你好,
我正在努力使用vmware 6.5u1在主机上加载nvidia驱动程序。 检查dmesg>输出: [root @ newhost:〜] dmesg | grep -E“NVRM | nvidia” 2017-11-06T11:37:35.084Z cpu12:66798)启动服务nvidia-init 2017-11-06T11:37:35.085Z cpu12:66798)激活Jumpstart插件nvidia-init。 2017-11-06T11:37:35.287Z cpu12:66798)Jumpstart插件nvidia-init激活。 [root @ newhost:〜] nvidia-smi NVIDIA-SMI因为无法与NVIDIA驱动程序通信而失败。 确保已安装并运行最新的NVIDIA驱动程序。 我不知道为什么它不加载它。 我试过了两个: NVIDIA-的vGPU - 开普勒的vSphere,6.5-367.106-370.12 NVIDIA-的vGPU - 开普勒的vSphere,6.5-367.122-370.16 ....没有成功。 有人提示还有什么可以尝试或做什么? 保罗 以上来自于谷歌翻译 以下为原文 Hi there, I am struggling with getting the nvidia driver loaded on a host with vmware 6.5u1. Checking dmesg > Output: [root@newhost:~] dmesg | grep -E "NVRM|nvidia" 2017-11-06T11:37:35.084Z cpu12:66798)Starting service nvidia-init 2017-11-06T11:37:35.085Z cpu12:66798)Activating Jumpstart plugin nvidia-init. 2017-11-06T11:37:35.287Z cpu12:66798)Jumpstart plugin nvidia-init activated. [root@newhost:~] nvidia-smi NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running. I don't have a clue why it doesn't load it. I tried both: NVIDIA-vGPU-kepler-vSphere-6.5-367.106-370.12 NVIDIA-vGPU-kepler-vSphere-6.5-367.122-370.16 ....without success. Anyone a hint what else to try or to do? Paul |
3个回答
您使用的是错误的vGPU管理器。
开普勒不会为Maxwell工作!!!! 以上来自于谷歌翻译 以下为原文 You're using the wrong vGPU manager. Kepler won't work for Maxwell!!!! |
我有问题。
这是我应该安装的所有帐户的驱动程序(我有): NVIDIA-VMware_ESXi_6.5_Host_Driver 384.73-1OEM.650.0.0.4598673 NVIDIA VMwareAccepted 2017-11-09 当我将vGPU配置文件附加到我的Windows 7虚拟机并尝试打开电源时,我收到以下错误“父资源池中可用的图形资源量不足以进行操作。” 它似乎指向这个VMware KB: https://kb.vmware.com/s/article/2126577 我再次相信我已经安装了正确的VIB,但是kb说它应该在描述中说vGPU。 如果我安装了不正确的振动器,我在哪里可以得到正确的振动器? 以上来自于谷歌翻译 以下为原文 I'm having issues. This is the driver that by all accounts I should have installed (and I have): NVIDIA-VMware_ESXi_6.5_Host_Driver 384.73-1OEM.650.0.0.4598673 NVIDIA VMwareAccepted 2017-11-09 When I attach a vGPU profile to my Windows 7 vm and attempt to power-on I get the following error "The amount of graphics resource available in the parent resource pool is insufficient for the operation." It seems to point to this VMware KB: https://kb.vmware.com/s/article/2126577 Once again I believe I've installed the correct VIB, but the kb says it should say vGPU in the description. If I've installed the incorrect vib, where do I get the correct one? |
决议与本文有关:
https://gridforums.nvidia.com/default/topic/1030/nvidia-vmware-vsphere-6-5/ 以上来自于谷歌翻译 以下为原文 Resolution was related to this article: https://gridforums.nvidia.com/default/topic/1030/nvidia-vmware-vsphere-6-5/ |
只有小组成员才能发言,加入小组>>
使用Vsphere 6.5在Compute模式下使用2个M60卡遇到VM问题
2847 浏览 5 评论
是否有可能获得XenServer 7.1的GRID K2驱动程序?
3230 浏览 4 评论
GMT+8, 2024-5-9 14:05 , Processed in 0.747449 second(s), Total 80, Slave 64 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
