你好,
我面临着实现睡眠模式的挑战。 在我们的代码中,LPM被初始化,低功耗查询回调也被注册。 问题是低功耗查询回调被连续调用,芯片组DOUNSOT似乎正在进入休眠模式。 基于低功耗查询回呼值,预计睡眠时间为1秒。 给定场景的附加源文件。跟踪转储 0:24:41-创建() 00∶24:41—1 00∶24:41—0018 0:24:41-0203000 0:24:41-636F6F6B705F6C706D 0:24:41-0205000 012A 00∶24:41—0003 00∶24:41—0118 0:24:41-0D 00∶24:41-0D00 0:24:41-02010503030118020A04 0:24:41-0A09636F6F6B705F6C706D 0:24:41跟踪解码错误-找不到第314行 属性字节 0:24:41句柄:0002 00:24:41烫发:0002 00∶24:41伦,Max Len:0005, 0005 0:24:41 UUID:2803 属性字节 0:24:41句柄:0003 00:24:41烫发:0000 00∶24:41伦,Max Len:0009, 0009 0:24:41:UAID:2A00 属性字节 0:24:41句柄:0004 00:24:41烫发:0002 00∶24:41伦,Max Len:0005, 0005 0:24:41 UUID:2803 属性字节 0:24:41句柄:0005 00:24:41烫发:0000 00∶24:41伦,Max Len:0002, 0002 0:24:41 UUID:2A01 属性字节 0:24:41句柄:0006 00:24:41烫发:0002 00∶24:41伦,Max Len:0002, 0002 0:24:41 UUID:2800 属性字节 0:24:41关贸总协定数据库转储完成 0:24:41 BDY-ADDR[5:2]=20 73 6A 11 0:24:41 BDY-ADDR [1:0]=00 00 0:24:41 GPIO 0001(11) 0:24:41 GPIOIWP:OFF=00 0:24:41电池电量:0/100 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 0:24:42-LPM 0 CoppLLPM.dB.H.Zip 1.3 K CoppLLPM.D.C.Zip 1.8 K CoppLLPM.C.Zip 4.6 K 以上来自于百度翻译 以下为原文 Hello, I am facing challenge in achieving Sleep Mode. In our code, LPM is initialized and low power query call-back is also register. Issue is lowpowerquery call back is continously called and chipset doensot seems to be entering SLEEP mode. It is expected to sleep for 1second, based on low power query call back return value. Attached source file for given scenario. and trace dump 00:24:41 - create() 00:24:41 - 1.00 00:24:41 - 0018 00:24:41 - 020300002a 00:24:41 - 636f6f6b705f6c706d 00:24:41 - 020500012a 00:24:41 - 0003 00:24:41 - 0118 00:24:41 - 0d 00:24:41 - 0d00 00:24:41 - 02010503030118020a04 00:24:41 - 0a09636f6f6b705f6c706d 00:24:41 Trace Decoding Error - Could not find line number 314 00:24:41 Attribute bytes 00:24:41 Handle: 0002 00:24:41 Perm : 0002 00:24:41 Len, Max Len : 0005, 0005 00:24:41 UUID : 2803 00:24:41 Attribute bytes 00:24:41 Handle: 0003 00:24:41 Perm : 0000 00:24:41 Len, Max Len : 0009, 0009 00:24:41 UUID : 2A00 00:24:41 Attribute bytes 00:24:41 Handle: 0004 00:24:41 Perm : 0002 00:24:41 Len, Max Len : 0005, 0005 00:24:41 UUID : 2803 00:24:41 Attribute bytes 00:24:41 Handle: 0005 00:24:41 Perm : 0000 00:24:41 Len, Max Len : 0002, 0002 00:24:41 UUID : 2A01 00:24:41 Attribute bytes 00:24:41 Handle: 0006 00:24:41 Perm : 0002 00:24:41 Len, Max Len : 0002, 0002 00:24:41 UUID : 2800 00:24:41 Attribute bytes 00:24:41 Gatt DB Dump complete 00:24:41 bd_addr[5:2] = 20 73 6A 11 00:24:41 bd_addr[1:0] = 00 00 00:24:41 GPIO 0001 (11) 00:24:41 GPIO_WP:OFF= 00 00:24:41 Battery level: 0/100 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0 00:24:42 - LPM 0
3个回答
使用模块测试代码吗?如果是,你会想做水晶预热修复。您可能希望将非零值设置为更精细的定时器,例如50。
或者你能在你的应用程序代码中的第248行返回0而不是1000? 我还建议你使用诸如WijdEnStand之类的示例应用程序建立的编码来开发你的睡眠/深度睡眠。我会避免 WORD蓝牙设计师。 以上来自于百度翻译 以下为原文 Are you using a module to test your code? If yes, you will want to do the crystal warm up fix. And you may want to set a non zero value to your finer timer, such as 50. Or can you return 0 instead of 1000 at line 248 in your app code? I also suggest that you develop your sleep/deep_sleep using established coding from sample apps like wiced_sense. I will avoid the wiced bluetooth designer. |
从Wice感测代码的第796行,它拼写出如何进入休眠模式。
以上来自于百度翻译 以下为原文 From line 796 of the wiced sense code, it spelt out how to enter sleep mode. |
广州洋钒 发表于 2018-10-3 13:47 问题是,返回值应该是从美国东海岸线248。 任何低于3.5msec是拒绝和芯片没有进入睡眠。 因此返回1000000秒1秒睡眠。 以上来自于百度翻译 以下为原文 Issue is the return value should be in terms of usec at line 248. Anything less than 3.5msec is rejected and chip doesnot enter sleep. So return 1000000 for 1 sec Sleep. |
只有小组成员才能发言,加入小组>>
718个成员聚集在这个小组
加入小组1910 浏览 1 评论
1665 浏览 1 评论
3418 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1581 浏览 6 评论
1387 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
207浏览 2评论
194浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
337浏览 2评论
365浏览 1评论
74浏览 1评论
GMT+8, 2024-5-11 06:32 , Processed in 0.686513 second(s), Total 52, Slave 46 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
