您好,我已经制作了一个原型的led驱动程序
一个HVLED815PF,这很好。 现在我想添加一个集成的日/夜 用最少的部件切换到灯泡。 是否可以将HVLED815放入其中 有点睡眠模式或待机模式 电源消耗 (虽然整流的电源仍在排水管上)? 或者我必须断开电路形式 主电源? 该灯是一个10W的LED灯,由230V电源供电, 高功率因数电路,不可调光,内置适应性 AN4129原理图和元件值。 谢谢, 法比奥·埃博利 #hvled815 #led 以上来自于谷歌翻译 以下为原文 Hello, I've prototyped a led driver built around an HVLED815PF, it's woking nicely. Now I'd like to add an integrated day/night switch to the lamp, with minimal components. Is it possible to put the HVLED815 in some sort of sleep-mode or standby, with minimal power consumption from th supply (while the rectified mains is still on the drain)? Or I have to disconnect the circuit form the mains supply? The lamp is a 10W led lamp, powered from 230V mains, high power factor circuit, not dimmable, built adapting the AN4129 schematic and component values. Thanks, Fabio Eboli #hvled815 #led |
1个回答
您好,我回复自己并回来了
一个解决方案和更多问题,也许这可以 对别人有帮助。 解决方案是改变输出电压,改变输出电压 分压比通过晶体管到DMG引脚。 这会改变允许的最大输出电压。 将最大电压值置于LED正向电压以下, 关闭psu并使其在突发模式下工作。 但我仍然不满意,司机仍然需要约 主电源电流为4mA。观察 收集器,我看到它检查电压,脉冲 每个500uS的漏极,根据数据表。 40-60mS后 它会重新启动并恢复输出电容上的电压损失。 次级有一个泄放电阻,现在的问题是: 怎么能减少主电源的功率? 如果我提高输出泄放电阻的值,我可能会 减慢重启速度,降低功率 在电阻器上消散,但LED发光。 这是由于过量的电感引起的 铁氧体磁芯? 如果我减小输出电阻,我可以制作LED 关闭,但psu将从更多的电流 电源。 欢迎任何想法... ST工程师,你在这附近吗? ;) 谢谢。 以上来自于谷歌翻译 以下为原文 Hello, I reply to myself and come back with one solution and more questions, maybe this can be helpful to somebody else. The solution it to change the output voltage, changing the divider ratio to DMG pin trough a transistor. This changes the maximum output voltage allowed. Putting the max voltage value below the leds forward voltage, shuts down the psu and makes it work in burst-mode. But I'm still not satisfied, the driver still takes approx 4mA of current from mains. Observing the collector, I see that it checks the voltage, pulsing the drain each 500uS, as per datasheet. After 40-60mS it restarts and recovers the voltage lost on the output capacitors. The secondary has a bleeder resistor, now the problem is: how could I reduce the power taken from mains? If I raise the value of output bleeder resistor, probably I will slow down the restarting rate, reducing the power dissipated on the resistor, but the leds keep glowing. Is this due to excessive leackage inductance on the ferrite core? If I reduce the output resistor, I can make the leds shut down, but the psu will take more current from mains. Any ideas is welcome... ST engineers, are you around here? ;) Thanks. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1551 浏览 1 评论
2230 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1517 浏览 1 评论
2874 浏览 6 评论
5362 浏览 21 评论
383浏览 4评论
621浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
294浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
713浏览 3评论
586浏览 3评论
GMT+8, 2024-5-6 20:57 , Processed in 0.826480 second(s), Total 75, Slave 59 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
