1 to manage the clock of CyFi and I fixed a value of 2, namely, VC1=SysClk/4=24MHz/4=6MHz. For other hand, I have changed the clock source of the ADCINC to VC2 and I have fixed a value of 3, namely, VC2=VC1/N=6MHz/3=2MHz. For me atonishment, when I change the clock source of the ADCINC module from VC1 to VC2 having the same value the project doent work properly. The values gets from the ADC are out of range. I can't use VC3 to configure CyFi because I need this source with the module CNT8. Anyone know what is this happening? Could I manage the clock in another way to use CyFi with this project? Thanks in advance and regards, MagicPhoton |
4个回答
张贴你的项目,让论坛可以看看它。
使用IE或Firefox,而不是Chrome。 问候,Dana。 以上来自于百度翻译 以下为原文 Post your project so forum can take a look at it. Use IE or Firefox, not chrome. Regards, Dana. |
也许,VCS的使用有点混乱。是否有一些模块使用相同的VC来实现立柱时钟?我参观了射频集线器设计,所以我感觉到了。总之,需要一个实际的设计文件来获得更多的细节。当做。
以上来自于百度翻译 以下为原文 Hi MagicPhoton Maybe, there are some confusion of usage of VCs. Is there some module using same VC for column clock? I have looking around The RF HUB design,So I felt it. Anyway, Need an actual design file to get more in detail. Regards. |
检查ADC的数字和模拟部件的时钟是同一个源。鲍勃
以上来自于百度翻译 以下为原文 Check that ADC's clocks for digital AND analog parts are the same source. Bob |
谢谢鲍伯。你是对的,我忘了改变模拟时钟源,我认为这两个部分同时发生了变化。
谢谢大家的快速回答。 当做, 魔光子 以上来自于百度翻译 以下为原文 Thanks Bob . You are right, I forgot change the analog clock source, i thought that the changes occurred in both parts at the same time. Thanks all for yours fast answers. Regards, MagicPhoton |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1903 浏览 1 评论
1654 浏览 1 评论
3409 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1570 浏览 6 评论
1382 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
191浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
325浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-27 11:16 , Processed in 0.682093 second(s), Total 77, Slave 61 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
