我刚刚购买了准峰值检测卡(HP 5062-1983)。
和11946-60002一样吗? 有谁知道这张卡是否可以作为“选件103”安装在HP 8591A上,还是仅适用于8590系列中的其他型号? 如果是这样,它是否只是插入卡笼或是否需要额外的连接和修改(我希望我需要安装扬声器)? 我已经有了QP驱动卡和驱动程序说明,并且已经在互联网上搜索过,但似乎没有任何关于如何安装卡的说明。 在此先感谢托尼 以上来自于谷歌翻译 以下为原文 I have just acquired a Quasi-Peak Detector Card (HP 5062-1983). Is it the same as 11946-60002 ? Does anyone know if this card can be fitted to a HP 8591A as "Option 103" or does it only fit other models in the 8590 series? If so, does it just slot into the card cage or are there additional connections and modifications required (I expect I will need to fit a speaker)? I already have the QP driver card and the driver instructions, and have searched the internet but there does not appear to be any instructions available for how to install the card. Thanks in advance Tony |
3个回答
嗨Tony,是的,它是同一块板,它也可以用在8591A中。
随附您可以找到准峰值检测器升级套件的安装说明。 它还有材料列表,它显示其他部分,如扬声器,音量控制和接线,但如果您不需要demod声音,您可以使用探测器功能,只需安装卡和驱动程序。 如果仪器已经有选项102 FM Demod所有的扬声器和东西已经存在,你只需将连接移动到选项103板,它需要deididant demod。 最好的问候,迈克 以上来自于谷歌翻译 以下为原文 Hi Tony, Yes, it is the same board, and it can be used in the 8591A as well. Attached you will find the installation note for the quasi-peak detector upgrade kit. It also has the material list, which does show other parts such as the speaker, volume control, and the wiring, but if you don't need the demod sound you can use the detector functionality with just the card and driver installed. If the instrument already has option 102 FM Demod all of the speaker and stuff is already there, you just move the connections to the option 103 board, it takes precidant for demod. Best regards, Mike 附件
cmh23 发表于 2018-10-26 17:47 非常感谢迈克。 另外一个问题 - 我没有安装选件102,找到扬声器和RFI板可能会非常困难。 这些绝对必要吗? - 我不太担心缺乏声音,对我而言,在需要时能够获得QP读数非常重要。 托尼 以上来自于谷歌翻译 以下为原文 Thanks very much indeed Mike. One additional question - I don't have option 102 installed, and it is probably going to be very diffiecult to find the speaker and the RFI plate. Are these absolutely necessary? - I'm not too worried about the lack of sound, for me it's only really important to be able to obtain QP readings when required. Tony |
迈克 - 对不起,我第一次看到你时错过了部分答案! 我现在看到你已经回答了我的其他问题。 我现在设法获得了演讲者 - 所以我期待着一个好的结果再次感谢Tony 以上来自于谷歌翻译 以下为原文 Mike - sorry I missed part of your answer when reading it the first time! I see now that you already answered my additional question. I have managed to obtain the speaker now - so am looking forward to a good result Thanks again Tony |
只有小组成员才能发言,加入小组>>
2110 浏览 1 评论
1873 浏览 1 评论
1727 浏览 5 评论
2599 浏览 3 评论
将设备连接到PC并通过asic格式读取数据然后我的网络分析仪挂起
1571 浏览 4 评论
518浏览 1评论
关于Keysight x1149 Boundary Scan Analyzer
373浏览 0评论
1433浏览 0评论
N5230C用“CALC:MARK:BWID?”获取Bwid,Cent,Q,Loss失败,请问大佬们怎么解决呀
285浏览 0评论
2267浏览 0评论
GMT+8, 2024-5-13 19:05 , Processed in 1.204291 second(s), Total 51, Slave 45 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
