你好伙计们,
不知道在哪里发布这个,因为传感器类别中的压力传感器似乎没有任何子类别,所以我在这里发布它,请原谅任何有关该计数的进攻。 我们一直在使用LPS331AP进行几种设计,并且只有在最近的一次电路板旋转中我们才注意到这个问题。我们使用的电路与数据表中详述的相同。器件配置为I2C通信模式,分辨率设置为0.025 mbar,温度和压力的内部平均值设置为1,温度和压力设置为25 Hz的连续模式速率,两个中断引脚均配置为数据就绪中断。 我们遇到的问题是数据就绪脉冲不能始终如一地发射(见附图),所以虽然它会定期以正确的速率运行,但它会经常错过脉冲。将具有相同寄存器配置(可正常工作)的单元与另一个单元进行比较,该单元与电路立场没有明显的电气差异,也没有从配置寄存器的角度看出。 我真的很想知道可能导致这种情况的原因,我希望有人可能会知道是什么原因造成这个问题。 任何想法或相关经验与人们可以分享的这部分将非常感激。 非常感谢,无论如何。 问候, 格雷格 #lps331ap数据准备好断言-SP 以上来自于谷歌翻译 以下为原文 Hello Folks, Not sure where else to post this as there doesn't seem to be any subcategory for pressure sensors in the sensors category, so I'm posting it here, please forgive any offense on that count. We've been working with the LPS331AP on a couple of designs and only on a recent board spin have we noticed this issue on a number of units. The circuit we're using is identical to that detailed in the datasheet. The device is configured in I2C communications mode, with the resolution set to 0.025 mbar, the internal averaging for both temp and pressure set to 1, continuous mode rates set for 25 Hz for both temperature and pressure, and both Interrupt pins configured as data ready interrupts. The problem we're having is that the data ready pulse does not fire consistently (see attached picture), so while it will operate at the correct rate periodically, it will frequently miss pulses. Comparing a unit with identical register configurations (which works correctly) with another unit which does not shows no apparent electrical differences from a circuit standpoint nor any from a configuration register standpoint. I'm really scratching my head as to what might be causing this and I was hoping that someone might have some idea if what could be causing the issue. Any ideas or relevant experiences with this part that folks could share would be much appreciated. Thanks kindly in every case. Regards, Gregg #lps331ap-data-ready-asserting-sp |
2个回答
嗨格雷格,
您有没有得到有关LPS331AP问题的回复?我的一些LPS331AP看到了类似的问题。 谢谢, 玛丽 以上来自于谷歌翻译 以下为原文 Hi Gregg, Did you ever get a response concerning your LPS331AP issue? I'm seeing a similar problem with a few of my LPS331APs. Thanks, Mary |
你好,
我的ST FAE建议转到LPS25H,因为它们无法解决我所拥有的INT数据就绪输出问题。我花了很多时间来优化代码和正交补偿以及IRR Filter例程......时间浪费。 现在我开始用LPS25H评估STEVAL ....我希望我会更好。 以上来自于谷歌翻译 以下为原文 Hello, my ST FAE suggest to move to LPS25H because They can't solve the problem concerning INT Data Ready output that I have. I spent lot of weeks to optimize the code and quadrature compensation and IRR Filter routines... time waste. Now I'm starting with LPS25H evaluation STEVAL.... I hope I will be better. |
只有小组成员才能发言,加入小组>>
请教:在使用UDE STK时,单片机使用SPC560D30L1,在配置文件怎么设置或选择?里面只有SPC560D40的选项
1595 浏览 1 评论
2277 浏览 1 评论
请问是否有通过UART连接的两个微处理器之间实现双向值交换的方法?
1518 浏览 1 评论
2896 浏览 6 评论
5395 浏览 21 评论
395浏览 4评论
662浏览 4评论
在Linux上安装Atollic TRUEStudio的步骤有哪些呢?
295浏览 3评论
使用DMA激活某些外设会以导致外设无法工作的方式生成代码是怎么回事
744浏览 3评论
620浏览 3评论
GMT+8, 2024-5-12 15:01 , Processed in 0.712456 second(s), Total 48, Slave 41 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
