我在这篇文章(WICE智能蓝牙论坛)的步骤,以改变我的BLE MAC地址到生产编程的自定义值。然而,我正试图找出是否有一种方法可以读取UART程序员引脚上的闪存,这样我就可以检查它是否已经用预期的MAC地址编程了,如果是这样的话,可以使用同一个。到目前为止,在这篇文章中的拉链工具中,似乎没有任何资源可以做到这一点。我也找不到通过Wide IDE读取闪存的方法。有什么建议吗?
以上来自于百度翻译 以下为原文 I went through the steps in this post (WICED Smart Bluetooth Forums ) to change my BLE Mac address to a custom value on production programming. However I am trying to discover if there is a way I can read the flash memory across the UART programmer pins so I can check if it has already been programmed with an expected mac address, and if so, to use the same one. So far out of the Zipped tools in that post, it doesn't appear to have any resources to do that. I also wasn't able to find a way to read flash memory through the WICED ide. Any suggestions? |
4个回答
我认为在UART端口上阅读BDY-ADDR没有直接的方法。可以使用BLeCMH-HCIADBADDRD()函数读取地址。该地址将在BLECM事件处理程序中报告。
以上来自于百度翻译 以下为原文 I don't think there's a direct way to read the BD_ADDR over the UART port. You could use the blecm_hciReadBdAddr() function to read the address. The address will be reported in an blecm event handler. |
烈阳异丙醇 发表于 2018-12-17 13:10 我刚刚在BLECM.H中查找了函数头。 无效; 如果我不能通过一个指针,我就不能从函数调用中获得地址,而我得不到返回。地址读到哪里去了? 以上来自于百度翻译 以下为原文 I just looked up that function header in blecm.h void blecm_hciReadBdAddr(void); How am i supposed to get the address from the function call if I can't pass in a pointer and I don't get a return. Where is the address read going to? |
当调用该函数时,将触发BLECM-EVT处理程序,并在事件处理程序中报告设备地址。如果启用打印日志,则可以看到正在打印的设备地址。 以上来自于百度翻译 以下为原文 When you call that function, the blecm evt handler will be triggered and the device address will be reported in the event handler. If you enable the print logs, you can see the device address being printed. |
只有小组成员才能发言,加入小组>>
717个成员聚集在这个小组
加入小组1903 浏览 1 评论
1654 浏览 1 评论
3409 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1570 浏览 6 评论
1382 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
190浏览 2评论
184浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
325浏览 2评论
352浏览 1评论
63浏览 1评论
GMT+8, 2024-4-26 23:40 , Processed in 0.658176 second(s), Total 78, Slave 62 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
