我有一个使用PIC18F66K22的设计,它在非睡眠模式下使用ADC工作“OK”,但是结果似乎随固定输入变化约10%。我做转换8次,取平均值,但仍然看到很多变化。我想尝试在睡眠模式下运行ADC,看看这是否会改善结果。我已经尝试了一些方法,但是PIC似乎挂起了。有人能指点一下在睡眠模式下使用ADC的一些示例代码吗?我已经尝试过搜索,并且找到了一些使用HITECH内置例程的例子,但是我无法弄清楚例程是什么样子,我正在使用XC8编译器。谢谢,Pete。
以上来自于百度翻译 以下为原文 I have a design using a PIC18F66K22 that is working "OK" using the ADC in non-sleep mode, however the results seem to vary with a fixed input by about 10%. I am doing the conversion 8 times and taking the average, but still see a lot of variation. I wanted to try running the ADC in sleep mode to see if this would improve the results. I have tried a few ways to do this but the PIC seems to hang. Can anyone point me to some sample code that uses the ADC in sleep mode? I have tried searching around and have found some examples using the HITECH built-in routines, but I was not able to figure out what the routines looked like and I am using the XC8 compiler. Thanks, Pete |
3个回答
通常,在进入睡眠模式之前,开始A/D转换,然后通过A/D中断退出睡眠模式。
以上来自于百度翻译 以下为原文 Normally you start the A/D conversion before entering sleep mode, then exit sleep mode via the A/D interrupt. |
你有没有对进入ADC管脚的信号进行过滤?
以上来自于百度翻译 以下为原文 Do you have any filtering on the signal coming in to the ADC pin? |
ADC引脚是从运算放大器驱动的。它是一个直流电路,在Op Amp(1000 PF)的输出上有一个小的盖。用一个范围看信号显示很少的噪声(大约1%的变化),但是ADC从样品到样品显示大约10%或更多。
以上来自于百度翻译 以下为原文 The ADC pin is driven from an Op Amp. It is a DC circuit with a small cap on the output of the Op Amp (1000pf). Looking at the signal with a scope shows very little noise (about 1% variation) but the ADC is showing about 10% or more from sample to sample. |
只有小组成员才能发言,加入小组>>
4850 浏览 9 评论
1847 浏览 8 评论
1773 浏览 10 评论
请问是否能把一个ADC值转换成两个字节用来设置PWM占空比?
2975 浏览 3 评论
请问电源和晶体值之间有什么关系吗?PIC在正常条件下运行4MHz需要多少电压?
2076 浏览 5 评论
474浏览 1评论
320浏览 1评论
PIC Kit3出现目标设备ID(00000000)与预期的设备ID(02c20000)不匹配。是什么原因
379浏览 0评论
271浏览 0评论
LAN9252使用SQI通信,进行数字复位后读BYTE_TEST异常
1828浏览 0评论
GMT+8, 2024-5-21 22:58 , Processed in 1.005980 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
