在WICE中是否有任何额外的步骤来支持IPv6?我对IPv6是新的,所以我真的不知道从哪里开始测试IPv6功能。
当我的应用程序启动时,无论是在FrReToS+LWIP还是THEXX+NETXX-DIO,我都看到了这个消息。 IPv6网络准备就绪的IP:FE80:00:00:万:BAD7:AFF:FE28:B672(或F80::BAD7:AFF:FE28:B672在LWIP构建) 我应该能在同一局域网上从Windows PC上ping这个地址吗?ping返回目标主机不可访问。PC能够ping模块的IPv4地址。 我需要在局域网上运行一个DHCPv6服务器来提供地址吗?它看起来不像我的网件有内置的DHCPv6,有没有基于PC的服务器? 我用CYW43907跑步6.1。 以上来自于百度翻译 以下为原文 Are there any extra steps required to enable IPv6 in WICED? I am new to IPv6 so I do not really know where to begin in order to test IPv6 functions. When my app starts up, either in FreeRTOS+lwIP or ThreadX+Netx_duo, i see the message IPv6 network ready IP: FE80:0000:0000:0000:BAD7:AFFF:FE28:B672 (or FE80::BAD7:AFFF:FE28:B672 in the lwip build) Should I be able to ping this address from a Windows PC on the same LAN? Ping returns Destination host unreachable. The PC is able to ping the module's IPv4 address. Do I need to run a DHCPv6 server on my LAN to provide an address? It does not look like my Netgear has a built in DHCPv6, are there any PC based servers? I am running WICED 6.1 with a CYW43907. |
5个回答
有两个电脑的无线网络,我可以平两计算机使用IPv6地址和分配地址的DHCP服务器之间(点播)
的cyw43907不出现拉一个IPv6地址从DHCP服务器不响应ping的尝试。 我建在WICED控制台应用程序试图运行在IPv6模式供之间的Wi-Fi模块和一台笔记本电脑,我无法连接。 **这些测试是用TyRex/NETX双选项进行的。 以上来自于百度翻译 以下为原文 With two PC's on the wireless network, I can ping between the two computers using the IPv6 local address and a assigned address from a DHCP server (dibbler) The CYW43907 does not appear to pull an IPv6 address from the DHCP server not does it respond to a ping attempt. I built the console application in WICED and attempted to run iperf in IPv6 mode between the wi-fi module and a laptop and I was unable to make a connection. ** These tests are with the ThreadX / NetX-Duo options. |
cmh23 发表于 2018-9-24 19:40 只要您在同一子网中通信,就不需要IP前缀。 但是当你需要一个全局IP地址时,子网就应该被分发到节点以允许路由。 以上来自于百度翻译 以下为原文 As long as you are communicating within the same subnet, no IP prefix is required. But when you need a global IP address, then the subnet should be distributed to the nodes to enable routing. |
你好,Nick:
实际上,我做了一个基于6.1 SDK版本的测试,我用APSA应用程序进行测试。 在这里添加的结果,应该证明IPv6在发布中可以很好地工作。但是我的环境是 Wi7 WiFi敲击软芯,使iPHELPL服务在连接之前工作。 以上来自于百度翻译 以下为原文 Hi Nick: Actually I did a test based on 6.1 sdk release, and I used APSTA application for the test. add the results here, it should prove ipv6 can work well in the release . but my environment is Win7 wifi pinging wiced softAP, and make the iphelper service working before the connection. |
DH9527 发表于 2018-9-24 20:06 我尝试了ApStA与FreeRTOS & LWIP=不能够ping与目标主机不可到达的错误。 我尝试了用TestReX和NETX DOO= 为什么我不能使用LWIP?支持IPv6。我的应用程序必须使用FiReToS+LWIP并支持IPv6向前发展。 启用iPHELPL,Windows 10 顺便问一下,这只会和主机一起使用iPHELPER吗? 以上来自于百度翻译 以下为原文 I tried apsta with FreeRTOS & lwIP = not able to ping with destination host unreachable error. I tried apsta with ThreadX & NetX Duo = able to ping Why can I not use lwIP? IPv6 is supported. My application has to use FreeRTOS + lwIP and support IPv6 going forward. iphelper is enabled, windows 10 By the way, will this only work with a host using iphelper? |
cmh23 发表于 2018-9-24 20:21 添加我的测试补丁,补丁是基于6.1 SDK版本。IPv6 ping功能运行良好,但不知道它是否能满足所有的需求,谢谢。 LIPIP IPV4.7Z.ZIP 31.1 K 以上来自于百度翻译 以下为原文 add my test patch, the patch is based on 6.1 sdk release . The Ipv6 ping function works well, but don't know if it can match all the needs, thanks.
只有小组成员才能发言,加入小组>>
718个成员聚集在这个小组
加入小组1909 浏览 1 评论
1663 浏览 1 评论
3418 浏览 1 评论
请问可以直接使用来自FX2LP固件的端点向主机FIFO写入数据吗?
1579 浏览 6 评论
1387 浏览 1 评论
CX3连接Camera修改分辨率之后,播放器无法播出camera的画面怎么解决?
206浏览 2评论
193浏览 2评论
使用stm32+cyw43438 wifi驱动whd,WHD驱动固件加载失败的原因?
336浏览 2评论
363浏览 1评论
73浏览 1评论
GMT+8, 2024-5-9 14:40 , Processed in 0.916811 second(s), Total 86, Slave 70 queries .
Powered by 电子发烧友网
© 2015 bbs.elecfans.com
关注我们的微信
下载发烧友APP
电子发烧友观察
版权所有 © 湖南华秋数字科技有限公司
